January 26th, 2018, 01:27 PM | #1 |
anyone up for local tutoring on carbs?
anyone well-versed in the carb (& local to Fairfield/Vacaville, CA 94533) have some time and up for local tutoring? I can pay for your time if reasonable.
I've taken care of some of the basic maintenance (eg: spark plugs, oil/filter, inline fuel filter, etc), by watching YT vids and reading docs/forums online. Lots of great info I have an '03 250 and is my first bike with a carb. I thought it be a good idea to have someone school me on carbs; maybe at a minimum do a removal/cleaning/re-install/test? I'm also up for me removing the carb and coming to you (within ~30 miles from 94533). I have tools; I just need someone's experience and brain Let me know time-availability and rate, if interested. Thanks in advance. ~D |
January 26th, 2018, 01:40 PM | #2 |
Hi, I'm just 15-minutes south of you and can help you with basic carb work.
What kind of issues are you having with carbs? Cold start & choke problems? Stumbling at partial-throttle? Stumbling at full-throttle? |
January 26th, 2018, 01:46 PM | #3 | |
no issues with the bike; it runs pretty solidly. my request is more for a preventative-/maintenance session, more so than a troubleshooting session. |
January 26th, 2018, 02:02 PM | #4 |
Ok, we can do basic maintenance. Perhaps you can order a carb-rebuild kit first, and then we clean and install:
- carb-removal (should separate battery-box to make future-removal easier) - carb-disassembly - jets removal - soaking/cleaning of carb pieces - float-bowl seal replacement - float-valve replacement - float-height measuring & adjustment if neceesary - vacuum-hose replacement - carb re-install I leave anything out? |
January 26th, 2018, 02:14 PM | #5 | |
any recommendations on which rebuild kit to order and from where? |
January 26th, 2018, 03:08 PM | #6 |
If things are working, no need to replace much more than rubber parts. Here's basic rebuild kit on ebay: https://www.ebay.com/itm/222262539152
January 26th, 2018, 03:28 PM | #7 | |
Bill
Insanity: doing the same thing over and over again expecting different results each time. |
January 26th, 2018, 03:49 PM | #8 |
January 26th, 2018, 03:54 PM | #9 | |
January 26th, 2018, 04:42 PM | #10 | |
In the You Tube search box type in "Simple Way to Remove the Carburetors on a Ninja 250 Pregen" Bill
January 27th, 2018, 10:03 AM | #11 |
You should look up The Vintage Monkey in Sac. I know they are doing a class on carbs. Plus is a really cool place to visit
January 27th, 2018, 11:51 AM | #12 |
Thanks Cody. Looks like they don't have any future carb classes posted yet. I wonder how often they offer these classes. I'll keep checking their site. Thanks again.
January 27th, 2018, 11:52 AM | #13 |
January 27th, 2018, 11:52 AM | #14 |
Thanks Bill. I was able to watch the vid. Good stuff.
February 28th, 2018, 07:45 PM | #15 |
Join Date: Feb 2018 Motorcycle(s): 2004 Kawasaki Ninja EX250F Posts: 1
a better way to remove carbs
guys, check this one out. i just did it this way and it took all of 10 minutes flat.
https://youtu.be/s86bimD4ft0 |
February 28th, 2018, 09:23 PM | #16 | |
A little help with my carbs? | soonerbillz | 1986 - 2007 Ninja 250R Tech Talk | 3 | August 28th, 2014 07:29 AM |
My Local Track | oblivion007 | Videos | 3 | July 28th, 2013 01:43 PM |
Local cruise. | Sipper' | Ride Reports | 1 | January 26th, 2013 12:56 PM |
Saw this on my local CL | cerberusrex25 | General Motorcycling Discussion | 27 | January 6th, 2012 08:43 PM |
local riders | stroked59 | General Motorcycling Discussion | 4 | December 30th, 2008 09:45 PM |
