Old August 26th, 2014, 07:56 AM   #1
soonerbillz
Motorcycle(s): 2003 Ex250
A little help with my carbs?
During a competition I started having a problem with the bike dying coming out of the corners going into the straights.. I mean it sounded like the bike was only running on one lung.. and the other was not working well too. Around 4-5-6K rpm the bike just shut down.. I would keep the throttle pinned and as I came up on speed a little finally the bike acted like someone flipped a switch.. and at around 7-8 K it would come back strong as hell and rev right up to the limit.. 13-14 and sound very good..
Go into a corner and at low rpm's it was like all was good.. hit a straight, roll on the gas and ...dead again.. get up in speed and it would take off! Very frustrating..
Any ideas?
Thanks
Soonerbillz - Soonerbillz Racing News - Soonerbillz Trading Post
soonerbillz is offline   Reply With Quote
Old August 26th, 2014, 08:08 AM   #2
cuong-nutz
cuong-nutz's Avatar
Check for loose battery connections, igniters, grounds. Perhaps vacuum leaks.
HalfFast Racing Team
Old August 26th, 2014, 08:35 AM   #3
soonerbillz
Yeah I went through all those common things except the coils... I get a big fat blue spark when I turn the bike over but have no way of knowing what they are doing at speed. I have the carbs at 112 mains.. 40 needle jet and right now have 2 washers on the needle. Best idle mix settings seem to be around 3 out.
It is running a little rich but really not bad from the plugs.. I am going to pull the carbs and see what is going on inside! The tank had rust originally... maybe something got through the filter....
Old August 28th, 2014, 07:29 AM   #4
agentbad
agentbad's Avatar
Maybe run it without the filter?
08 carbs on 07 sigma44 1986 - 2007 Ninja 250R Tech Talk 10 January 26th, 2015 10:05 AM
Need 08+ Carbs Donnyd21 Items Wanted 2 September 19th, 2014 04:38 PM
08+ carbs cuong-nutz Items Wanted 1 August 12th, 2013 10:53 PM
CR Carbs Jiggles 2008 - 2012 Ninja 250R Tech Talk 36 November 27th, 2012 12:50 PM
Carbs choneofakind Motorcycle-related 0 October 30th, 2011 05:39 PM
