March 29th, 2016, 03:21 PM | #1 |
[motorcycle.com] - 2016 Yamaha FJR1300ES Video Review
For 2016, Yamaha upgraded the popular FJR1300ES and FJR1300A with a significant internal change while leaving the rest of the motorcycle what on the surface seems basically the same. To discern the 2016 model from the 2015 at a distance, just go by the Cobalt Blue color instead of the Candy Red. You probably won’t be pick out the cornering lights or the LED lights all around – well, maybe the restyled brake light. Oh yeah, or the blindingly bright LED high beam until after dark. What stands front-and-center in the FJR update list is the new 6-speed transmission. This long requested change to the engine was no simple feat. Typically, adding a cog to a gearbox requires new, wider engine cases. However, that would have compromised the FJR’s ground clearance and added additional weight – two things it does not need. So, Yamaha’s engineers were challenged with the task of adding sixth-gear in the same cases. In the process, those smart folks also tightened up the gap between the gears. The result is a remarkable refinement to an established sport-touring motorcycle. In addition to the 6-speed, the FJR1300A gets new KYB suspenders front and rear to bring its handling closer to that of the ES model and its electronically adjustable suspension. All the details are outlined in our full test of the 2016 Yamaha FJR1300ES/A, and now you get the chance to view our video review below. Get the Flash Player to see this player. 2016 Yamaha FJR1300ES Video Review appeared first on Motorcycle.com. Click here for full story...
[motorcyclistonline] - First Ride Review: 2016 Yamaha FJR1300ES | Ninjette Newsbot | Motorcycling News | 0 | March 22nd, 2016 02:10 PM |
[motorcycle.com] - 2016 Yamaha FJR1300A and FJR1300ES Review | Ninjette Newsbot | Motorcycling News | 0 | March 18th, 2016 03:30 PM |
[motorcycledaily.com] - Yamaha Refines FJR1300A and FJR1300ES for 2016 (Bike Reports) | Ninjette Newsbot | Motorcycling News | 0 | November 30th, 2015 11:21 AM |
[motorcycle.com] - 2016 Yamaha FJR1300A and FJR1300ES First Look | Ninjette Newsbot | Motorcycling News | 0 | November 30th, 2015 10:20 AM |
[motorcycle.com] - 2014 Yamaha FJR1300ES Review + Video | Ninjette Newsbot | Motorcycling News | 0 | March 28th, 2014 03:50 PM |
