Old August 6th, 2015, 10:47 PM   #6761
johnydecali
johnydecali's Avatar
Motorcycle(s): '12 Ninja 250r
Originally Posted by cbinker View Post
Put the stock 14 tooth front sprocket back on and added a 44 tooth rear, just need to finish the painting and the bike is ready for racing!
Pretty! I was thinking about getting a red one but couldn't find a red sprocket made with steel, my bike is my main mode of transportation and aluminum wouldn't last long enough. Anyway I'm happy with what I got and keeping the aesthetics of the bike simple.
I'm not imperfect. However my imperfections are what creates my value and makes me unique - johnydecali
johnydecali is offline   Reply With Quote
Old August 7th, 2015, 05:22 AM   #6762
cbinker
Track Clown
cbinker's Avatar
MOTM - Sep '15
This is my first aluminum sprocket, but then again, it is a 250 and not putting out much power so the sprocket should last fine.
TEAM ALFALFA
www.apexassassins.com
Old August 8th, 2015, 11:21 AM   #6763
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Looks good! You'll be fine. Rear sprocket teeth take approximately one third the load of those experienced by the front sprocket (exact ratio dependent upon numbers of teeth, of course). Now your front and rear sprockets should wear out in tandem.
Old August 9th, 2015, 10:26 AM   #6764
Ghostt
Ghostt's Avatar
Originally Posted by Ghostt View Post
Valve adjustment complete, and if your gonna keep your Ninjette for awhile, I strongly recommend the valve tool from Kawasaki. All the exhaust valves were too tight, but all the intake valves except 1 was okay.
Still more to do, next up new chain and sprockets.
Installed the ZX coils plugs, blog post: Kawasaki ZX Ignition Coil Pack modification. silicone hose kit for coolant system, drilled 3, 1/16" holes in thermostat to allow a little more coolant flow.
violente et ignorantia
ZX-2R BLOG
Last futzed with by Ghostt; August 9th, 2015 at 10:32 PM.
Old August 11th, 2015, 12:13 PM   #6765
Road Dawg1
Motorcycle(s): 04 Ninja 250
Pulled her out, notice oil cap very loose (tightened), and went for an easy 35 miles of exploring my area.
Rever (rever.co) has an interesting new bike app and they are giving away $10 for riding 200 miles or $100 for documenting 500 miles in their new app. I've installed the app and signed up for the challenge on their website.
Small potatoes for many of you guys, but a nice step up in mileage for me.
Road Dawg1 is offline   Reply With Quote
Old August 11th, 2015, 03:57 PM   #6766
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
Went for a ride and around the time i turned to go home the back end started to act really weird and squirrely like the rear end was going to kick out, so i high tailed back home and switched rear wheels in hopes it was just a bad wheel bearing. Just as i lift the bike up on the stand you could move the wheel from side to side from the bad bearing on the brake side crapping out, thankfully i had another wheel with tire on it all aired up and ready to roll.
Now it's time to get some new wheel bearings for it.
Old August 12th, 2015, 07:46 AM   #6767
VaFish
VaFish's Avatar
MOTM - Jan '16
Went for my first ride with my 16 yo daughter. Me on the 2001 and her on the 1989. Just went around the neighborhood, down a back road to the next subdivision. Saw a little girl with a lemonade stand so we stopped to encourage her entrepreneurship.
Old August 12th, 2015, 08:19 PM   #6768
Ghostt
Ghostt's Avatar
Now that's a father and daughter moment,
ZX-2R BLOG
Old August 13th, 2015, 12:08 AM   #6769
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Oil change, grease and lube the clutch cable, top off the coolant, and went for a ride to go watch the Perseids.
<-- Linky
Old August 13th, 2015, 09:26 AM   #6770
cadymae
Cadymae
cadymae's Avatar
Baby got new shoes!
Thanks to this board I went with Bridgestone BT-45s. While there I asked about how to do the chain without a center stand. So they sold me a used lift and ordered the (nuts, brackets, spool-thingy's?) that it grabs on to lift the bike with. Gosh I am so not a wrencher! I was married last time I owned a motorcycle. It is amazing how much he did behind the scenes so that I could just hop on a ride.
Anyway!!!! Knowledge is power and the folks at Moramoto are absolutely awesome. They have been very kind and helpful getting me on my beautiful little steed.
The attached picture was my baby yesterday morning as the sun came up. I'll take another picture with the new Bridgestones on shortly.
BTW, I went with an ogio tankbag to hold my raingear and spare flip-phone. and I bought a steel cable to add to the kryptonite lock. I run the lock through the d-ring on the tank bag and run the cable through the back tire. You can see the cable and D-lock on the back seat. I put a plastic bag over the tank bag and I leave it like that in the work parking lot through all the Florida sun-showers during the day. So far the set up is working out pretty good.
I had her on the highway for the first time this morning as well.
I am SO SO SO HAPPY to be riding again. That was a looooooooooong 6 years without a bike.
And it is true: "It is just like riding a bike." I was worried I'd forgotten how to ride but all my instincts seem to still be there. My hands and feet and eyeballs picked it all right back up. I was doing head-checks again before I even remembered to be doing head-checks.
Whew!
The only thing I wish I had now was a large sign to hold up for people who seem unable to shut up about my nasty accident. "NO **** ASSHOLES! I remember better than you how many surgeries that was. I'd have been dead if I'd hit her in my truck. The bike actually saved me."
But there is no convincing them of that. So pardon my cursing but WOW I wish people would STFU about how risky riding a bike is while they are over-eating and smoking their cigarettes and screwing hookers behind their wife's back. Pick your poison is my only reply to them because no one gets out of life alive and dying at 95 in a wheelchair ain't all THAT grand.
OK. Enough complaining about idiots! Back to smiling about riding again.
Ride safe everyone!!!
File Type: jpg 11846516_1631135503829771_6792114613965352088_n.jpg (251.2 KB, 3 views)
cadymae is offline   Reply With Quote
Old August 13th, 2015, 10:04 AM   #6771
NGagne
NGagne's Avatar
Motorcycle(s): 2 Ninja 250r, Tl1000s and ZX7r
Today, I Swap the rear shock...
The old one was leaking...
NGagne is offline   Reply With Quote
Old August 15th, 2015, 02:24 PM   #6772
VaFish
VaFish's Avatar
MOTM - Jan '16
Replaced a rear valve stem that broke as I put air in the tire.
Old August 15th, 2015, 11:30 PM   #6773
NevadaWolf
NevadaWolf's Avatar
I was informed today I was smoking on my down shifts and "smelled bad".'
Joyous....
*adds to list of stuff to do on the big tear down/learning session coming up*
<-- Linky
Old August 15th, 2015, 11:37 PM   #6774
Ghostt
Ghostt's Avatar
Joyous....
bad seals/guides
ZX-2R BLOG
Old August 15th, 2015, 11:43 PM   #6775
NevadaWolf
NevadaWolf's Avatar
Yep, that's the going theory from a couple sources. My friend who's going to help me wants to do a compression check/test/thingy(?) and has since I recruited his help for this task. When I reported the smoke, now he really wants to do it.
Hope I am relaying that right. Still a "magic box" to me.
<-- Linky
Old August 15th, 2015, 11:51 PM   #6776
Ghostt
Ghostt's Avatar
Oil smoke during acceleration is rings, deceleration is valve seals and/or guides.
Personally find another low mileage complete running engine, and just swap it out.
ZX-2R BLOG
Old August 16th, 2015, 12:14 AM   #6777
NevadaWolf
NevadaWolf's Avatar
Ahh thank you. Guy behind me specifically said it was when I was downshifting.
And no, I want 100k out of this thing!
<-- Linky
Old August 16th, 2015, 12:21 AM   #6778
Ghostt
Ghostt's Avatar
A little smoke is okay, nothing to worry about IMHO.
One must keep in mind a lot of other variables could cause it, oil type, weight etc..... And let's not forget that the Ninjette is a beginner bike, so maybe Kawasaki were a little sloppy when they assembled the engine, it's not a H2
ZX-2R BLOG
Old August 16th, 2015, 04:33 AM   #6779
Hey if you end up doing valve seals, I modded a Spark plug socket to use with a C clamp in order to compress the valve springs and still get the keepers out. Let me know if you want to borrow it. Just send it back when you're done.
Old August 16th, 2015, 06:51 AM   #6780
NevadaWolf
NevadaWolf's Avatar
You guys are awesome, thank you.
When my buddy and I start work, I'm sure my post count is going to soar as I document this process. Ninjette has turned into my maintenance log book.
@choneofakind Gracias! I'll let you know!
<-- Linky
Old August 16th, 2015, 09:22 AM   #6781
dcj13
Participant
dcj13's Avatar
What do you have on the bike? Around 90K miles? Shouldn't need a rebuild yet!
I'd try a little heavier oil before messing with rings, seals, etc. Perhaps 20W50 is in order for the next oil change. Especially for hard use in a warm climate.
Old August 16th, 2015, 09:25 AM   #6782
dcj13
Participant
dcj13's Avatar
What is your oil consumption rate per 1000 miles?
Old August 16th, 2015, 07:20 PM   #6783
NevadaWolf
NevadaWolf's Avatar
I don't think it needs a rebuild (unless that's the point of checking seals?) I just need to sit down and learn how to do things like valve adjustments and whatever else the manual calls for.
Um, it's been going down just "a splash" in between oil changes every 5k. barely pour any in and the level goes back up to the top mark on the window.
<-- Linky
Old August 16th, 2015, 07:28 PM   #6784
Ghostt
Ghostt's Avatar
Personally I wouldn't worry about it, valve adjustment makes all the difference.
I did mine and all the exhaust values were tight, but intake was fine except for one.
Bike runs like new again for sure.
ZX-2R BLOG
Old August 16th, 2015, 08:05 PM   #6785
dcj13
Participant
dcj13's Avatar
For measuring and adjusting valve clearances, the engine should be stone-cold.
For checking compression, the engine should be fully warmed up.
So eight ounces or so of oil use in 5k miles? Definitely not a problem!
Thanks for sharing the data.
Old August 16th, 2015, 08:14 PM   #6786
^^^^^ lol, even mine wasn't super bad. 1/4 quart in 3500 miles. Just enough to take the sight glass from high to low between changes. But it bothered me so I did new seals and rings. No more oil burn!
My only question is if her oily cloud and smell is on decel after downshifting or on the initial blip to rev match for downshifting? I don't know if that was mentioned.
Old August 16th, 2015, 08:28 PM   #6787
dcj13
Participant
dcj13's Avatar
A quarter of a quart of oil is what? One dollar? Maybe two bucks if one uses gee-whiz special oil? And a person rides maybe 7500 miles per year? (20k miles for 'Wolf).
You decided to rebuild an engine to save $2 to $4 per year? That doesn't make any sense.
It was a guy who reported on the smell. Guys aren't known for their keen olfactory sense. A quarter of a quart of oil use in 5k miles is in the noise: insignificant. Any smoke or smell is probably due to fueling. And it's still insignificant. A non-problem.
Old August 17th, 2015, 01:43 AM   #6788
Flying
Motorcycle(s): 2010 Ninja 250
Probably was a "while you're in there" occurrence. I would like to think chone is brighter than that.
Old August 17th, 2015, 02:09 AM   #6789
Lol I also had a whole shop and help and equipment at my disposal and did way more to the bike than just rings and seals. Thermobob, blasted and painted and serviced everything Id been putting off servicing and had wanted to refinish, new bixenon headlight setup that I still haven't finished my lens on, etc. It was a winter project for the sake of tinkering while it was not riding weather. Plus I learned a lot. I remember we had this discussion before and I don't regret anything I did
That nasty gray cloud of smoke at startup was annoying too.
Did I mention we spent most of jan and feb around 10 degrees and it rained all of May and june? Literally all of it.
Old August 17th, 2015, 08:27 AM   #6790
The Red Scourge
The Red Scourge's Avatar
Motorcycle(s): '76 Yamaha RD400, '71 Kawasaki G3SS, '88 Honda CBR400RR, '90 Yamaha FZR400/600 hybrid
Who needs a Corbin seat when you have a throw pillow and duct tape?
I had to ride to Atlanta and back the other day. 200 miles each way. I went to a show and my truck's fuel pump died. The damn thing worked wonders! I'd do it again if I had to!
"When in doubt, gas it!"
The Red Scourge is offline   Reply With Quote
Old August 21st, 2015, 12:45 AM   #6791
Ghostt
Ghostt's Avatar
I've just rolled over 7k miles(34k total) I've put on SERENITY since I purchased her last spring, it's been great.
After a nice long ride today, after I did the valve adjustment, I noticed an oil leak coming from the valve cover, so I double check the 4 bolts, all is good.
So I'm guessing the rubber gasket is no longer good. So do I purchase a new one along with the other ones for the valve cover, or be cheap and use some RTV on the old dried out rubber gasket?
And for @The Red Scourge try this next time., or try what I did https://www.ninjette.org/forums/blog.php?b=8352
ZX-2R BLOG
Old August 21st, 2015, 02:15 AM   #6792
Be cheap and use really nice RTV on the old gasket, that's what I did
Remember the other thread where I suggested Threebond 1215 solvent-less gasket maker?
Old August 21st, 2015, 08:51 AM   #6793
Ghostt
Ghostt's Avatar
My thoughts exactly, and yes I do remember, Thxs
ZX-2R BLOG
Old August 22nd, 2015, 02:28 AM   #6794
johnydecali
Went riding through Marin County yesterday... Friend lowsided and luckily walked away with just a few scratches his R3 will need new fairings though....
Short highlight Instagram video from the ride here.
Old August 22nd, 2015, 02:35 AM   #6795
Ghostt
Ghostt's Avatar
That suxs, but as Chuck Yeager would say "ANY LANDING YOU WALK AWAY FROM IS A GOOD LANDING" glad your friend is okay, hope he was wearing his gear.
ZX-2R BLOG
Old August 23rd, 2015, 02:07 AM   #6796
johnydecali
That he was, AGATT. Thanks
Old August 23rd, 2015, 02:26 AM   #6797
johnydecali
Finally made time to put on the new chain and rear sprocket (14/42), plus a custom machined kickstand... Sadly the kickstand had the wrong angle that made the bike lean way to much to the left and had to put back the old kickstand
Old August 24th, 2015, 04:19 PM   #6798
pigp3n
Motorcycle(s): pregen
yesterday, stripped a pre-gen down to turn into streetfighter. re routed and moved wiring. Ordered the headlight for it.
pigp3n is offline   Reply With Quote
Old August 25th, 2015, 10:59 AM   #6799
cuong-nutz
cuong-nutz's Avatar
Passed the point of no return.
HalfFast Racing Team
Old August 25th, 2015, 09:56 PM   #6800
superflytako
superflytako's Avatar
Motorcycle(s): 2014 Ninja 300 ABS, 2013 Ninja 300 ABS (RIP), 2015 FZ-09 (sold)
Put on some new shoes, Pilot Street Radials - they feel better over stock and spent an hour or so in a parking lot practicing.
superflytako is offline   Reply With Quote
Discovered something scary about my Ninjette today... kjohng General Motorcycling Discussion 28 October 15th, 2021 01:40 PM
Sold the 2006 Ninjette today :( Renner General Motorcycling Discussion 31 October 16th, 2014 11:46 PM
Today I Gave My Ninjette Wings! BlueHairSar Pictures 5 June 20th, 2013 07:38 AM
my bro went down today on his ninjette richierich781 !%@*#$%!)@#&!%@ I crashed! 46 January 18th, 2013 11:59 AM
Ninjette. org hacked today CC Cowboy Off-Topic 9 April 3rd, 2011 08:55 AM
