Old April 5th, 2024, 12:47 PM   #1
unionjack
Motorcycle(s): ninja ex250f
sparks sometimes and has weak spark (solved)
so i fixed the issue regarding it not having any spark at all, replaced the pulsar coil but now its pointed out another issue both plugs and ignition coils will spark but only sometimes and it appears to be pretty weak, does this point towards faulty ignition coils or something else i should be looking for?
editproblem solved by replacing the ignition coils)
Last futzed with by unionjack; April 20th, 2024 at 07:17 AM.
unionjack is offline   Reply With Quote
Old April 5th, 2024, 01:52 PM   #2
What is the battery voltage while you're cranking? My guess is it's dropping a lot under load.
Old April 5th, 2024, 02:16 PM   #3
unionjack
i charged it up to about 12.3 volts but wouldn t be suprised if it was dropping after some cranks its a fairly new battery
Old April 5th, 2024, 07:32 PM   #4
I'm asking what the battery voltage is during cranking. That can tell us if your weak spark is due to low voltage.
Old April 6th, 2024, 04:49 AM   #5
unionjack
i can absolutely check that I haven't actually tried that yet, I took off the ignition coils and found that the "intermittent" ness possibly could be because the contacts in the wire is pretty messed up and would only read with a multimeter in certain positions and on top of that the resistance of the primary windings was way off, ordered 2 oem replacements off ebay, ill check the voltage while cranking today though
Old April 6th, 2024, 12:44 PM   #6
unionjack
it drops to around 11v
resistance on primary windings of ignition coils is 5.5 ohms
Old April 6th, 2024, 02:17 PM   #7
Edit: deleted wrong information!
Last futzed with by Triple Jim; April 6th, 2024 at 03:43 PM.
Old April 6th, 2024, 03:06 PM   #8
unionjack
11v is not bad for a during-cranking reading. I hope you mean the ignition coil secondaries read 5.5 ohms.
as far as I got in the manual I was sent on this forum my primaries read 5.5 as in the two standoff posts being connected by a multimeter not to the actual spark cable
Old April 6th, 2024, 03:44 PM   #9
Sorry, I had a brain fart! You're right. I'll fix the post for future searchers. I had tube amplifier output transformers on my mind.
I was the one who posted the manual supplement for you.
Old April 6th, 2024, 05:36 PM   #10
unionjack
your all good lol I was super confused, it was out of wack as far as the manual readings so I have two oem ones getting here Tuesday but have just continued testing and working on this big puzzle regardless
Old April 8th, 2024, 01:05 PM   #11
unionjack
just replaced the ignition coils, solved the issue have strong spark all the way up to the actual plugs now
Old April 8th, 2024, 01:12 PM   #12
I wonder if they were stock coils that gave you trouble. I don't hear about coil failures here.
Old April 8th, 2024, 04:03 PM   #13
unionjack
so the actual coils themselves looked identical same branding and all HOWEVER the actual spark plug wire looked like a replacement, even the rubber gasket piece that covers up the head didn't really fit or cover right and could be popped off of the wire very easily, so my guess is probably stock coil, ghetto repair job on the actual wires
Bike seems weak. corksil General Motorcycling Discussion 9 March 30th, 2016 10:11 PM
Weak Vacuum ans008 2008 - 2012 Ninja 250R Tech Talk 3 November 20th, 2013 01:17 PM
Removing spark spark plugs? tsdexter 2008 - 2012 Ninja 250R Tech Talk 3 June 26th, 2013 03:48 PM
I'm Weak.... onetruevibe Off-Topic 32 June 17th, 2011 08:48 PM
Gas Tank, is it this weak? Betlog 2008 - 2012 Ninja 250R Tech Talk 5 January 16th, 2010 03:55 PM
