Old April 11th, 2009, 09:59 PM   #1
kylerwhite
2008 Kawasaki Ninja 250R
kylerwhite's Avatar
Motorcycle(s): 08 Ninja 250R
LED footpeg brackets (work in progress)
After seeing Freyedchicken's footpeg brackets i decided i'd make my own. I ordered some 3mm LED's of ebay and started drilling some holes. That was the easy part! Soldering all the tiny wires together is a PITA. Anyways here are some pictures of what i've done so far.
I have a couple lights that aren't working that i'll have to fix but once i install the brackets on the bike i'll post more pictures.
kylerwhite is offline   Reply With Quote
Old April 11th, 2009, 10:05 PM   #2
miks
I'm lovin' it.
miks's Avatar
Motorcycle(s): '09 Black 250R
Wow, very nice job. Can't wait for some pictures of the finished product.
miks is offline   Reply With Quote
Old April 11th, 2009, 11:04 PM   #3
VeX
That's me!
VeX's Avatar
Motorcycle(s): 2008 Ninja 250r (Tis blue), 2008 CBR600RR
One thing I did on the backside was filled the backside of the peg mount with silicone. It covers up the LED leads and wiring. Plus if you use black silicone it looks really smooth.
VeX is offline   Reply With Quote
Old April 12th, 2009, 01:24 AM   #4
ak_907_ak
I approve!
'08 Ninja 250R: Yoshi Full System, HID's, FP Jet Kit, Snorkel removed, LED Brakelight, LED Footpeg Turnsignals, Zero Gravity SR Windscreen, Fender Eliminator, Solo Seat Cowl, Woodcraft Clip-Ons
ak_907_ak is offline   Reply With Quote
Old April 12th, 2009, 05:25 AM   #5
NickH
NickH's Avatar
Motorcycle(s): 2009 Buell XB12Scg and 2009 Kawasaki Ninja 250R
Looks good so far.....are these used for turn signals or brake lights?
-Nick-
Posted via Mobile Device
NickH is offline   Reply With Quote
Old April 12th, 2009, 05:55 AM   #6
randomwalk101
self wrencher
randomwalk101's Avatar
you could have the leds in series and use one resistor for that...put each series of leds in parallel to have less wiring...really clean up your circuit...
overall not bad result.
Old April 12th, 2009, 10:13 AM   #7
Snake
Snake's Avatar
Wow that looks great! I can't wait to see it mounted on the bike.
Old April 12th, 2009, 11:08 AM   #8
Sloppy2nds
just a n00b
Sloppy2nds's Avatar
Motorcycle(s): '06 R6/'08 250R
Looks good man.
Sloppy2nds is offline   Reply With Quote
Old April 12th, 2009, 01:47 PM   #9
Rynownd
Rynownd's Avatar
Nicely done!
I almost sent my brackets to freyedchicken to have this done.
http://www.southparkstudios.com/clips/224099
Rynownd is offline   Reply With Quote
Old April 12th, 2009, 08:02 PM   #10
kylerwhite
kylerwhite's Avatar
I planned on filling it with some epoxy but i like the sound of black silicone.
-Nick-
Yes they will be turn signals on the sides and brake lights in the rear. There is a video somewhere on youtube of someones completed brackets on the bike. I'll see if i can find it and i'll link or post it up.
Thanks eveyone for the comments. i hope to have them installed on the bike within the next week. check back soon for more pics
Old April 13th, 2009, 06:45 PM   #11
randomwalk101
self wrencher
i wanna play...done it about 6 months ago
Old April 13th, 2009, 06:48 PM   #12
Snake
Snake's Avatar
Wow looks very cool.
Old April 13th, 2009, 08:01 PM   #13
miks
I'm lovin' it.
miks's Avatar
Those look great, does yours act like a tail light or also like a brake light?
Son: When I grow up I want to ride a motorbike.
Father: You can't do both son.
Old April 13th, 2009, 11:28 PM   #14
VeX
That's me!
VeX's Avatar
The resistors are really small and with shrink-tubing over the soldered leads and resistor they're basically invisible. It's always wiser to run LED's in parallel as if any of the LED's burn out or a solder connection breaks loose you don't lose the whole circuit.
They're tiiiiny
Shrink tubed up...
That and if you're wiring up a bunch of LED's in series you have to pay special attention that you're wiring them in the correct direction. If you have one LED flipped backwards (which is easy to do as after you trim the leads it's tricky to distinguish the negative and positive sides). That and with a lot of LED's you start to require running multiple series IN parallel which really complicates things further I just don't believe in running LED's in series unless it's only a very few and there are issues like space to worry about.
Old April 13th, 2009, 11:35 PM   #15
VeX
That's me!
VeX's Avatar
Furthermore here's a good example of why I believe in running LED's in parallel:
Notice in the 2nd from the left row about 2/3 of the way up? There is ONE LED that had a bad solder connection (not bad out of 50 or so LED's). If I did wiring in series I would've had a bank of 5-6 LED's (not too bad, but still a PITA to locate the right one) that would all be out. If it was a bad LED and not just a bad connection then it'd be even MORE difficult to diagnose. I was able to find that one LED as it was the only one not illuminated and within 10 minutes:
They're all lit
Old April 14th, 2009, 11:38 AM   #16
tinng321
tinng321's Avatar
Motorcycle(s): 08 black 250r (sold); '09 black zx6r
what's the purpose of the resistors?
tinng321 is offline   Reply With Quote
Old April 14th, 2009, 01:25 PM   #17
Viper-Byte
Viper-Byte's Avatar
Motorcycle(s): 08 Ninja 250R in Green! (Sold) Now 2011 Triumph Daytona 675 SE
To reduce the amount of current going through the LEDs, if they have too much current, then they will burn out, OTOH the more current they have the brighter the LEDs, so really it is a trade off on the life and how bright you want them. Though if you keep the current within the specs of the LED it will last a very long time.
2008 GREEN Kawasaki Ninja 250R.
AreaP Quiet Core Carbon Fibre : 8000k HIDs : Dynojet Jet kit : Double Bubble Windscreen
Viper-Byte is offline   Reply With Quote
Old April 20th, 2009, 07:08 PM   #18
kelly06
kelly06's Avatar
Motorcycle(s): 2009 Ninja 250
i wish i could do this i think after i get some money im going to get Freyedchicken to do this to mine
kelly06 is offline   Reply With Quote
Old April 20th, 2009, 09:48 PM   #19
andrewwoo
WHEE!
Motorcycle(s): 2009 Black Kawi 250R
ooo man that is sick!!! i want that mod... but different setup..
andrewwoo is offline   Reply With Quote
Old April 20th, 2009, 10:24 PM   #20
kylerwhite
kylerwhite's Avatar
It isn't that expensive to do it yourself but it is very time consuming. If you don't know much about wiring then i suggest you do buy a set from Freyedchicken.
Still working on the wiring and i'm hoping to have everything finished up in the next couple days.
Old May 8th, 2013, 06:16 PM   #21
kirk595x
kirk595x's Avatar
Motorcycle(s): 03' Ninja 250ex
Looks awesome man!!
kirk595x is offline   Reply With Quote
Old May 14th, 2013, 10:31 AM   #22
broilmebk
broilmebk's Avatar
Motorcycle(s): '12 ninja 250r
Wow, what a thread revival. Is the OP even around anymore? Pics of finished product?
broilmebk is offline   Reply With Quote
Old May 20th, 2013, 12:31 AM   #23
Old May 30th, 2013, 12:08 AM   #24
teejay
teejay's Avatar
Motorcycle(s): 2009 Kawasaki 250R SE
Looks awesome! Congrats on a job well done!
Project Time...
2009 Kawasaki 250R SE Street-Fighter
*PHASE 1* - Planning (And fixing a bunged wiring harness)
teejay is offline   Reply With Quote
My Ninja Cafe...work in progress Ivanrules 2008 - 2012 Ninja 250R Farkles 208 July 25th, 2017 01:16 PM
A work in progress - and a question liquidnine 1986 - 2007 Ninja 250R Farkles 7 January 28th, 2015 03:39 PM
Work in progress auntymunga Pictures 33 May 13th, 2014 12:57 PM
My work in progress Cochese 2008 - 2012 Ninja 250R Tech Talk 34 May 30th, 2009 06:44 PM
LED footpeg brackets ak_907_ak 2008 - 2012 Ninja 250R Farkles 5 January 8th, 2009 09:07 AM
