Old September 10th, 2015, 07:39 PM   #1
nikeeric86
nikeeric86's Avatar
Motorcycle(s): 1992 fzr600 2010 ninja 250 2006 cbr600rr
Fork oil
Found that my left fork seal is leaking after low siding and decided it was a good time to upgrade the front suspension. I ordered .75 race tech springs along with new seals and bushings but don't know what weight/brand/ fork oil to pair it with and a good starting oil level? I'm 145-150lbs no gear, track only.
nikeeric86 is offline   Reply With Quote
Old September 10th, 2015, 08:32 PM   #2
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Check the "similar threads" entries listed below these two postings.
If it were me, I'd go for a 10 or 15 weight fork oil.
Old September 11th, 2015, 04:34 AM   #3
Ghostt
Ghostt's Avatar
If your looking for better dampening, I'd go with Ricor INTIMINATORs
http://store.ricorshocks.com/product...20-1001nin.htm
If those are not within your budget, the I'd start with 15w synthetic fork oil, and work from there.
Torco T830015CE RFF 15 Racing Fork Fluid Bottle - 1 Liter https://www.amazon.com/dp/B000WMO6NS..._XVR8vbW6QHAPV
violente et ignorantia
ZX-2R BLOG
Old September 11th, 2015, 01:52 PM   #4
fred smoot
fred smoot's Avatar
Motorcycle(s): 1996 Ducati 900SS/SP 45k miles
fork oil . . .
Factory specs call for 10 weight oil & 106-110mm from the top of the oil to the top of the fork tube, with the fork compressed, no spring. If you are not comfortable with doing the work yourself, get experienced help.
Fred
'09 Ninja 250R track only SOLD
"If everything seems under control, you're not going fast enough." -Mario Andretti
fred smoot is offline   Reply With Quote
Old September 12th, 2015, 10:13 AM   #5
abhijitz
Motorcycle(s): Many Two Wheels ..
If you are not installing any emulators, you could use 12.5W or 15W at stock air gap. I use Maxima Racing (Blue Bottle) OR Torco. Honestly, BelRay/Maxima/Torco are all good brands.
[ex-AFM #828 | SMUSA #828 |
Sponsors : MotionPro | LeoVince | Insurrection Racing Gloves | QstarZ Laptimers
+ OEM Parts @ 30-40% OFF : Harry @ 1-877-437-1631,17 harry@hondaeasttoledo.com
abhijitz is offline   Reply With Quote
Old September 12th, 2015, 03:36 PM   #6
nikeeric86
nikeeric86's Avatar
i bought 10w and 15w and plan to mix it.
Old September 12th, 2015, 03:47 PM   #7
dcj13
Participant
dcj13's Avatar
I like the way you think! Plus you'll have enough oil to do the fork again in a few years (or do another bike...).
Old September 12th, 2015, 04:07 PM   #8
nikeeric86
nikeeric86's Avatar
can i put the excess in the rear so the damping is matching front and back?
Old September 12th, 2015, 04:48 PM   #9
dcj13
Participant
dcj13's Avatar
Ha! That's a good one.
Old September 30th, 2015, 12:25 PM   #10
APEmike
Motorcycle(s): 2014 Ninja 300
do these intiminatorthingamabobs fit the 300?
Old September 30th, 2015, 05:13 PM   #11
Ghostt
Ghostt's Avatar
I believe so, but double check with the manufacturer.
ZX-2R BLOG
DIY- Replace fork seals, dust seals and fork oil shortstuff 2008 - 2012 Ninja 250R Tech Talk 212 November 6th, 2023 10:53 AM
Question about Fork Oil thisisbenji General Motorcycling Discussion 16 February 23rd, 2015 08:40 AM
Fork oil level Sipper' 1986 - 2007 Ninja 250R Tech Talk 1 June 25th, 2014 04:08 PM
Fork oil jconolty 2008 - 2012 Ninja 250R Tech Talk 5 April 11th, 2013 11:33 AM
Fork Oil nexus 2008 - 2012 Ninja 250R Tech Talk 2 March 20th, 2011 08:42 PM
