Old July 3rd, 2017, 04:57 PM   #1
tesla
Motorcycle(s): Ninja ex 250
Suddenly no front light.
Hi all, first of all sorry my basic english, i have a trouble with my 2012 250 ninja, since two days ago i noticed the front light isnt working, a few minutes ago i checked all the fuses and they are OK, i have all working horn, turn lights all the meters are OK, but the front light isnt working at all, the bulbs are OK what can i check ?, any ideas ?, thanks in advance. (again sorry for my english)
tesla is offline   Reply With Quote
Old July 3rd, 2017, 05:22 PM   #2
Is the engine running? I know on the pregens the headlight does not come on until the engine is running.
Old July 3rd, 2017, 05:24 PM   #3
tesla
Yes, the engine its running allways!
Old July 3rd, 2017, 05:29 PM   #4
You'll save gas if you shut it off when you're asleep at night.
All I can suggest is to use the wiring diagram to trace where the headlight power runs, and follow it with a meter or test lamp until you find where it's not getting though.
Old July 3rd, 2017, 05:46 PM   #5
tesla
Ok. i think ill do that, i think it might be the relay out of the fuse box, but i will test it.
Old July 3rd, 2017, 05:51 PM   #6
Momaru
Momaru's Avatar
Is the high-beam light working? Might give you a starting point on a shared circuit
If the high beam does work, you can doublecheck the low-beam bulb by swapping them since they are identical bulbs.
I had a low-beam blow out a while back. Bulb looked fine at a glance. Swapped them, and it wouldn't work in the high-beam. The original bulb from the high beam worked in the low beam housing, suggesting it was the low-beam bulb.
Also useful trick if your lowbeam does blow and you don't want to use your highbeam - they can be swapped on the roadside if you know what you're reaching for and have skinny arms.
Just make sure you wipe off the glass on the bulb - don't want to make hot spots with finger oil or dirt.
Proud member of the Blue Army
Old July 3rd, 2017, 06:01 PM   #7
tesla
Momaru, thanks for the answer, high-beam light isnt working, the blue light indicator of high beam working, isnt working already, i think it must be the relay there is outside of the fuse box, but im new with the bike so im not sure about that.
[motogp.com] - Iannone: “A light went on and suddenly I crashed” Ninjette Newsbot Motorcycling News 0 May 7th, 2016 11:40 AM
[motogp.com] - Viñales: “Suddenly many riders overtook me” Ninjette Newsbot Motorcycling News 0 October 27th, 2015 02:25 AM
[nytimes.com] - Suddenly, a 3-Wheel Traffic Jam Ninjette Newsbot Motorcycling News 0 November 14th, 2014 06:50 PM
Bike won't start suddenly. dsuchmiel 2008 - 2012 Ninja 250R Tech Talk 14 November 16th, 2013 03:28 PM
[crash.net - MotoGP] - Rossi: Suddenly Pedrosa was just in front! Ninjette Newsbot Motorcycling News 0 July 5th, 2009 07:50 PM
