Old June 25th, 2010, 05:52 PM   #1
gogiburn
Motorcycle(s): have 24
starting problem
2005 with 12K new to me.Won't start without pulling in clutch with it in neutral.Sprayed switch with Deoxit and pulled sidestand off and sprayed it and worked the rod in and out.Is connected electrically but still won't start in neutral without pulling in clutch
Posted via Mobile Device
gogiburn is offline   Reply With Quote
Old June 25th, 2010, 06:17 PM   #2
seis gunnar
Motorcycle(s): '09 250R SE Lime Green
It shouldn't start without the clutched pulled in. Even with the gear selector in neutral. Don't quote me on this but, until the clutch is disengaged there is still enough drag from the transmission, that the engine won't turnover.
seis gunnar is offline   Reply With Quote
Old June 25th, 2010, 06:21 PM   #3
gogiburn
My other 250 2004 and all 23 other bikes I own start in neutral without the clutch being pulled in.In fact the 2004 250 does have sticky clutch plates at times and will MOVE the bike forward even with the clutch pulled in.
Old June 25th, 2010, 07:25 PM   #4
seis gunnar
Fair enough; I guess, I've always pulled my clutch in as I was driving cars with manuals before motorcycles.
Unfortunately, that is as far as I can go with any help. Or was that help? Though I am interested in what you find out.
Old June 25th, 2010, 08:11 PM   #5
I believe that the clutch lever switch overrides all. If the clutch isn't pulled in, it won't start no matter what's happening with the other safety switches (kill switch, sidestand switch, neutral indicator).
EDIT: Nope, I was wrong. Just tested mine in the garage. If it's in neutral and the sidestand is up, my 2008 will start whether the clutch lever is pulled in or not.
Sounds like it has to be your neutral indicator being the issue. The clutch lever shouldn't matter, and if the sidestand switch was keeping it from starting, it would kill the engine as soon as you put it in gear anyway.
Old June 25th, 2010, 08:12 PM   #6
gogiburn
nope
Old June 26th, 2010, 09:22 AM   #7
gogiburn
Actually you were half right.The clutch switch was misaligned so the plunger was ALL the way out (no start) I jumped the connector and it worked so I checked the mechanical part (the plunger) and found it below the cluch lever.Once I put the plunger at the right place where the clutch lever pushed it in it worked fine with the side stand up and clutch out.Seems it has to be the right combo but the clutch switch seems to be the main key.Thanks for everyones help I now have a bike that starts when I hit the button
Old June 26th, 2010, 11:43 PM   #8
03slime250
Motorcycle(s): 2003 ninja 250
hmmm, i have to pull my clutch in sometimes to start it also
03slime250 is offline   Reply With Quote
Old June 27th, 2010, 04:34 AM   #9
gogiburn
WEll tings are still not right.Bike starts in neutral without clutch but will not start in gear with clutch pulled in??
Old June 27th, 2010, 05:05 AM   #10
Guinss
Guinss's Avatar
Motorcycle(s): 2008 250R (Black)
Is that with the side stand down?
Guinss is offline   Reply With Quote
Old June 27th, 2010, 05:08 AM   #11
gogiburn
NO,it's with the side stand up.Will stat in neutral and I will drive it a few feet and stop leave it in gear and hit starter with clutch pulled in and it will not start
Old June 27th, 2010, 05:16 AM   #12
Guinss
Guinss's Avatar
Sounds like the clutch switch isn't working then.
I assume that when you say "will not start", you mean that the starter motor wont turn over.
The talk above about sticky clutch made me a bit confused, wether you mean the start motor is turning but the bike wont start, or the start motor doesnt turn.
Old June 27th, 2010, 05:36 AM   #13
gogiburn
No starter motor at all
Old July 20th, 2010, 03:41 PM   #14
gogiburn
Ok,found out the clutch lever was bent in slightly,enough that it hit the bar before totally disengaging the clutch switch.Didn't find it till AFTER I bought a new switch.
Old July 29th, 2010, 03:24 PM   #15
I always kick up into neutral clutchlessly before I even stick in my key (safe when it's parked, right?) and then inset the key, flip my kill-switch back into the start position, and start the bike, all while I stand next to it. It remains on the kick stand and I do not have to pull in the clutch. Does everyone else warm up while sitting on the bike or something?!
Of course, mine's a J-series.
Problem starting bike soliman 2008 - 2012 Ninja 250R Tech Talk 17 October 12th, 2014 12:16 AM
Peculiar starting problem Tom504 1986 - 2007 Ninja 250R Farkles 4 November 6th, 2012 07:11 PM
starting problem b4lt1m0re 2008 - 2012 Ninja 250R Tech Talk 15 September 13th, 2012 04:03 PM
Starting Problem emoyer 1986 - 2007 Ninja 250R Tech Talk 4 July 3rd, 2012 11:00 AM
having an intermittent starting problem! davidfriend 1986 - 2007 Ninja 250R Tech Talk 8 April 18th, 2012 05:16 AM
