Old July 21st, 2010, 01:36 PM   #1
Togglehead
Motorcycle(s): 1989 Ninja 250 / 1997 Bandit 1200S
How to test coolant temp sensor?
I thought i had both the base service manual and the supplement, as thats how the files are labeled....but it turns out theyre both the supplement! Oh no!
Does anyone know the procedure for testing the temp sensor? I need proper resistance and all...
thanks in advance.
Togglehead is offline   Reply With Quote
Old July 21st, 2010, 03:50 PM   #2
HKr1
IC2(SW)
HKr1's Avatar
Testing is pretty simple. Use a pot of water on the stove, thermometer in the water, temp sender probe portion in the water. Use an ohm meter, hook onto the lug and sender body. Start heating the water....
I dont have the resistance numbers handy for the older model, Iam sure there pretty close to the new gen
122 deg F 210 Ohms
240 deg F 21 Ohms
Koso Oil Temp Sensor Adapter & Water Temp Sensor Adapter StaylorT 2008 - 2012 Ninja 250R Tech Talk 10 January 24th, 2014 12:38 AM
oil temp vs coolant temp cuong-nutz General Motorcycling Discussion 11 January 23rd, 2013 05:44 PM
WTB: Pre-Gen Water Temp Sensor!! bluebr65 Items Wanted 3 January 5th, 2012 09:45 AM
WTB 08+ Water Temp Sensor charri Items Wanted 0 July 26th, 2011 07:05 PM
Where is the water temp sensor? wild-bill 2008 - 2012 Ninja 250R Tech Talk 2 December 24th, 2010 10:32 PM
