July 25th, 2010, 08:07 AM | #1 |
Alternator output??
Need to know the output of the alternator and also the draw from the fan? See other post for farkles as I added driving lights 55Watts and rear running lights 8 watts each side and lost battery last night after a spirited high RPM ride.Rethinking the situaation last night I realize it ws 95 degrees and stopping at the light may have had the fan runniing and that drew the battery down I have a Datel volt metter on my Concours and the fan does draw quite a bit of power when on at idle.
Posted via Mobile Device |
July 25th, 2010, 10:41 PM | #2 |
Join Date: May 2009 Motorcycle(s): 2007 EX250 (street), 1994 EX250 (Race), 2008 250R (Race), 2000 250 (project), 1991 EL250 (a cruiser!) Posts: 287
There's a detailed breakdown of the output over at ninja250.org but it's about 50-60 Watts of overhead. If you're running TWO driving lights and TWO 8 Watt lights in the back then you're going to kill the battery really quick, even cruising at high RPMs.
Help!! My engine runs great but no power output! | Ebny250 | 2008 - 2012 Ninja 250R Tech Talk | 4 | October 11th, 2014 07:16 PM |
Transmission output shaft replacement | Mulholland | 1986 - 2007 Ninja 250R Tech Talk | 10 | April 12th, 2013 08:21 AM |
[topix.net] - Workers of Hero unite, Gurgaon output to take a hit | Ninjette Newsbot | Motorcycling News | 0 | January 24th, 2013 01:40 AM |
12V Socket - Max power output? | AgentX | 2008 - 2012 Ninja 250R Farkles | 15 | September 12th, 2010 07:55 PM |
[topix.net] - Toyota and Honda cut more output | Ninjette Newsbot | Motorcycling News | 0 | January 19th, 2009 04:21 AM |
