Old August 10th, 2010, 12:44 PM   #1
Slabrocks
Slabrocks's Avatar
Motorcycle(s): 01 Ninja 250
odd fuel issue
I have an 01 that I put about 1500 miles on the 1st month that I could ride this summer. All was well, no issues at all.
At some point, the fuel wasn't going into the in line fuel filter (that has the arrow pointing the right way) so when the bowls were empty it would die.
I figure, hey, I'll read the FAQ and see what I can learn. It's barely more to buy an entire new petcock than it is to rebuild the old one. The new one came in and i put it on with no issues. While it was off I decided it would be a great time to drain the fuel that was in the tank and put fresh in.
As soon as I hit the starter, the filter gushed full of fuel and it ran fine for like 2 min. Since then it hasn't run right.
The vacuum line is hooked up and the fuel line is new. Can anyone tell me what is wrong????? I'm ready to scrap the thing.
Thanks in advance.
"Helmets are like rubbers, you know you should wear one, but its so much better when you don't." Zerk from ADV
Slabrocks is offline   Reply With Quote
Old August 10th, 2010, 12:55 PM   #2
have you checked the stock filter? it's a small inline filter located at the end of the fuel line as it enters the carbs.
also, have you tried popping the gas cap when the problem arises? it could be a tank venting problem.
Old August 10th, 2010, 12:56 PM   #3
Slabrocks
Slabrocks's Avatar
I took out the stock filter when i put the big one on. I have also tried the gas cap open trick.
wanna buy a Green 01?
Old August 10th, 2010, 01:08 PM   #4
did you try running it w/o any filter in the fuel line?
Old August 10th, 2010, 01:10 PM   #5
Slabrocks
Slabrocks's Avatar
I have also bypassed the filter a few times.
Is there something vacuum based that i may be missing? when it is running if i pull the vacuum line off and put my thumb over it there is a pretty good amount of pressure.
Old August 10th, 2010, 01:20 PM   #6
the vacuum to operate the petcock comes from that hose that runs to the top of one of the crabs. You can try removing the vacuum hose from the back of the petcock, install a another hose on the there and suck on the hose. Have the end of the fuel line disconnected from the carbs and see if you can get a steady stream of gas to flow out of the fuel line. If you can then you know the petcock diaphragm is working properly.
if that checks out, check the hose that runs from the back of the petcock to the carbs... may have a slow leak/split? does the bike idle well when it runs? usually if there is a vacuum leak, it affects the idle smoothness.
if all checks out okay, you can rule out fuel delivery from tank to carbs as the problem and work from there.
Old August 10th, 2010, 01:22 PM   #7
Slabrocks
Slabrocks's Avatar
The petcock has 0 miles on it. Its new straight from Kaw.
so you are telling me to get an new vac line and pull pressure by sucking on it while the fuel line is unhooked from the petcock to make sure i get flow?
I just want to make sure i got it right.
is there something extra on the carb that does just vacuum?
Thanks for the help as usual
Old August 10th, 2010, 01:26 PM   #8
yes
nope. the carbs are it
Old August 10th, 2010, 01:28 PM   #9
Slabrocks
Slabrocks's Avatar
Im about to leave for my weekly 35 mile tuesday night bicycle ride, but I will go buy a new line in the morning and give it a try during the day tomorrow.
Old August 10th, 2010, 01:43 PM   #10
have fun... always good to leave a problem and come back to it with a fresh mind.
enjoy your ride.
Fuel gauge backlight issue botguy2185 2008 - 2012 Ninja 250R Tech Talk 3 January 3rd, 2014 07:55 AM
Fuel Petcock Issue ans008 2008 - 2012 Ninja 250R Tech Talk 6 June 7th, 2013 07:14 PM
Odd fuel observation slickt0mmy 1986 - 2007 Ninja 250R Tech Talk 3 June 6th, 2013 03:28 PM
Fuel tank venting issue bjl4776 2008 - 2012 Ninja 250R Tech Talk 6 April 15th, 2013 09:07 AM
HELP: odd fuel issue Slabrocks 1986 - 2007 Ninja 250R Tech Talk 21 April 1st, 2010 12:09 PM
