March 6th, 2012, 06:47 PM | #1 |
Join Date: Dec 2011 Motorcycle(s): 2003 Kawasaki Ninja EX250-F Posts: 8
If I buy a used full rear wheel assembly for an 04 model off ebay...
Will a full rear wheel assembly for an '04 fit unmodified on an '03? I see that on eBay I can get a used full rear wheel including tire with good tread for around $80, but a new tire usually runs around $120, so to save time and money I just want to buy a complete rear wheel, will that work? Because it comes with the sprocket and the disc brake already on the rim, only the axle and bushings/spacers have to be interchangeable, right?, are they?
Thanks in advance. Will a 41073-1366-15E fit on a EX250-F17? Last futzed with by losmurfs; March 6th, 2012 at 07:07 PM. Reason: Added 7 word version of the original question. |
March 6th, 2012, 07:55 PM | #2 |
Identical. While you have it apart, swap on the least worn rear sprocket and rotor, and shim the cush drive with some cut pieces of milk jug plastic to reduce drivetrain lash.
March 7th, 2012, 05:40 AM | #3 |
Thanks for the rapid response
I hope you're right 'cause I just spent $94.48 (that includes shipping) for an '04 rim that hopefully will arrive this Friday.
March 7th, 2012, 12:24 PM | #4 |
The bike didn't notably change from 1988 through 2007. Yes, that's a very long time. The only parts I know that can't be used between any bike in that range are the CDI and associated wiring harness (pinout changed or something)
Why You Shouldn't Buy Ebay Helmets | az3200 | Motorcycle Gear | 5 | June 11th, 2013 05:53 AM |
Buy Plastics off eBay | RiderOnTheStorm | General Motorcycling Discussion | 3 | January 22nd, 2013 08:42 AM |
Want to Buy: front/rear signals, headlight assembly, tail light assembly for 2009 | rph12 | Items Wanted | 1 | July 15th, 2012 08:02 PM |
UK model 2008 250R on ebay | Gregular | Motorcycle-related | 4 | December 11th, 2010 01:13 PM |
