Old March 28th, 2015, 12:30 PM   #1
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
please help with throttle cable on carbs
In the months that I've had this bike apart, I have forgotten how the cables are attached to the carbs. I have the right cable in the right spot, but I would need to adjust a lot to make it work. I think I'm missing something. Can someone please post a picture or two of the carbs where the cables connect? That way I will see what I'm doing wrong. Thanks
gantt is offline   Reply With Quote
Old March 28th, 2015, 12:40 PM   #2
heres a pregen
Old March 28th, 2015, 05:01 PM   #3
gantt
gantt's Avatar
Thanks Alex. Didn't think of YouTube. From the video, I have them right. But they are adjusted all the way out and the retract cable is loose. Also I can see where the cables are bent like they used to be in w different configuration. Also, throttle doesn't return well at all. It doesn't actually hang up, but it doesn't close on its on.
Old March 28th, 2015, 05:22 PM   #4
Originally Posted by gantt View Post
......... Also, throttle doesn't return well at all. It doesn't actually hang up, but it doesn't close on its on.
The problem may be in poor lubrication of the cables and/or handle.
The spring in the carburetor is strong enough to pull back the main cable and to rotate the handle all the way.
Please, take a look at these:
http://faq.ninja250.org/wiki/Throttl...is/re-assembly
https://www.ninjette.org/forums/newr...reply&p=998772
Old March 28th, 2015, 06:58 PM   #5
gantt
gantt's Avatar
Thanks moto, but the issue I have is proper routing on the carb side. The cable is bent like it used to be mounted in a different way. I can't find any other way to mount it. I'm sure it will be a facepalm moment when I figure it out.
Broken throttle cable Ninja Rob 1986 - 2007 Ninja 250R Tech Talk 12 January 23rd, 2015 10:07 AM
Throttle went while riding -> need new throttle cable? AndrewMack 2008 - 2012 Ninja 250R Tech Talk 13 September 8th, 2013 06:17 PM
Throttle Cable Housing indr 2008 - 2012 Ninja 250R Tech Talk 2 December 20th, 2012 07:44 PM
Adjusting Throttle Cable - Barrel adjusters and Throttle body adjusters are maxed out theob 2008 - 2012 Ninja 250R Tech Talk 10 July 19th, 2012 05:01 PM
Throttle & Throttle Cable Smoothness paterick4o8 2008 - 2012 Ninja 250R Tech Talk 3 December 1st, 2009 01:50 PM
