Old February 17th, 2022, 10:32 AM   #201
back on a set of especially nasty 250's today. Overtightened bowl screws needed dremel action to remove, as did all 8 brace screws. Badly discolored brass, clogged jets....yada yada. Completed pics to follow when completed.
Sounds like horror-movie of carbs!!! Post lots of photos in progress. I'll make video and set it to soundtrack! ...
Old February 17th, 2022, 03:14 PM   #202
sorry, the video production will need to wait for another set. Due to restricted time, I snapped NO before pics and just 3 afters. I'll post 1.
Of course I HAD to make time to drill out and tap a stripped carb top thread, using a 5mm thread bolt in place of the 4mm stocker.
Getting busy already, an EX500 in my garage for carb and valve clearance services. Sat for 4 years prior to a local student gaining ownership.
Old February 18th, 2022, 11:19 AM   #203
shspvr
Sound like fun
Old February 18th, 2022, 01:57 PM   #204
doing a set of (4 years dormant) EX500's carbs today......here's visual documentation of some built up poop
given more time, this crap (varnish) would turn brown.
Old February 18th, 2022, 02:33 PM   #205
shspvr
Look like you caught it just time that look like just after 1 year of just sitting around with Gas Stabilizer but will end it will turn in crystal state.
Last futzed with by shspvr; February 21st, 2022 at 03:12 AM.
Old February 20th, 2022, 11:40 AM   #206
Now completed, slight improvement, IMHO. Bike in my possession, starting sequence to commence soon.
Old February 20th, 2022, 07:14 PM   #207
experimenting (within a deep learning curve) on my new injector cleaning/testing machine this evening
Old March 7th, 2022, 04:34 PM   #208
invested $35 in a set of used (complete) throttle bodies (strictly as spares) for my SS800 Ducati twin. Discovered 1 intermittent firing injector...no biggie I've got spares.
Well worth the investment, I believe.
During disassembly and split, I retained all settings. In the process of renewing fuel feed lines, requiring some special parts and attention.
Before/after pics.
Last futzed with by ducatiman; March 8th, 2022 at 11:25 AM.
Old March 20th, 2022, 02:11 PM   #209
completed a REFURB of a set of BSDT38 Mikuni's off a Ducati 900SS/FE today, basically returning them back to stock spec.
Findings included: 150 mains (replaced with OEM supplied 140)
pilot screws backed out 5 (!) turns, returned to 3 1/2 (more normal starting point for Ducati spec)
As current owner is replacing airbox top with a stock unit, he found a basically removed (drilled/modded) cover upon purchase, the PO in an obvious search for "more fuel/more air".
Standard for these Mikunis, I found ovaled emulsion tubes (replaced with new). This condition is known to cause uncontrollable rich running.
Last futzed with by ducatiman; March 20th, 2022 at 03:42 PM.
Old March 30th, 2022, 06:22 PM   #210
a set of EX500 carbs completed today.
Old March 31st, 2022, 05:25 PM   #211
currently doing 250 ninj carb set & petcock refurbs.
(attached pic of completed, functional petcock, carbset to follow)
Petcock got 1 new mesh filter (upper), all new orings (was able to reuse diaphragm, with new, small oring installed o'course). It tested perfect as OFF seals, ON + RESERVE only flow when vacuum is actuated.
Rebuilding petcocks can be problematic, as such, testing PRIOR to installation is mandatory.
Old March 31st, 2022, 05:53 PM   #212
shspvr
Nice work
Old March 31st, 2022, 06:01 PM   #213
ty @shspvr
Old April 1st, 2022, 10:45 AM   #214
pic as promised, carbset now refurbed.
Old April 1st, 2022, 04:05 PM   #215
today converted a standard 250 vac petcock to constant flow per client request.
Made a gasket, thus eliminating the diaphragms/gaskets and spacer, which leaked under testing. Also provided a missing oring at the lever.
ON-OFF-RESERVE still function as intended under constant flow condition. All good, no leaks.
Old April 3rd, 2022, 09:22 AM   #216
another set of Ducati / Mikuni BSDT38's in process. Fuel rail seals show a ton of white varnish, 1 pilot jet needed 'help' in removal. Thankfully, spares stocked for these exact circumstances. In addition, throttle slides frozen solid.
Old April 3rd, 2022, 04:22 PM   #217
finished them today....from this.....
Old April 3rd, 2022, 04:25 PM   #218
to this
onward to 250's now in house
Old April 4th, 2022, 05:20 PM   #219
250's in house today. Finished, but not without some drama. Replaced aftermarket, non-marked main and pilot jets with factory stock sized jets. Ugh. Had no choice but to repair via enlargement/drilling/tapping a stripped female thread at the LH carb float bowl, upped from 4 to 5mm (see pic). Other changes were made where necessary to net a set of now perfectly set up, usable carbs.
Old April 8th, 2022, 07:43 AM   #220
another 250 set finished this morning. Coincidentally, the same exact drilling/tapping sequence in the same exact spot was required! Overtightening screws (compensating for flattened bowl gaskets) is a no-no. Replace the darn bowl gaskets! In this case, I ran out of my standard, I subbed Lite-Tek spares. Also replaced a torn diaphragm.
All consumables replaced, adjusted, synched, wet tested. I'll submit these as now fully functional, a far cry from what I was initially sent.
Old April 30th, 2022, 12:21 PM   #221
refurbed, shipped back to owner yesterday.
Old May 17th, 2022, 04:41 PM   #222
busy day, 100 mile morning ride followed by completion of a 250 refurb upon return. They came out nice.
Old May 23rd, 2022, 04:24 PM   #223
another set of 250 carbs finished today after a quickie 45 mile morning ride.
Old May 25th, 2022, 07:22 PM   #224
a set from an EX500 done after another 45 miler today.
Old June 4th, 2022, 06:21 AM   #225
over a 12 hour period yesterday ....completed 2 refurbs , both a 250 and a 500.
The 250 a member here....I'm sure he'll be v happy.
The 500 my 2nd (of 3) sets for a group of converted sprint car guys in upper NY state. They insist on using Dynojet kits. OK, customer is always right. Comment after my 1st was run..."it never ran better" ...thus the repeat business.
Old June 4th, 2022, 07:25 AM   #226
thedrewski86
thedrewski86's Avatar
I always took issue with that rule. A shrewd customer should rely on the expertise of the one hired to do the job. Otherwise, why hire them?
Don't think, look!
Old June 20th, 2022, 04:29 PM   #227
EX500's done today
Old June 22nd, 2022, 04:10 PM   #228
yet another 500 set done today.
Old June 27th, 2022, 05:07 PM   #229
'81 Yamaha XV920 (early Hitachi CV) carbset done today.
A before/after or 2.
Last futzed with by ducatiman; June 28th, 2022 at 10:02 AM.
Old July 21st, 2022, 02:06 PM   #230
doing a set of 250's today that were left as-is (loaded with fuel) in a bike parked for 7 years. Coming out perfect (will be bolt-on runners) using my normal cleaning tactics. Every part submerged within bowls was gross....jets totally clogged, discolored, floats were green, both float valves and slides were frozen in place.
I'll post a pic or 2 later, what a transformation!
Old July 22nd, 2022, 11:24 AM   #231
as promised
Old July 27th, 2022, 03:57 PM   #232
a REFURB on 250's underway today....needed to drill/eze-out a pilot screw with stripped head. Piece o' cake.
Old July 28th, 2022, 01:32 PM   #233
and.....finished. I'll project these'll bolt right up and run.
Old August 11th, 2022, 06:10 PM   #234
and yet another 250 finished today. These featured "hogged out" pilot jets drilled so far out, biggest I've ever encountered...beyond .040". AND a float valve stuck in place ....yes, yet another.
In the end....all circuits clear, pilot jets replaced with OEM #38 from my stock, wet tested perfect. I'll submit yet another set of bolt-on runners were completed today.
I believe a PO was compensating for something in the drilling of the pilots....stock exhaust and airbox too! The bike then sat for 18 months before being sold to the current owner. Well, at least these little speedbumps keep me in "practice".
Old August 11th, 2022, 06:52 PM   #235
Bob KellyIII
Bob KellyIII's Avatar
Some people use the strangest reasoning for their actions....their reasonable to them at any rate but they just don't see the whole picture !
Nice work Gordon ! they look brand new !
Old September 13th, 2022, 05:23 AM   #236
another one (EX500) bites the dust, going back home today, now bolt-on runners
Old September 30th, 2022, 04:45 PM   #237
Bolt-on runners completed for a member here today
Old October 12th, 2022, 05:30 PM   #238
season winding down....rode the 800SS to Southampton, Long Island today...a bit over 100 miles. My chosen destination, a waterside park pictured, parking lot empty. Retirement has certain advantages.
Old October 12th, 2022, 05:34 PM   #239
Nice scenery!
Old October 13th, 2022, 06:33 AM   #240
better yet
[roadracingworld.com] - â??Racers Edge Performance Hosting Track Day/ Practice Day Ap Ninjette Newsbot Motorcycling News 0 March 25th, 2015 02:20 PM
