Old November 18th, 2013, 10:39 PM   #1
mikedabike64
Motorcycle(s): 2008 ninja 250
carb removal
at the risk of burning my bridges, does the stock air box need to come out to remove the carbs, am i missing something?
seems like the box must be moved back a little at the very least,
i see the 2 rubber boots connecting the carb to box I was thinking they should be loosened at the carb end.
thanks
Last futzed with by mikedabike64; November 18th, 2013 at 10:55 PM. Reason: more detail
mikedabike64 is offline   Reply With Quote
Old November 18th, 2013, 11:38 PM   #2
tubarney
airbox out to remove carbs.
Old November 18th, 2013, 11:52 PM   #3
mikedabike64
Ok thanks
Old November 19th, 2013, 04:43 AM   #4
The airbox doesn't really have to come out. You can slide it back, it only slides back a little bit but it's enough to wrestle it out and back in.
Old November 19th, 2013, 07:49 AM   #5
mikedabike64
Cool ok
Thanks I will try to move it back first, Got up this am & questioned whether or not a top and flat spot
is worth the effort of taking the entire inbox out.
Old November 19th, 2013, 07:57 AM   #6
I aint gunna lie brah. It only moves back about an inch and a half and takes some wrestling but it's just enough. Many newgen 250 riders do it like that. Now if your working on an 07 or older, then ya... do yourself a favor and remove it.
When putting the airbox boots back on the carbs, double, triple and then check again for a good seal around each end on both boots. Good luck mang, it's one of the more aggravating maintenance jobs for this bike.
Old November 19th, 2013, 08:07 AM   #7
rc racer
rc racer's Avatar
Motorcycle(s): 2015 R3, 1969 CB160, 2002 TTR125, 2007 KX250F
It helps a ton to remove the battery and battery box. Doing this lets the air box move back just a little more.
rc racer is offline   Reply With Quote
Old November 19th, 2013, 08:21 AM   #8
mikedabike64
ok thanks guys
I appreciate the help for sure, I plan on running track days with it next year.
so I have plenty of time I work on it a little bit and then when I get frustrated I put it down for a while, but I wanted to make sure to get some tips, as I move along in the process before each stage
Old November 19th, 2013, 08:34 AM   #9
It's easier than it sounds, you will do fine I am sure. Good luck at the track!
airbox realignment problems after carb removal Akane 2008 - 2012 Ninja 250R Tech Talk 2 April 15th, 2014 01:04 PM
Help me please! Carb Removal (I'm Stuck) zach 2008 - 2012 Ninja 250R Tech Talk 30 August 13th, 2013 08:17 PM
Gas Tank Removal; Carb Boots aweesner 1986 - 2007 Ninja 250R Tech Talk 1 September 6th, 2011 06:53 AM
CA Emissions Removal question (carb parts) CynicalC 1986 - 2007 Ninja 250R Tech Talk 6 March 17th, 2011 09:18 AM
Do shogun sliders get in the way of carb removal? adouglas 2008 - 2012 Ninja 250R Tech Talk 3 April 29th, 2010 07:53 AM
