Old May 10th, 2009, 03:15 PM   #1
tlhamon
tlhamon's Avatar
Motorcycle(s): None Yet
Exhaust Suggestions
I'd like to put something on my bike that sounds a little throatier, but not loud and I don't want to have to do anything to the carb. Does that exist, or should I just drill holes in the stock exhaust? I'm kidding about the holes.
It's not worth doing if you aren't completely stressed out about it.
tlhamon is offline   Reply With Quote
Old May 10th, 2009, 03:26 PM   #2
Rocketman
Rocketman's Avatar
Motorcycle(s): 2009 250r special edition
I saw on 2fiddy.com awhile back that a company called Scorpion makes exhausts that work well with stock jetting...maybe check them out.
Rocketman is offline   Reply With Quote
Old May 10th, 2009, 03:30 PM   #3
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
Area P - no need to look any further
Old May 10th, 2009, 03:44 PM   #4
Rocketman
Rocketman's Avatar
How is not looking past an area p exhaust going to help his situation ?
Old May 10th, 2009, 03:47 PM   #5
Mo1981
Mo1981's Avatar
Motorcycle(s): 2008 Ebony Ninja 250R
D&D's slip-on doesn't require jetting, but it might be a bit louder than what you're looking for...
Matt
2008 Ebony Ninja 250R (a.k.a. "Venom")
Mo1981 is offline   Reply With Quote
Old May 10th, 2009, 04:59 PM   #6
whatever exhaust is put on there should be rejetted. even stock, the bike needs to be rejetted.
Old May 10th, 2009, 10:09 PM   #7
Ninja007
忍者
Ninja007's Avatar
Motorcycle(s): None Now - Used to have an '08 Ninja 250R Candy Blue
+1. stock exhaust is lean. also, with an Area P or Yoshi exhaust, you can stick the silencer in there to quiet it down if so desired.
Ninja007 is offline   Reply With Quote
Full exhaust and intake suggestions storm720 2008 - 2012 Ninja 250R Tech Talk 8 August 30th, 2014 12:46 PM
Exhaust suggestions (priorities probably different from most) jent 2008 - 2012 Ninja 250R Farkles 21 August 4th, 2011 08:17 PM
2010 ninjette exhaust upgrade suggestions Shaol1n Monk 2008 - 2012 Ninja 250R Tech Talk 19 May 23rd, 2011 10:37 AM
Need some suggestions with this situation bikermunda 2008 - 2012 Ninja 250R Tech Talk 13 September 14th, 2010 06:53 AM
