Old July 7th, 2022, 08:52 PM   #1
Thedonn1732
Motorcycle(s): 2006 Ninja 250r
Help installing Vapor trail tech cluster
Just got the Vapor trail tech cluster in the mail that I am going to install on my 06 ninja 250, but I am looking at all the wires here and not gonna lie I am very confused. I've seen on these forums that some people have installed them before on their bikes but I can't seem to find a tutorial specific to the 06 ninja 250, I only found one for the 08 models and I'm not sure if they are going to be the same.
For example, how do I wire the neutral light? Brights?
The kit provided a temp sensor, but I've read that you can actually wire it up to the stock sensor?? I also got what looks like two things for the speed sensor, how has others installed these? Just generally confused
Advice on this would be incredibly helpful.
Thedonn1732 is offline   Reply With Quote
Old July 8th, 2022, 09:02 AM   #2
hi, take your time and do one wire at time. Most of them can actually connect to factory dash wires
power - connect to wire with power with key ON
ground - connected to ground wire
brights - connect to wire that turned on dash's high-beam indicator
neutral - connect wire that turned on dash's neutral light.
Use factory manual's wiring diagram to figure out which wire does function you want. Don't use Haynes or Clymer manuals, they have lots of errors. Use multimeter to verify signal.
Compare stock temp sensor with one they provided. Put both in pot of water and measure resistance. Bring pot to boil and measure resistance of both along way. Maybe every 5-minutes.
Trail Tech Vapor Odometer Cra1g General Motorcycling Discussion 6 September 8th, 2016 07:37 PM
Trail Tech Vapor MAZ 80 General Motorcycling Discussion 2 October 19th, 2015 04:10 AM
Trail Tech Vapor Review Kruse08 1986 - 2007 Ninja 250R Tech Talk 7 August 19th, 2014 02:55 AM
Trail Tech Vapor and mount rugbert 1986 - 2007 Ninja 250R Farkles 12 September 2nd, 2013 11:36 AM
Vapor Trail Tech Question/Help skilletmo 2008 - 2012 Ninja 250R Tech Talk 41 May 12th, 2013 02:40 PM
