Old July 3rd, 2022, 04:36 PM   #1
jcgss77
Its not a 250,its a Ninja
jcgss77's Avatar
Mystery open tube on top of engine
Thankfully, the '12 carb woes are finally behind me, just got the MOST WONKY carb I have every worked on with a ninja taking throttle. So now I am moving on to other projects, which includes this little opening I noticed. Is this normal, or do I need to connect this to something?
Last futzed with by jcgss77; July 3rd, 2022 at 07:13 PM.
Old July 3rd, 2022, 09:51 PM   #2
SuspectPage3
Motorcycle(s): 2008 Ninja250R
On mine, doesn't connect to anything, just an empty hose routed to ground, for overflow or air may be!
Not a certain answer, but hopefully helps
Only a biker knows why a dog sticks his head out of a car window!
Current Ride: 08 Ninja250R
SuspectPage3 is offline   Reply With Quote
Old July 4th, 2022, 07:01 AM   #3
jcgss77
jcgss77's Avatar
It does, thank you for taking a look on your bike. You just never know when you get one of these used, mine was missing both tightening bolts on the ends of the triple tree clamps, the side cover for the airbox, and the exhaust spacer for the muffler. I just don't understand people sometimes.
Old July 5th, 2022, 11:18 AM   #4
Ceeloo Yello
Motorcycle(s): 250
I put a breather on that pipe to catch any oil.
Old July 5th, 2022, 10:35 PM   #5
jcgss77
jcgss77's Avatar
Interesting idea, I might just throw a foam baffle over it to protect both entrance and exit.
[visordown.com] - Triumph to open new factory visitor centre next month, with mystery Ninjette Newsbot Motorcycling News 0 September 12th, 2017 07:50 AM
mystery part hanging from my engine gary 1986 - 2007 Ninja 250R Tech Talk 7 July 11th, 2015 12:07 PM
Gas coming out of overflow tube. Engine not starting. BearZ 2008 - 2012 Ninja 250R Tech Talk 11 October 11th, 2014 07:53 PM
[motorcycle.com] - Rich Olivers Mystery School Still Has Open Dates Ninjette Newsbot Motorcycling News 0 October 1st, 2014 11:40 AM
Mystery Tube HorizonXP 2008 - 2012 Ninja 250R Tech Talk 3 August 28th, 2010 05:54 AM
