Old February 8th, 2009, 01:06 PM   #1
ajcalamia
Motorcycle(s): 1992 Ninja250
Radiator Fan Question
Hi all..New member here. I recently bought a 1992 ninja 250 with 5596 miles on it. However when I got it home I noticed that the fan runs whenever you turn the key on. Even when the bike is cold! All of the wiring appears to be stock and without any modifications. What could be causing this?
ajcalamia is offline   Reply With Quote
Old February 8th, 2009, 01:37 PM   #2
bad fan temp sensor, bad fan, maybe low coolant level... host of things that you will be need to troubleshoot.
welcome to the forum...
check your PM.
Old February 8th, 2009, 01:42 PM   #3
komohana
komohana's Avatar
Motorcycle(s): 05 GSX-R 600 2003 EX250: Woodcraft Bars, Levers, Mirrors, Shim'd Mixture, Synthetic, '08 Rear Shock
let us know whatcha find...
Remember when sex was safe
and motorcycles were dangerous?
komohana is offline   Reply With Quote
Old February 8th, 2009, 02:20 PM   #4
Guinss
Guinss's Avatar
Motorcycle(s): 2008 250R (Black)
i thought the fan only ran when the engine was running, same as headlights. (its like this on my 2nd gen, may not be like this on the 1st gen, but its logic? the battery will empty quickly with that kind of amp the fan draws)
my conclusion, must be something wrong with the wiring.
welcome to the forum!
Guinss is offline   Reply With Quote
Old February 8th, 2009, 03:14 PM   #5
HKr1
IC2(SW)
HKr1's Avatar
Fan comes on via the temp sw on the 2nd Gen. Doesnt have anything to do with ingition sw.
If the 1st Gen is like the 2nd, all it could be is the switch(2).
Old February 8th, 2009, 03:25 PM   #6
Guinss
Guinss's Avatar
My fan wont go if the engine is stopped. When i start it, the fan starts immiedatly. Is that 2nd gen wiring?
Its most likely the switch that needs to be changed. It almost always that when fan wont go, or is always on.
Old February 8th, 2009, 03:29 PM   #7
HKr1
IC2(SW)
HKr1's Avatar
Post a pic of the schematic, I would like to see. I bet the FI ecm controls the cooling fan along with the ingition coils/injectors
Old February 8th, 2009, 03:38 PM   #8
Guinss
Guinss's Avatar
Could be, i dont have the schematics.
Agree with you when you say it can only be a faulty temp switch.
Old February 8th, 2009, 05:29 PM   #9
noche_caliente
noche_caliente's Avatar
Motorcycle(s): '08 250
can't help with the fan question - but welcome!
Old February 8th, 2009, 07:28 PM   #10
HKr1
IC2(SW)
HKr1's Avatar
Yeah, if its wired the same... thats all it could be
You need to order up the service manual(I thought you had one from the shock post, guess that was from bike manual), while your there order up the 250r stickers too. < 250r stickers for the rear cowl(green/red bike x2) then you could send to me here in the USA
Radiator Fan Led WindMeUp 2008 - 2012 Ninja 250R Farkles 5 September 10th, 2010 04:33 PM
Radiator Fan Problems wayanlam 2008 - 2012 Ninja 250R Tech Talk 9 July 22nd, 2009 07:16 PM
