Old March 17th, 2012, 06:17 AM   #1
NDspd
1/4 English, 3/4 Kick Ass
NDspd's Avatar
Motorcycle(s): 2002 Triumph Speed Triple 955i, '05 Suzuki SV650S(retired), '11 Ninja 250R(sold)
Front Brake Pads, change
Hey guys looks like I'm gonna be changing the front brake pads here by the end of the week. Do you guys have any tips when doing this? I have most of the tools, minus one or two to pick up at the hardware store. I'm gonna clean the calipers before pushing on the pistons, but can you push them in by hand?
Thanks for the help guys,
J
NDspd is offline   Reply With Quote
Old March 17th, 2012, 06:23 AM   #2
You can push them in by hand slowly if you get your grip right and they are clean enough. I've found brake cleaner 100% ineffective, though.
Old March 17th, 2012, 06:41 AM   #3
Jono
Jono's Avatar
Get a C clamp to push them back in!
Old March 17th, 2012, 06:57 AM   #4
leed
leed's Avatar
Motorcycle(s): Time will tell
Don't squeeze or let anyone squeeze the brake lever once you've taken the caliper off! And yes, you can push the piston in by hand. If it helps, use one of the old brake pads to assist. You can also use the brake pad to protect the piston if you use a c-clamp to push it in.
Old March 17th, 2012, 12:28 PM   #5
leed is right. Use the old pad to press the pistons back in. don't use anything that could possibly mar those up, or you'll likely be looking at replacing them later on.
Front and rear brake pads for $11? DmbShn41 2008 - 2012 Ninja 250R Tech Talk 13 April 5th, 2015 02:23 PM
Went to change my brake pads, but had some issues installing the news ones. Insane Pie 2008 - 2012 Ninja 250R Tech Talk 6 September 16th, 2014 02:18 PM
Are front and rear brake pads the same? warning 2013 - 2017 Ninja 300 Tech Talk 12 June 22nd, 2013 03:22 PM
Are front and rear brake pads the same? kchava 1986 - 2007 Ninja 250R Tech Talk 4 March 7th, 2011 10:39 AM
[motorcyclistonline] - How to Change Brake Pads Ninjette Newsbot Motorcycling News 0 June 19th, 2008 04:55 AM
