Old January 21st, 2013, 12:54 AM   #1
NJfinest50
NJfinest50's Avatar
Motorcycle(s): Ninja 250r
H7 bulb
A friend of mine recently brought these 65w H7 bulbs for his bike from rally lights (Susquehanna Motorsports). Will these be okay in our bikes, not mess up wiring or anything? I'm looking for nice bright bulbs for safe riding with out dishing out the money for HID Kit.
http://rallylights.com/detail.aspx?ID=1197
http://rallylights.com/SearchResult.aspx?CategoryID=369
NJfinest50 is offline   Reply With Quote
Old January 21st, 2013, 09:23 AM   #2
DaBlue1
Long Time Rider
DaBlue1's Avatar
Those bulbs would probably work, however higher wattage bulbs tend to put out a little more heat. So you may want to stay with a 55w bulb. I have the Phillips MotoVision Motorcycle Bulb. Its an excellent stock replacement. Quite a few members on the forum use them. They also have great reviews in the motorcycle community. They are also cheaper than the ones you are considering.
http://www.ninjette.org/forums/showthread.php?t=94768
http://www.ninjette.org/forums/showthread.php?t=24074
http://www.ninjette.org/forums/showp...60&postcount=9
http://www.cyclegear.com/eng/product...ulb/web1005526
Old January 21st, 2013, 09:36 AM   #3
xSean13
xSean13's Avatar
Motorcycle(s): 2010 Ninja 250r (sold) / '03 CBR 600RR
If you do it without using projectors, you're just asking to get hit. Putting HIDs in halogen housing without projectors to block off the light will blind everyone in your path.
Does this look safe?
xSean13 is offline   Reply With Quote
Old January 21st, 2013, 09:53 AM   #4
menikmati
crash 250, get supersport
Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ
Yeah I threw away my HIDs and switched over to Philips Xtreme Power bulbs recently, I like having a functional hi-beam and being respectful to other drivers.
They're around $30 a pair and there are rebates available:
http://www.amazon.com/Philips-X-trem...lips+xtreme+h7
As stated above, I wouldn't get HIDs without getting a proper retrofit or projector setup which is something most people won't do, they'll get a cheap HID kit and throw it in the stock halogen housing.
menikmati is offline   Reply With Quote
Old January 21st, 2013, 10:17 AM   #5
Peanut_EOD
Peanut_EOD's Avatar
Motorcycle(s): Green 2013 ZX-6R
I would go with the Philips bulb since they're the only ones that spelled "Lumens" correctly.
http://www.simplysurrealphotography....es/peanut2.png
Peanut_EOD is offline   Reply With Quote
Old January 21st, 2013, 10:28 AM   #6
Just a standard xenon without the ability to switch over to high beam on one side. Then use the Halogen on the right side for your high beam. Best of both worlds. You can get a single projector on ebay for cheap. (like $30 or so) and then you just take your HID kit and plug it into the projector.
You've already got most of the parts since you have an HID kit that you took out. You'll just need a projector, a bulb for it, and potentially an adapter if you choose to use a D2S projector and D2S bulb. Cheap.
Old January 21st, 2013, 05:35 PM   #7
NJfinest50
NJfinest50's Avatar
so the bulb i posted about (http://rallylights.com/detail.aspx?ID=1197) is an HID?? I thought our bike takes an h7? Thanks for the help.
Old January 21st, 2013, 05:48 PM   #8
Oh! Sorry NJfinest50, we got on a tangent there (happens a lot here, I'm very guilty of it). Your bulb looks like a 65w Halogen H7 bulb to me
I was responding to menikmati about him taking an HID kit off of his bike and saying he should have kept the low beam side HID and used a projector along side the standard Halogen high
Old January 21st, 2013, 06:06 PM   #9
NJfinest50
NJfinest50's Avatar
sorry I got a little confused. I'm going to try the bulb and also order a set of motovisons (http://cyclegear.com/eng/product/mot...ulb/web1005526). I will let everyone know how the Osram bulb works out from rallylights.com.
As a side note from my research the H7 is a Tungsten-halogen single-filament bulb.
Old January 21st, 2013, 06:09 PM   #10
NJfinest50
NJfinest50's Avatar
Sean the bulb we posted about is not an HID sir.
Light bulb and Gauge bulb options RandomPhantom 2008 - 2012 Ninja 250R Tech Talk 11 August 21st, 2014 10:06 AM
Does dead taillight bulb affect the license plate bulb? headshrink 2008 - 2012 Ninja 250R Tech Talk 5 April 3rd, 2013 06:05 AM
bulb options? azimmer11 2008 - 2012 Ninja 250R Tech Talk 1 August 10th, 2012 07:24 AM
What Size Bulb Is This!?!? Key007 2008 - 2012 Ninja 250R Tech Talk 7 August 17th, 2010 11:42 AM
WTB: Replacement bulb. Upgraded to HID? Sell me your old bulb! CZroe Items Wanted 7 October 25th, 2009 03:58 PM
