Old July 17th, 2012, 10:18 AM   #1
psych0hans
psych0hans's Avatar
Just picked up some gold valve emulators
Hi guys, I just picked up some gold valve emulators for a princely sum of 120$. What I want to know is, should I consider changing the springs as well? I weigh about 150lbs, so I'm not sure if I need to. I checked on another thread on these forums that the compression rate of the stock springs is approx .65kg, which would be close enough for what I need. I'll be mainly using the bike for street use, but will track it from time to time. What else should I consider purchasing with this to enhance the front suspension? I'm generally on a pretty tight budget.
Old July 17th, 2012, 10:42 AM   #2
cuong-nutz
cuong-nutz's Avatar
Nice find. Preload adjusters would help. I think your springs are going to be fine. I am keeping my stock springs and I weight ~155lb.
HalfFast Racing Team
Old July 17th, 2012, 11:34 AM   #3
look up how to tell what your current sag is. if your sag isnt correct with your current springs and weight you can add preload with washers or a set of preload adjusters or change to correctly rated springs (better then just adding preload because it keeps your current travel)
ideally you would want correctly rated springs with preload adjusters to fine-tune your bottom out
valve emulators lolibater 1986 - 2007 Ninja 250R Tech Talk 103 December 10th, 2012 02:45 PM
Gold Valve Emulators KChatham 2008 - 2012 Ninja 250R Tech Talk 4 January 4th, 2012 11:03 PM
Front fork Valve Emulators? empire00 2008 - 2012 Ninja 250R Tech Talk 5 July 21st, 2009 01:30 PM
