July 25th, 2012, 10:54 AM | #1 |
Stock turn signal issue
I sent my bike to a mechanic to get the carbs cleaned. When I got it back, I notice that my right turn signals work fine, but if I try to blink left, the front one does not light up and the back one stays solid. The green light on the dashboard also stays solid when turning left, but blinks when turning right.
Do you guys think that this is a wiring issue or does the behavior indicate that a bulb is out? If it is a bulb issue, does anyone know the part number for a stock front turn signal? I was going to try amazon. Thanks! |
July 25th, 2012, 11:39 AM | #2 |
Maybe he forgot to plug the light back in. You can probably reach it through the side fairing. Part number can be found through the search function.
July 25th, 2012, 11:54 AM | #3 |
Join Date: Apr 2012 Motorcycle(s): '12 ninja 250r Posts: 762
^Kinda sounds like that. Wiring systems counts on resistance of the bulbs.
July 25th, 2012, 12:09 PM | #4 |
Thanks, I'll check the plugs and post afterwards.
July 25th, 2012, 12:15 PM | #5 |
Join Date: Mar 2011 Motorcycle(s): 09 Ninja 250r Posts: 634
probably just forgot to plug it back in when he put the fairing back on...
”Any man dies with a clean sword, I’ll rape his f***ing corpse!”- The Hound |
July 25th, 2012, 04:59 PM | #6 |
Thanks for your help, it was in fact an un-plugged wire under the left fairing.
turn signal issue, help plz | K11 | 2008 - 2012 Ninja 250R Tech Talk | 6 | October 20th, 2013 11:09 AM |
Turn Signal issue, looking for opinions | ArsnlTim | 2008 - 2012 Ninja 250R Tech Talk | 14 | August 2nd, 2013 02:47 PM |
Where to buy stock front turn signal bulb? | Ben M | Items Wanted | 6 | November 6th, 2012 04:26 PM |
Stock turn signal issue. | larson38 | 2008 - 2012 Ninja 250R Tech Talk | 3 | July 24th, 2012 09:49 PM |
Turn signal issue... | YMCMB | 2008 - 2012 Ninja 250R Tech Talk | 8 | July 21st, 2012 04:58 PM |
