May 17th, 2009, 05:48 PM | #1 |
Join Date: Oct 2008 Motorcycle(s): 08 250 R Posts: A lot.
specific front stand question
I am trying to decide on a front stand. We have a Vortex rear but now need a front. Pitbull has one that has the rollers hooking up on the bottom of the forks. Vortex has the pin up top model. Pin model would seem better for more applications.
Question: with my bike being lowered... will there be clearence to use that Upper pin style??? Anyone have one, Anyone know? Thanks,!!
"Don't let adverse facts stand in the way of a good decision" Colin Powell |
May 17th, 2009, 06:00 PM | #2 |
I've got the pitbull one with the pin that fits in the triple-tree. The bar holding it up sits flush with the top fairing (right underneath the headlight), so I have a feeling it would fit just fine. How many inches clearance are there when the bike is at rest between the top of the fender and that bottom part of the front fairing (that black piece under the headlight assembly)? If there's at least 3", I think you'll have no issue sliding it in there.
May 17th, 2009, 08:41 PM | #3 |
Alex, did you have to remove anything (horn, fender, etc.) to use the pitbull stand?
I just felt an earthquake. |
May 17th, 2009, 08:58 PM | #4 |
Join Date: Feb 2009 Motorcycle(s): '09 Candy Thunder Blue Ninja 250R Posts: 618
it was a 5.0 in L.A. and i wonder how my motorcycle is doing. how big of a chance is there that a motorcycle will be knocked over?
May 17th, 2009, 09:06 PM | #5 | |
Hold on tight!
May 17th, 2009, 10:21 PM | #6 |
Thanks Alex I will measure in the morn!
May 17th, 2009, 10:21 PM | #7 |
Z-
With my pin type front stand and the front end lowered, I couldn't get the stand out with out scratching the top of the front fender. So, every time I would lift the front of the bike, I would remove the front fender. Six hex head screws to take it off... very easy. hope this helps. |
May 17th, 2009, 10:33 PM | #8 |
I was waiting for you kk and your lowered front.
thanks that sounds like an easy fix!!! and a good chance to clean that fender! I hadn't measured yet but picturing it in my mind it was tight...
May 17th, 2009, 10:44 PM | #9 |
yeah, before I lowered the front, lifting with the triple tree stand was pretty easy... no problems. The night I installed the lowering blocks, I found I couldn't get the stand out w/o scratching the fender.
Since that time, each time I use that front stand, I remove the fender. gl |
May 17th, 2009, 10:52 PM | #10 |
They aren't cheap that is for sure.. and TR needs a special rear one for his Triumph. arrggghh!! $$$$$$$$$$$$$$$
May 17th, 2009, 10:54 PM | #11 |
May 17th, 2009, 11:01 PM | #12 |
Thanks! l
May 18th, 2009, 01:33 PM | #13 |
Z- I haven't gotten mine yet, but I plan to do the pit bull - you can get it for just under $150 shipped from oneida suzuki out of New York
May 18th, 2009, 02:12 PM | #14 |
IC2(SW)
Go for the head lift stand, I also have the DMP S-spec it works real nice.
The ones that use the bottom of the forks are OK, but sooner or later you will have to work on the forks. < Atleast I did |
SV Racing Parts, Black Front Stem Stand and SS Style Rear Stand Combination | SV Racing Parts | Motorcycle-related | 0 | January 15th, 2015 06:45 PM |
specific cornering question | Domagoj | Riding Skills | 31 | October 22nd, 2012 04:56 AM |
Kick Stand Question | drdriftking007 | 1986 - 2007 Ninja 250R Tech Talk | 8 | June 11th, 2012 06:39 AM |
Specific Clip-Ons question? | JMcDonald | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 22nd, 2011 11:04 AM |
WTB: Pitbull Front Stand or Rear Spool Stand | Mr_Pete | Items Wanted | 8 | October 30th, 2009 02:02 AM |
