Old February 21st, 2010, 07:25 AM   #1
esi7esi7
212
esi7esi7's Avatar
Motorcycle(s): 09 250R, 09 ZX6R
Dragging belly pan?
I noticed that the belly pan on my '09 is dragging on the edge of both sides. Anyone else have this problem? I am on stock suspension with Attack bodywork.
Posted via Mobile Device
esi7esi7 is offline   Reply With Quote
Old February 22nd, 2010, 07:01 PM   #2
2WheelGuy
2WheelGuy's Avatar
Your suspension could be a big part of it. I don't drag but I'm running +9mm height on the shock and the forks at -14mm with stiffer springs. I've seen a lot of people drop the forks to -30mm attach clipons over the top triple clamp which eats up a lot of valuable ground clearance. Also, the stock springs are very soft and you will be bottoming out the suspension in turns.
Another part could be your body position, but it looks good in your avatar. Your upper body should be across the bikes center line to help stand it up in turns.
AFM #278
Belly pan(homemade) Anybody ever make one? justopelt 1986 - 2007 Ninja 250R Farkles 7 April 22nd, 2014 10:52 AM
WERA: stock belly pan? walk_n_wind Ninjettes At Speed 10 June 10th, 2012 06:59 AM
WTT pregen parts for belly pan Jiggyfly Motorcycle-related 0 March 20th, 2012 05:51 PM
belly pan gpx250rii marc_previtera Items Wanted 0 October 22nd, 2011 01:30 PM
SHINTO Belly Pan : Pre-Orders ThaiNinjaRR Motorcycle-related 0 March 14th, 2010 12:47 AM
