Old August 11th, 2011, 11:25 AM   #1
james250ninja
james250ninjette.newbie
james250ninja's Avatar
Motorcycle(s): 1986 ninja 250
buying a pipe
hi there i just bought a 2011 ninja 250 have 60 miles now, wanted to know whens a good time to put a aftermarket pipe on, should i still break the bike in .dont want too harm the bike ....
james250ninja is offline   Reply With Quote
Old August 11th, 2011, 11:30 AM   #2
is it a "water pipe"?
if its a full pipe make sure you rejet properly. correct me if i'm wrong but aside from that it shouldn't effect break in... break in is more for heat treating and seating the rings in the cylinder...
Old August 11th, 2011, 12:45 PM   #3
dubojr1
dubojr1's Avatar
I don't know of any issues changing the exhaust early on. Change it anytime you like.
Old August 11th, 2011, 01:11 PM   #4
james250ninja
ok thanks for info
Old August 11th, 2011, 01:12 PM   #5
james250ninja
Smile
lol..thinking of a slip on pipe only
Old August 11th, 2011, 02:36 PM   #6
2011Ninja250R
2011Ninja250R's Avatar
Motorcycle(s): 2011 Ninja 250R SE (Green) Previous bikes R1, Daytona 675, GSXR600, Pre-Gen 250R
Ijust bought an '11 250r and put the 2 Brothers slip-on on mine after about 75 miles. I also put the Factory Pro jet kit on it and WOW it sounds so much better and runs alot smoother as well. If you go with the 2 Brothers and don't want it too loud, get the P1X powertip. It is the perfect balance of better sound, but not too loud. When you get on it it growls but you can cruise along unnoticed by the police when you need to.
'11 Green SE - 2 Bros Blk Series CF, Factory Pro Jet Kit, Spiegler Lines, ZG Windscreen, Pazzo Levers, CW Fender Elim, Custom LED Integrated Tail Light, Protons, OEM Seat Cowl & Ti ProBolts.
2011Ninja250R is offline   Reply With Quote
Old August 11th, 2011, 03:58 PM   #7
greatwhiteninja
Ridin Dirty
Motorcycle(s): 2011 white se 250r , 2008 zx6R
youll be fine changing it..i see your from cherry hill nj, i bought mine from cycle world of cherry hill.
#1
greatwhiteninja is offline   Reply With Quote
Old August 11th, 2011, 04:55 PM   #8
Madchild
Ninja Racer
Motorcycle(s): 2006 Yamaha R6, 2009 Kawasaki Ninja 250R, 07 Aprilia SR50 Factory
You shouldn't have a problem at all. The stock pipe is really restricted.
CRA #23 - 2011 Sponsors: Cheng's Dynasty, Motoprimo, Studio299.com, Michelin, Syderleatherworks, Woodcraft, Vortex, Scorpion Helmet (USA), 24/7
Madchild is offline   Reply With Quote
Old August 12th, 2011, 09:39 AM   #9
james250ninja
do i have too re jet its just a slip on , did u do the jetting yourself
Old August 13th, 2011, 12:51 PM   #10
2011Ninja250R
You don't have to re-jet. The bike should run fine with just the slip-on. Re-jetting just helps it out alot.
Old August 13th, 2011, 02:00 PM   #11
the big restriction in the stock pipe is the catalytic converter in the mid pipe. the can on the end is just baffles... not terribly restrictive. you need to rejet if you change the flow in the intake or exhaust... so only changing the can at the end isn't going to really change much flow when you still have the catalytic converter
Old August 13th, 2011, 02:56 PM   #12
banhbaoo
banhbaoo's Avatar
Motorcycle(s): 08 250r Red
u dont need to get a jet kit for a slip-on, but I hear shimming your needles with make the bike run smoother
banhbaoo is offline   Reply With Quote
Old August 13th, 2011, 04:50 PM   #13
2011Ninja250R
That is right. You can shim your needles or install a jet kit on a bone stock Ninja 250R to smooth out the idle and warm up, as well as throttle response.
You don't have to do either if you install a slip-on.
You need to do one or the other if you install a full system.
Old August 14th, 2011, 09:21 PM   #14
Madchild
Ninja Racer
I have a full yoshi for sale if you're interested
What pipe is the best on the 08-12 250r? IconChris 2008 - 2012 Ninja 250R Tech Talk 19 April 15th, 2013 12:06 PM
Homemade GP pipe Gulf1 2008 - 2012 Ninja 250R Farkles 15 April 18th, 2012 10:42 AM
New pipe, now what Ulivious 2008 - 2012 Ninja 250R Tech Talk 19 February 16th, 2012 11:23 AM
Water pipe came out.... headshrink 2008 - 2012 Ninja 250R Tech Talk 10 May 3rd, 2011 10:28 PM
Smoking pipe eddiekay General Motorcycling Discussion 12 November 22nd, 2010 04:55 PM
