Old June 30th, 2018, 09:01 PM   #41
jrshooter
Motorcycle(s): ninja 300
Originally Posted by MakoMoto View Post
Ordered a RK 520SO 106 chain and some JT Sprockets. Went with the 15/45 as I feel it will be the best fit for me and my riding habits. They will arrive Monday and will be getting to work then! Thank you all! I'll keep it updated and will probably have many questions. Especially trying to get the OEM chain off...
cut off wheel
Old July 1st, 2018, 05:35 PM   #42
MakoMoto
Ninja 250r Noob
MakoMoto's Avatar
I don't have a Dremel tool, grinder or chain breaker. Will boot cutters cut the chain off? Is it easy enough to disconnect the swingarm and just pull the chain out that way?
"Kawasaki Ninjas Rule!" - 1997 Power Wheels Commercial
MakoMoto is offline   Reply With Quote
Old July 1st, 2018, 06:15 PM   #43
Ram Jet
Ram Jet's Avatar
Unbolting the swing arm will be a BITCH! However, it will be a great opportunity to lubricate all of your suspension components. A Dremel tool will do it but will take a while. Boot cutter won't do. Maybe a BOLT cutter would but it would be a first that I've heard of. If you don't remove the swing arm and don't decide on a master link (my choice) you're going to have to invest about $80.00 for some good link rivet tools and if you do that you will not have to cut-off your old chain. Your $80.00 rivet tool set should include and link removal tool. I didn't say it would be inexpensive. Lube your chain really well and make sure you don't have to go through all this ****.
Bill
Old July 1st, 2018, 06:21 PM   #44
Here are some ideas for removing the chain - https://faq.ninja250.org/wiki/How_do...e_the_chain%3F
Removing the swingarm is one of the most difficult IMO.
Borrow something to cut the old chain if you can.
Old July 2nd, 2018, 09:41 AM   #45
backinthesaddleagain
backinthesaddleagain's Avatar
Motorcycle(s): 2013 ZX6R 636
My apologies, that is what I intended to say.
While it is chain slack - others such as MCN and CycleWorld have also used slack and tension in their writings. Also back when long travel suspension was invented on MX bikes they had chain tensioners as some bikes had a long distance between front sprocket and swingarm pivot which meant wide swings in the amount of slack or tension on the chain.
Old July 2nd, 2018, 09:50 AM   #46
Use Alcatraz method, butter knife!!!
Loose chain? Hesh 2008 - 2012 Ninja 250R Tech Talk 27 April 19th, 2018 05:26 AM
Is this a loose cam chain? Cra1g 1986 - 2007 Ninja 250R Tech Talk 7 August 30th, 2016 06:53 PM
Loose chain remedy The_big_dill 1986 - 2007 Ninja 250R Tech Talk 11 October 31st, 2013 07:18 PM
I just wanna tighten my chain! poo poo 2008 - 2012 Ninja 250R Tech Talk 5 July 23rd, 2011 04:05 PM
Loose chain - really that bad? headshrink 2008 - 2012 Ninja 250R Tech Talk 42 February 11th, 2010 01:06 PM
