Old October 1st, 2014, 01:10 PM   #1
[motorcycle.com] - Metzeler Unveils Sportec Klassik Tire At Intermot
In many ways, owning a classic motorcycle is refreshing. Free of the technological advancements modern bikes contain, bikes from 40-plus years ago are simple mechanical things the average backyard mechanic can tame. However, there’s one element of old bikes that should remain in the past: tires. Tire technology has improved dramatically since the 1970s and the new Metzeler Sportec Klassik, unveiled this week at Intermot, gives old bikes the advantage of new rubber. The following is from a Metzeler press release.
With Sportec Klassik, the brand of German origins has taken the style of the glorious*ME1 CompK, the first tire with “bias belted” (MBS) technology launched by Metzeler*in the mid-80s, which became a hit among sports bike owners during those years. As a result of the most modern engineering technologies to offer the ultimate tire in terms of handling and safety even in severe weather conditions,*Sportec*Klassik*is in all respects a performance upgrade for those motorcycles that do not boast the most modern technology. By equipping their motorcycles with the new*Sportec*Klassik,*the owners will be able to revive their motorcycles thanks to modern tire technology while maintaining the vintage style and charm of their vehicles.
The Metzeler*brand worked on those elements of the tire that in recent years have been more subject to technological development, which are*tread design and materials.
The aim of the operation was to rejuvenate the entire vehicle safety while improving the stability, ride comfort and the behavior on dry as well as wet roads, always keeping in mind the importance of good mileage.
Particular attention was also placed in the consistency of the performance throughout the entire life cycle of the product. Metzeler*Sportec*Klassik*is built to wear in a consistent basis, and this aspect is one of the greatest achievements of the technological development in the field of tires.
In the past, to obtain a good level of safety in the wet, it was necessary to adopt a tread pattern with several grooves; the new*Metzeler*Sportec*Klassik*uses a reduced number of grooves thus being able to boast more uniform wear of the compound.
From a*compounds*point of view, the Research and Development Center of the Metzeler*brand has worked hard in recent years to develop more and more advanced chemical formulations that would ensure safety and traction on wet and dirty roads, as witnessed, for example, by the success of the new model in the Metzeler*range, the Sportec*M7 RR.
The same developments put in place for the new supersport product have enabled us to design the compound that allows the*Sportec*Klassik*to achieve excellent results in the wet, without exceeding the use of grooves and maintaining a design with a very high land-sea ratio.
The*tread pattern of*Sportec*is very robust because its footprint provides a high amount of rubber in contact with the road; both on the straight as well as when leant over. This not only offers advantages in terms of mileage, stability and road holding, but it means that all of these qualities remain after many kilometers and with the progressive wear of the tire.
The natural process of wear of the tread in*Sportec*Klassik*will therefore be homogeneous, without causing irregularities in the profile or footprint area. In this way, all the advantages of the design extend throughout the life cycle of the product. These solutions have resulted in a high mileage without resorting to excessively flattened profiles that would have affected the handling, a fundamental attribute for the bikes of today as well as for those of the past. The drainage capacity is ensured by parallel grooves that work in unison to disperse water that comes under the footprint of the tire. The development of the grooves in the direction of the shoulder of the tread provides a cross-section that grips the asphalt, to the benefit of traction especially on wet surfaces.
The evolution of materials has also covered the*carcass, stiff enough to ensure optimal interaction with the robustness of the tread. The structure thus reinforced of*Sportec*Klassik*allows a better stability of the motorcycle in the most critical phases of riding, which are cornering, braking and acceleration, contributing in an important way to improve the balance of the entire motorcycle. The balance of all the components of the tire helps the suspension to filter road irregularities better and keep a good line through corners.
Sportec*Klassik*will be available starting from Spring 2015 in the following sizes:
Metzeler Unveils Sportec Klassik Tire At Intermot appeared first on Motorcycle.com News.
Click here for full story...
[cyclenews.com] - Product Showcase: Metzeler Sportec M7 RR Ninjette Newsbot Motorcycling News 0 April 18th, 2014 04:51 AM
[motorcyclenews.com - news] - Video: Metzeler Sportec M7 RR exclusive test Ninjette Newsbot Motorcycling News 0 December 5th, 2013 04:02 AM
Metzeler Sportec M5 Interact ninjamunky85 General Motorcycling Discussion 2 April 26th, 2013 03:15 PM
[motorcyclistonline] - Metzeler Sportec M5 Interact Ninjette Newsbot Motorcycling News 0 September 10th, 2010 07:50 PM
[roadracingworld.com] - Thursday Video: Development Of The New Metzeler Sportec M5 In Ninjette Newsbot Motorcycling News 0 March 11th, 2010 01:50 PM
