Old July 17th, 2018, 06:03 PM   #1
ThePursuer
Motorcycle(s): 250r
Infrequent engine ticking at low rpm
The bike is very weak to start up and ticks. I start it with the choke on and leave it until the bike is warmed up. The ticking returns after turning the choke off and letting the rpm's fall. If I roll on the throttle too much the bike will stall. All issues seem to subside after the bike has been run for 10 minutes but the ticking will come and go. Does anybody have any idea what this could be?
https://www.youtube.com/watch?v=4HFbNbsbBQU
Ticking starts at the beginning then subsides. It dies after I apply throttle. Bike was just started no choke.
Last futzed with by ThePursuer; July 22nd, 2018 at 11:00 AM.
ThePursuer is offline   Reply With Quote
Old July 21st, 2018, 10:15 PM   #2
jp8484
Motorcycle(s): 2010 Ninja 250
https://www.youtube.com/watch?v=LLYPntxPBKw
First.. maybe check the oil level and I also noticed this not long ago and from what I gathered, it seems to be a common thing with this bike. Cam Chain tensioner is bit loose or something and needs bit of oil to be lubed when you first start the bike.
I don't think this is considered an issue.. but perhaps more experienced member can chime in on the topic.
jp8484 is offline   Reply With Quote
Old July 21st, 2018, 11:22 PM   #3
Also measure your valve-clearances and post them here.
Old July 22nd, 2018, 12:27 AM   #4
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
yup, i agree check your valve clearance
"trying not to get old"
Old July 22nd, 2018, 05:55 AM   #5
I think there are a few things going on.
As suggested, most likely a valve issue (can't tell, as the video has been removed) causing the ticking, but from the sound of it you may need some carb work and tuning as well. Cam chain tensioners can also cause some noise if they are not functioning properly.
You should be able to start it cold with moderate choke, then turn it off almost completely after a minute or so if it's tuned properly.
I'm guessing a valve adjustment and intense carb cleaning and adjusting are in order.
Old July 22nd, 2018, 07:50 AM   #6
Check the easy stuff first.
1. oil level AND for contamination
2. check for exhaust leaks
3. clean your cam chain tensioner
4. really, really, really bad gas
Also, does it tick only when when in motion?
Other things that can make noise;
Engine mount bolts, brake pad slides, frozen chain links, valves, steering stems, levers ect... ect..
You also might want to just redo a 600m service on the bike and ensure all bolts are tight.
I hope it something simple, good luck!
Old July 22nd, 2018, 10:07 AM   #7
ThePursuer
Motorcycle(s): 250r
Here's a video I reuploaded:
Thanks for all the help even with the broken video! Ill start going through the list this week. Does the video change any answers?
Old July 22nd, 2018, 06:28 PM   #8
Sounds like maybe perhaps cam-chain tensioner...
Just cleaned carbs - now stuttering at low RPM, fine at high RPM Ohio 2008 - 2012 Ninja 250R Tech Talk 20 August 5th, 2014 10:30 PM
Engine ticking sound Nosajong 2008 - 2012 Ninja 250R Tech Talk 4 May 21st, 2013 07:57 PM
Low rpm power not there? zzrguy 1986 - 2007 Ninja 250R Tech Talk 22 June 20th, 2012 06:37 PM
Can thinner oil cause engine ticking?? LoneRonin 2008 - 2012 Ninja 250R Tech Talk 7 June 11th, 2012 11:25 PM
Engine ticking at idle? JMcDonald 2008 - 2012 Ninja 250R Tech Talk 14 December 17th, 2010 10:11 AM
