Old February 28th, 2012, 08:40 AM   #961
kamikaze
ex-ninjette.org guru :o
kamikaze's Avatar
Motorcycle(s): 2003 SV1000 S
Originally Posted by kamikaze View Post
I was thinking about that too, anyone know off hand the measurements? I'm sure that hobby shop would have some nice stainless replacements
Originally Posted by Momaru View Post
Urg, I know I posted 'em around here somewhere. I'll see if I can dig 'em up
Edit: Yep, here they are
Short answer, they're 4x18mm, 0.7 pitch. If you can't find 18mm, I'd get mostly 16mm and a few 20mm. See the above thread for why.
Just to update this, I finally got around to replacing these last night and the screws are not 18mm long. The factory screws are 16mm long and have captive washers that you can't remove from the OE screws, so you may need flat washers and lock washers as well. the 18mm screws may be good for the 3 on the left carb that have the extra brackets, but they are way too long for the other holes, even with washers.
kamikaze is offline   Reply With Quote
Old February 28th, 2012, 09:37 AM   #962
MikeBudd
MikeBudd's Avatar
Motorcycle(s): RED 2010 Ninja 250r
That is completely correct. I don't know where those other measurements came from (I'm on my phone and to lazy to check), but I do know that in this thread (approximately 2nd or 3rd page), it had the correct measurements. I replaced mine according to those.I bought like 100 bolts for 12 bucks because I couldn't find anything smaller, then replaced them with the ones in the fp jet kit. Now I have tons extra if people need them. I also have extra #3 washers if people can't find them. Close to 80 of them left :P
PS: if anyone is going to jet with FP don't buy the replacement screws as they provide some high quality ones in the kit.
Posted via Mobile Device
MikeBudd is offline   Reply With Quote
Old March 4th, 2012, 11:48 AM   #963
Momaru
Momaru's Avatar
Odd. My sincere apologies for the mislead then. That may be a between-year difference on the carbs (or mebbe my bike's just special). Mine were/are definitely 18mm (checked it on every screw at least twice on two different rulers) and the washers will fall off if I don't prevent them.
Proud member of the Blue Army
Old March 4th, 2012, 03:35 PM   #964
MikeBudd
MikeBudd's Avatar
Mhmm. As far as I know they shouldn't be different. Did you measure just the bolt?
Old March 4th, 2012, 07:23 PM   #965
Momaru
Momaru's Avatar
Yup, just the threaded bit. If I include the head, it's 21mm. In retro-retrospect, mine may have been replaced by the previous owner, though he didn't mention any carb work on the top side, just new mains. Which, incidentally, had the bike running like shyte when I first got it...
Old March 4th, 2012, 08:03 PM   #966
MikeBudd
MikeBudd's Avatar
Interesting. Like @kamikaze if I put in 18mm bolts they don't fit. Do you have extra washers?
Old March 4th, 2012, 08:26 PM   #967
Momaru
Momaru's Avatar
Well... it's time I sat down for a slice of humble pie.
I've had the wrong set of screws. Been working off the sets I've got in my carb toolbox, which were pulled from the bike when I swapped out the screws a long while back. Now that I've found the real OEM carb screws the PO gave me, they're 14mm.
Not my day today, sorry about the mixup and misinformation all. I sincerely hope I haven't caused too many problems.
Old March 5th, 2012, 08:43 AM   #968
kamikaze
kamikaze's Avatar
no worries. So the OE ones that you measured were 14mm, is that with the washers? on my OE screws there is a flat washer and a lock washer that don't come off, which just by eyeballing looked to be a couple mm.
Old March 5th, 2012, 09:20 AM   #969
Mr.E
That rider dude.
Mr.E's Avatar
Motorcycle(s): 2011 White Ninja 250 SE.
Out of curiosity, how mandatory would you say the washers are? Going out in a couple of min to find screws. I already have about 4 or 5 screws in my carbs, and I'm pretty sure they're washerless because they were used to replace the screws I stripped. Also, I know they're the wrong size. I hope getting right size screws will make me feel better.
And I'm unshimming. My MPG took a huge hit and I feel like I have a flat spot. This is probably just because of unpropper mixing with the fuel and air, but if the bike ran fine (minus the long wait for start up) then I'll be fine returning to stock x-) lol
Mods: flushmount Led front binkers, diode mod, pazzo levers, clear tank pad, racing replica grips, bike monkeys integrated tal light, zx-2r vinyls, rearsets, red bar ends, and more red accented stuff.
Mr.E is offline   Reply With Quote
Old March 5th, 2012, 09:28 AM   #970
kamikaze
kamikaze's Avatar
I just added another shim to mine (2 total now, stock can & removed snorkel) and I'll see how it runs this spring. I was pretty happy with 1 shim last summer on premium fuel, but there was still a little flat spot around 8-9k.
Old March 5th, 2012, 10:17 AM   #971
Mr.E
That rider dude.
Mr.E's Avatar
Im currently at 2 shims lol. I tried removing my snorkle, but the bike ran like crap. So much so that I called the buddy that helped remove it and went to put the snorkle back in that night lol. But every bike is different. I'm just taking the easy way out and putting it back to stock, which for me had no flat spots or anything x-)
Old March 5th, 2012, 10:18 AM   #972
saxnbass
saxnbass's Avatar
Motorcycle(s): 2009 CBR600rr
Zach and I went down to 2 washers this weekend and we are both really liking it. We both have the snorkel removed as well. Pulls harder and smoother than with 3.
saxnbass is offline   Reply With Quote
Old March 5th, 2012, 10:40 AM   #973
oreX
oreX's Avatar
Motorcycle(s): 2013 636 - ABS
+1 to this.
I also think that three washers was killing the gas mileage.
oreX is offline   Reply With Quote
Old March 5th, 2012, 12:12 PM   #974
Not mandatory at all. My caps and bowls are held on with hex key screws and no washers on any of the 16 screws. No issues so far.
Although, I believe mine are also all M4x18 screws and I haven't had any issue with any of them. They just go through the holes and secure just fine... I followed Momaru's post on replacement screws also, and they worked out just fine for me.
The only screw I replaced that I did use the same washers on was the M5 screw that holds the throttle cable bracket on just because the oem screw is an M5x10, and I don't know how deep that hole is, so I figured it would just be easier to get a lock washer also and not worry about the depth of the hole.
Old March 5th, 2012, 12:45 PM   #975
kamikaze
kamikaze's Avatar
when i put the 18mm screws in without washers they bottomed out in the 2 or 3 holes I tried them in. I think 16mm with washers, 14mm without would be a better fit.
Old March 5th, 2012, 12:49 PM   #976
There's no bottoms in the holes on mine. they just go straight through. Next time I have them off, I'll measure them. It's possible I used 14's instead of 18's. idk. lemme go check my recent posts. I remember posting about it.
Old March 5th, 2012, 12:52 PM   #977
MikeBudd
MikeBudd's Avatar
Interesting, no harm done!
This has absolutely no effect on how your bike runs and is just eating a hole in your wallet. TBH stick to the recommended 87 octane 91 RON.
Yea, one of my friend had exactly the same thing happen. Removed the snorkel and his bike turned into a piece of poo. Put it back in and works perfect :P Every bike is different!
Same here, I haven't been using washers (just the socket cap screws from factory pro), and everything has been fine.
That's strange. I'm pretty sure when I tried 18's they wouldn't bolt down as they were hitting the metal that is a couple millimetres after the end of the hole. that's weird.
I didn't even bother replacing that screw yet. I'd have to go out and buy another 100 pack from fastenal or something because I haven't been able to find a smaller one. I'll do it eventually. Taking off the throttle cable bracket is definitely much easier than removing the cables and having to re-adjust them every time.
Old March 5th, 2012, 01:04 PM   #978
I figured out the discrepancy! I used M4x16 screws, which work just fine without the washers on the bowls and caps.
http://www.ninjette.org/forums/showp...postcount=1358
M4x18!! geez chone come on. Losing it here
Old March 5th, 2012, 01:16 PM   #979
MikeBudd
MikeBudd's Avatar
That's hilarious
Good to know i'm not loosing my mind though. I was just about to go check my bolts, praying that I was not crazy.
Old March 5th, 2012, 01:18 PM   #980
No worries, I hopped on the crazy train so you all didn't have to!
m4x16 for sure work without any washers, and they seem to work fine even on the corners that have brackets on them. But I have a pre-gen, so the brackets may be different. idk. When in doubt, buy 1 screw in a couple sizes, and see which one works best!
Old March 5th, 2012, 02:20 PM   #981
kamikaze
kamikaze's Avatar
Well, I beg to differ. after shimming the needles and pullin the snorkel it still ran like crap on 87. Started filling it with 91 and it ran much better, plus I get slightly better mileage.
Old March 5th, 2012, 05:19 PM   #982
Steven250R
Steven250R's Avatar
Motorcycle(s): 2009 NINJA 250R
Hey guys!
So ive read pretty half way through the entire thread and im planning on doing this to my 09 250R.
I live in the Bay Area and im planning to pick up some shims from the Radio Shack here in town.
I am also going to order a full exhaust, do an oil change, pull the snorkel out and throw some shims and figure out what works best for my setup.
I just wanted to say thanks for all the time and effort you guys put in, to give everybody a helping hand! Glad i joined the forum and will def post my results as soon as i gather all my parts together!
Thanks!
Steven250R is offline   Reply With Quote
Old March 5th, 2012, 08:00 PM   #983
Welcome to the Forum @Steven250R! Introduce yourself in the new member section so we can all say hi and get to know a little about you
If you're going with a full exhaust (and I would suggest de-snorkeling as well) I would pick up some 100 Keihin jets, and test them out in comparison to the stock 98 Keihin main jets to make sure that you have the main jets correct. Then shim
Old March 6th, 2012, 12:25 AM   #984
MikeBudd
MikeBudd's Avatar
Check out the video below. I'm not saying your wrong, but your experience doesn't equate when you look at what octane actually means and what higher octane does. Also refer to that thread for other info
Originally Posted by headshrink View Post
This video explains octane in a very simple manner. It's not my video, but I thought I would share it with the community here. You may enjoy some of his other motorcycle videos too.
Old March 6th, 2012, 08:20 AM   #985
kamikaze
kamikaze's Avatar
premium fuel is not just higher octane. some brands have no ethanol in their premium fuel, which I think makes a difference. Different additive packages as well.
either way, I've had good luck with it, and for the extra buck or 2 a tank, it's not exactly emptying my wallet.
Old March 6th, 2012, 11:33 AM   #986
Not so common here in the US. Companies are required by law to hit a minimum average company-wide for ethanol, and they can't remove it completely from premium and still meet those requirements. The additive packages are sometimes a bit different, though nothing so earthshattering that it makes any difference on an engine that is already working well.
Old March 6th, 2012, 11:37 AM   #987
TnNinjaGirl
Ms. Personality
TnNinjaGirl's Avatar
I would think since our engines have high compression that they would run better on the 91 vs 87 anyways. Does the ignition timing adjust itself? If so the higher octane would help performance/fuel economy as well.
Old March 6th, 2012, 12:08 PM   #988
Not in this case. There are no knock sensors that would allow the timing to be adjusted at all, and while the compression ratio is nominally high, the small size of the cylinders and the non-aggressive valve timing result in a lower effective compression.
These engines truly run just fine on 87, and receive no benefits from a higher octane rating.
Old March 6th, 2012, 03:45 PM   #989
MikeBudd
MikeBudd's Avatar
Wut he said ^
Old March 7th, 2012, 09:09 PM   #990
pilotgeorge747
pilotgeorge747's Avatar
Motorcycle(s): 08 Ninja 250r 03 Yamaha R6 (Project bike)
Originally Posted by oreX View Post
+1 to this.
I think I may go down to 2 washers as well. I have noticed my gas mileage did seem to be suffering a bit since adding the 3 washers. How much do you reckon it's changed since going down to 2 washers?
pilotgeorge747 is offline   Reply With Quote
Old March 7th, 2012, 09:44 PM   #991
saxnbass
saxnbass's Avatar
I gained maybe 5MPG on mine, not very significant in all honesty.
My Mods | My Bike's Ninjette Thread
Old March 7th, 2012, 10:19 PM   #992
pilotgeorge747
Well since I was bored I just went out and removed the 3rd washer from the carbs. Didn't get a chance to ride it yet but so far it seems like it will need a bit of time to warm up before it is ridable without the choke. At least from my bread test start after removing the washers. I'm also considering replacing the snorkle as I way to quiet the bike a bit. I'll wait Until I can try the bike out with 2 washers before I experiment with that though.
Old March 8th, 2012, 09:49 AM   #993
pilotgeorge747
Just took the bike for a quick test ride and it does seem to be smoother although I'm not sure if I'd say pull harder though. Also the warm up didn't seem that much longer than with 3 washers. Basically just enough time to put your gloves on after starting it. Hopefully gas mileage improves a bit and then I'll be happy.
Old March 10th, 2012, 01:21 PM   #994
cmSAE
Motorcycle(s): 2012 Ninja 250
im stupid
as the title says, i dont know anything about mechanical stuff. ive read some other threads about this, but i figured id just ask on one and see if i can figure my question out...
i have a 2012 stock (in engine mods) and im not sure whether or not this DIY is for me or not. like i said, i dont have an exhaust, still have my snorkel on, and no jet-kit (bc i dont even know what that is). I usually have to choke it for a min to warm it up, ive never stalled it, and i cant really tell if i have any dead areas on my high end rpms. im assuming that i dont need this, but if i get an exhaust system (looking at danmoto), will i need this?
cmSAE is offline   Reply With Quote
Old March 10th, 2012, 03:31 PM   #995
pilotgeorge747
You don't need to do it even with the exhaust but once you get some experience with the bike you MAY want to try playing around with it to see if you can improve the smoothness of the powerband. The only benefits I can see from you doing the shimming now is to smooth out the lower end of the powerband (which helps for new riders) and possibly less warm up time with the choke.
Old March 11th, 2012, 12:42 AM   #996
MikeBudd
MikeBudd's Avatar
This thread should answer all of your questions:
http://www.ninjette.org/forums/showthread.php?t=9465
Old March 11th, 2012, 08:10 AM   #997
cmSAE
mike, i read that and like i said above, i figured it would just be easier to ask rather then decide if my bike is/isnt in need of this mod
Old March 11th, 2012, 04:12 PM   #998
MikeBudd
MikeBudd's Avatar
Fair enough. Technically you don't need to shim your bike.
I would try it if you have any troubles starting your bike from a stop (don't have to have stalled to have troubles).
Personally, I would give it a whirl just to learn a bit about your bike. It does take some time the first time you do it, but you do learn about the carbs and how to take off the fairings and gas tank. Things you definitely will need to know how to do if you ever want to do any work.
Add one or two washers. If it doesn't work out and makes things worse, change it back and your good to go.
Just make sure you have the right tools, and don't strip the carb top screws. Buy new hardware for the tops as well (m4x16mm cap socket screws [allen key] work well).
Cheers buddy.
Old March 11th, 2012, 04:55 PM   #999
For the record, Ride it. That will tell you what it needs in the way of carb changes.
If you're completely in stock form, you don't NEED to shim, it just helps a little because the needles are just a touch lean and make the bike surge a little. If you don't notice anything when riding, don't worry about making any changes.
Old March 13th, 2012, 02:00 PM   #1000
Mr.E
That rider dude.
Mr.E's Avatar
Walked outside, saw my bike is leaking something, checked it out, Gas. Going to lowes to get me some screws now. Im pretty sure it's because I have improper screws in the carbs. This may be why my MPG went from 60 down to 30. :-\ I still think I may unshim, not sure yet though.
Shimming the Carb Needles... Is it for You? kkim 2008 - 2012 Ninja 250R Tech Talk 93 June 10th, 2018 05:25 PM
Shimming the carb needles kfilla General Motorcycling Discussion 2 July 2nd, 2014 06:14 PM
DJ Needles instead of shimming mxman38 2008 - 2012 Ninja 250R Tech Talk 7 May 30th, 2012 07:09 PM
Need help on shimming carb needles RedNinja21 2008 - 2012 Ninja 250R Tech Talk 6 October 27th, 2011 10:16 AM
FREE!!! 3MM Washers for Shimming Your Carb Needles kkim 2008 - 2012 Ninja 250R Tech Talk 1 September 10th, 2010 02:26 AM
