Old June 2nd, 2013, 02:45 AM   #1
psych0hans
psych0hans's Avatar
Ninja 300 oil change
Do you guys know which tool I need to do an oil change for the Ninja 300? I liked the old setup where all I needed was a couple of regular wrenches... Also, I'm sure this has been answered before, but how much oil does she hold?
Old June 4th, 2013, 07:23 AM   #2
Bump
Old June 4th, 2013, 08:03 AM   #3
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
I use the cup filter wrench, and the little adjustable wrench I keep in my underwear toolbox. Capacity is 2.5 quarts / 2.4 liters
Old June 4th, 2013, 08:17 AM   #4
psych0hans
psych0hans's Avatar
Pics please?
Old June 4th, 2013, 10:07 AM   #5
JohnnyBravo
Links are easier to post... http://www.ninjette.org/forums/showthread.php?t=115963
That will show the filter wrench
Adjustable wrenches are always in my toolbox, not always the best thing for the job, but used properly and with skill they do wonders!!!
http://m.sears.com/productdetails.do...1192011x000001
And if you can get one of these k&n filters it is def a plus, for me anyhow !!!
http://www.ninjette.org/forums/showthread.php?p=661494
Last futzed with by JohnnyBravo; June 4th, 2013 at 10:11 AM. Reason: Unfinished an needed futzink
Old June 4th, 2013, 10:09 AM   #6
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Oil filter wrench
AFM #676
Supersports are for n00bs
Old June 9th, 2013, 04:33 PM   #7
geeker
geeker's Avatar
Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold)
Use the same wrench as the last generation for the oil plug.
geeker is offline   Reply With Quote
Old June 11th, 2013, 12:57 PM   #8
Xtina
Xtina's Avatar
Motorcycle(s): 2013 Ninja 300, 2007 Gsxr 600, R6-sold :(
If it's for the first change you better get the screwdriver and hammer out. Factory has like 50lbs/ft of torque on it.
Also the manual says 2.2L for filter change and 2L without. But it was a little on the low side so I put about 100ml more in.
Xtina is offline   Reply With Quote
Old June 11th, 2013, 01:22 PM   #9
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Or just buy a damn oil filter wrench and be done with it.
AFM #676
Old June 11th, 2013, 03:35 PM   #10
lgk
would just use a rubber strap wrench on it.
1.99 at harbor freight, or just attach a rubber strap on to a piece of wood.
Old June 11th, 2013, 04:28 PM   #11
Brother Michigan
This is pretty much the only way to go. I went through three different types of cups trying to get mine off and they all either just cammed off or slipped. They'll be fine after the original filter is off, but not for the first go.
That definitely won't get it off.
Old June 11th, 2013, 04:29 PM   #12
antiant
antiant
antiant's Avatar
Motorcycle(s): None
MOTM - Oct '14
Have you already reached 600 miles?!?!
antiant is offline   Reply With Quote
Old June 11th, 2013, 04:47 PM   #13
Jiggles
Jiggles's Avatar
MOTM - Apr '13
I was able to get mine off of my Ninja 1000 and 300 which bother were tightened on there by retard apes at the factory with my oil filter wrench. After that I purchased K&N replacements which have a nut on the end so you can use a standard socket wrench on them
AFM #676
Old June 11th, 2013, 05:39 PM   #14
lgk
Thats surprising, lol.
The strap wrench took truck filter off when the cup wrench slipped.
Old June 11th, 2013, 08:01 PM   #15
Xtina
Xtina's Avatar
I used both and neither could get a grip on it. I'm not retarded
Old June 19th, 2013, 04:35 AM   #16
geeker
geeker's Avatar
Mine too. When mine is on too tight, I end up using a set of filter pliers to crush the can and spin it loose.
How To Change the Oil and Filter on Kawasaki Ninja 300 Motorcycle Video Tutorial SON1C 2013 - 2017 Ninja 300 Tech Talk 5 August 31st, 2014 10:01 AM
Synthetic oil at 300 mile oil change? anacron 2013 - 2017 Ninja 300 Tech Talk 14 July 29th, 2013 04:58 PM
