Old July 2nd, 2011, 07:01 PM   #1
ctruzzi
Motorcycle(s): Kawasaki Ninja 250r 09
250R Friction Zone Problem when not using throttle
Hi,
I have been having a problem with my Kawasaki Ninja 250r with 52 miles on it (been in garage for past 9 months because of the cold: live in Seattle). The problem I am having is after I heat up the bike and have the RPM's resting around 1500 when I try and have the bike move just while in the friction zone it dies. I had originally thought it could be a problem of not heated up enough (however I know that isn't it) and then my second thought was that I wasn't in-tune with where the friction zone is, however I am letting out the clutch very softly it will drop down to about 700RPMs, when I get the clutch to the throttle zone the engine changes sounds (which was what I was use to while taking the class) however the bike doesn't move at all. At this point I can always rev the throttle and let out the clutch the rest of the way and move in first gear but I cannot move while in the Friction Zone. If anyone might know what might be the problem I would love to hear. I am always willing to answer any questions you may have.
ctruzzi is offline   Reply With Quote
Old July 2nd, 2011, 07:21 PM   #2
you will always need to rev the bike a bit to get it to move from a dead stop with more than the idle rpm. what's makes you think you wouldn't?
Old July 2nd, 2011, 07:55 PM   #3
bob706
bob706's Avatar
One of the worst things you can do to your bike is not ride it. Too cold?? Get heated gear And give it some gas when your engaging the clutch.
Old July 2nd, 2011, 07:58 PM   #4
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
These bikes don't make as much torque at idle as the ones you learned on. I can roll mine forward when I'm parking with no throttle but that's about it, and I'm only like 140lbs wet and wearing boots
Felipe the Ant is offline   Reply With Quote
Old July 2nd, 2011, 08:00 PM   #5
Boom King
So, where's the reverse?
Boom King's Avatar
I can ride the friction zone all day on my bike without any throttle and my warm idle is around 1300 rpm. I don't know...
Old July 2nd, 2011, 08:36 PM   #6
ctruzzi
yeah this is what I was use to when learning, and those bikes where also 250 but where some type of Honda early 90's bike. It might be that the torque isn't high enough which means it cannot carry my 160lb frame. Was hoping there was some common problem to this, however in reality the bike is actually idling around 1000 (as when I try to change it jumps to 2000-2500) which could also be to low? But the manual said 1000-1500. If anyone else has any suggestions on anything I could attempt I would love to try.
One side note: I did try it when the bikes idle rpms were at 2000 (I know that's high and I moved it down) and even then it wouldn't coast in the friction zone.
Thanks
Old July 2nd, 2011, 08:47 PM   #7
Boom King
Boom King's Avatar
I don't weight much less than you do. About 150 -155 ish without gear. How far do you have to let the clutch lever out until you hit the friction zone? I'm not really sure what else I could suggest. Sorry and good luck.
Edit: Just to clarify, I only ride the clutch when I'm doing super slo mo maneuvers like in a parking lot. If you're trying to take off from a light, you definitely need to give it some throttle while you're in that friction zone as others have mentioned.
Old July 2nd, 2011, 08:47 PM   #8
The bike's doing almost nothing in the 1000 - 2000 range. Before you engage it to start moving forward, have the revs at 3000, 4000 or even more. Especially if the engine isn't warmed up and has sat for awhile, as you might find the low-speed running to be quite rough.
Old July 2nd, 2011, 10:28 PM   #9
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
When I put my bike away after riding it I use only the friction zone with no throttle to go up the driveway and into the garage and yes I start from a dead stop. The reason I go so slow is that I have to go between a boat and a car to get to my spot.
Then again, black bikes are more powerful =]
Old July 2nd, 2011, 10:39 PM   #10
I was assuming (and maybe it was a bad assumption) that the OP was referring to riding the bike, not just moving it like a granny, which I'm sure black bikes excel at.
btw, I would be cautious of moving it the way you are. one stall of the motor and you might not be prepared for the sudden stoppage and drop the bike.
Old July 2nd, 2011, 11:16 PM   #11
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Yes I am VERY CAREFUL. I will not be dropping my new found love. I keep the RPM's over 1000 and still get enough pull to go uphill.
What I meant though is that you sort of dismissed his problem of not being able to get the bike to move just using the friction zone. Of course on the streets you would need to use throttle to get moving fast enough but the friction zone should still move the bike without any throttle.
Error 387: Granny Comeback Not Found
Old July 3rd, 2011, 02:00 AM   #12
figures... people w/ black bikes wouldn't understand it anyway.
Old July 4th, 2011, 03:23 AM   #13
Domagoj
My bike will stall if I try to move it uphill without throttle. It has been like that from the day one.
I have a black bike, but I must admit that green is the fastest...
Old July 4th, 2011, 11:16 AM   #14
LazinCajun
LazinCajun's Avatar
Motorcycle(s): 2008 Ninja 250 (Blue!)
Don't forget you can give it a good amount of throttle and still go as slow as you want with good clutch control.
LazinCajun is offline   Reply With Quote
Old July 4th, 2011, 11:29 AM   #15
ctruzzi
I was mainly referring to being able to do this when parking or driving around in a mall parking lot with bastards not knowing how to drive faster then 3MPH. However going off from a traffic light like this I had also considered and not sure why that would be bad (if my bike could actually do it flawlessly.)
As towards letting out the FZ I had tested it by barely moving it and then holding it at a spot for a few seconds and then letting it out more and more, it just drops to 700RPM's then sputters off once the motor changes sounds which I had associated (when learning) as the FZ.
Well I shall screw with the bike some more and see if I can come to any solution.
Old July 4th, 2011, 05:50 PM   #16
Boom King
Boom King's Avatar
You shouldn't be doing this in traffic. You will stall and hold up traffic and risk having a cage slam into you. As others have said, taking off from a light or dead stop in traffic, you need to give this bike a little throttle as you ease into and ease out of the friction zone. As you start to ease out, gradually and smoothly give some more throttle. Practice this and eventually you will have butter smooth take offs.
Try to hold your clutch in the friction zone just enough so that it moves the bike. If you let it out too much, you will stall if you aren't giving any throttle. You have to "feather" the clutch. The friction zone on these bikes can be tricky for a new rider especially if you learned on a different type of bike during your course.
Just be sure you out rule rider error before you chalk it up to mechanical error and start fiddling around with the bike. Best of luck.
Old July 4th, 2011, 07:27 PM   #17
wayanlam
wayanlam's Avatar
Motorcycle(s): 2014 Z250
i hear that you can do this with the Hayabusa
rofl...
Kawasaki Z250, Bored up to 300cc with 12.8 CR, 41hp at wheel 27nm torque, Two bros full exhaust with DB killer
Dynojet Power Commander V, KnN Open filter, intake and exhaust ported, Puig Windshield
wayanlam is offline   Reply With Quote
Old July 4th, 2011, 09:22 PM   #18
Jiggles
Jiggles's Avatar
MOTM - Apr '13
TRAITOR!!!
Old July 4th, 2011, 09:53 PM   #19
wayanlam
wayanlam's Avatar
ps, generally i take the bike up to around 4~5k rpm if im starting from a dead stop (while on the bike). when hitting the friction zone, the rpm will drop a little if you dont compensate with more throttle, but usually its enough to get you going if you are on flat ground.
if i want to get going quickly, i take the rpm up to around 7~8k rpm.
note that im doing this only when im actually riding/sitting on the bike. i never move the bike with the engine while not actually ON the bike... if you want to just move it from one spot in the garage/parking spot to another, either push it in Neutral (engine off) or get on the bike and use the engine. its not hard to slip with the clutch and/or the throttle and have the bike jump out or stall suddenly, and you can easily end up tipping it over to the other side... or worse, dropping the bike on top of you, ouch... xP
Old July 6th, 2011, 10:53 AM   #20
ctruzzi
Thanks,
I will try and see if I can easily get use using the throttle right before going into the FZ. I will see about getting the RPM's to 4-5k prior to letting out the clutch to the FZ (or while doing it I guess once I get good at it). I had learned on a cruiser and the FZ was really really easy to get into and I was able to stay in it at pretty much a crawl. I will also see again if perhaps I though the FZ was at a different spot on the bike (though I don't think that was it... however most times when people think it's not them, it ends up being them). As well I was surprised how many with 250R's responded, this was quite helpful, I will update you on my endeavor as soon as I can. (Currently have the bike at a garage that doesn't cost $200 a month to park).
Old July 6th, 2011, 11:18 AM   #21
Craig... you'll find each make of bike differs as the gearing, torque and tuning of the specific engine has a lot to do with how much power is available at idle. Our ninjettes are more biased towards high rpm HP and w/ only 250cc's, there not much power to spread around.
I have a trials bike (tuned for low speed riding w/ tons of torque) that I've started by accident while it was still in gear w/o pulling in the clutch. It started right up and promptly fell over.
Friction Zone in the Cold Sykes92 2008 - 2012 Ninja 250R Tech Talk 6 December 16th, 2013 06:09 PM
Friction Zone. beqwarrior 2008 - 2012 Ninja 250R Tech Talk 6 January 1st, 2012 08:02 PM
Friction Zone Foom 1986 - 2007 Ninja 250R Tech Talk 4 July 6th, 2011 10:31 AM
Friction Zone FF0000 1986 - 2007 Ninja 250R Tech Talk 10 June 24th, 2011 12:33 PM
Help with the FRICTION ZONE tjb0012 Riding Skills 11 April 15th, 2010 05:07 AM
