February 1st, 2016, 09:46 AM | #1 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
Re-doin Valve Seats
Is 160 to get them done a good deal?
Also, the clutch cover gasket gets replaced everytime the clutch cover comes off right? |
February 1st, 2016, 06:22 PM | #2 |
Join Date: Jan 2012 Motorcycle(s): Race bikes:08 Ninja 250,11 R6,16 ZX6,SV650.3 HD-1947,2-2003,2010. 1946 Indian and a lot of dirt bikes.2 Posts: 999
are the replacing the seats or cutting them? I'll check what our local guy charges in the morning. If the gasket isn't ripped use it again.
February 1st, 2016, 06:26 PM | #3 | |
Did you do a leak-down test? http://www.dansmc.com/compression_test.htm [url]http://www.dansmc.com/leakdown.htm[/url Are you sure your low pressure comes from leaky valves? Leaky rings or/and guides of valves? Yes, the gasket gets ruined each time, unless you put grease on both sides of the gasket and it does not take too long to remove the cover again.
February 1st, 2016, 06:31 PM | #4 |
Motorcycle Nurse?
Cutting them. And I'm pretty sure that's where the fault is. One of my intake valves on the faulty cylinder was .012in
February 1st, 2016, 08:21 PM | #5 |
I mean... I've never looked into that because mine were in good shape, but that doesn't seem too bad for someone to do that work that has the proper reamers and setup for it.
You taking the head off and bringing it to them or are you delivering the bike and they're doing all the work? |
February 1st, 2016, 08:34 PM | #6 |
Motorcycle Nurse?
Already have the head off and boxed about. About to send it to HFD1 in Georgia
February 1st, 2016, 09:17 PM | #7 |
Well look at it this way: most machine shops and motorcycle shops charge somewhere from 75-100 dollars per hour. That means your valve seat cutting job is expected to take somewhere around 1.5-2 hours. Does this seem fair to you? If so, then it's a good price.
That seems fair to me, considering that they're cutting multiple angles and they're doing 8 valve seats in about 2 hours. That's just me. As for the clutch cover gasket: that's a paper gasket yes? If it's in good shape, get some good RTV (Yamabond or Threebond are two of the best for staying set up really well under oil and not getting gooey) and dress the gasket a little in RTV on assembly. Be careful not to goober it up in the case. If the gasket tears at all, replace it. Not worth the money to have to deal with drips. |
February 2nd, 2016, 04:45 PM | #8 |
Our local guy charges $175 to do a single cylinder, 4 valve MX head. that includes setting the valve lash when done so $160 sounds real fare.
February 3rd, 2016, 11:42 AM | #9 |
Board Member
APE Racing has decent prices as well....
February 10th, 2016, 01:40 PM | #10 |
Join Date: Oct 2014 Motorcycle(s): 2014 Ninja 300 Posts: 160
Thanks! lol
Just a heads up, angles aren't cut one at a time. The cutters are set up to cut them all in 1 go. The pain in the behind part is just getting everything lined up right. Thats why there isint a huge gap between a 4 valve head, and a 16 valve head. You can do all 8 on one side of a 4 cylinder nearly as fast as a 4 valve single because once you get the machine set up its a simple process of sliding over to the next hole. But the setup is the tricky, time consuming part... And DONT get me started on the stupid Honda thing where they have 4 valves in a chamber all pointing different directions!!!
I ride because therapy is too expensive, and less fun. |
February 10th, 2016, 01:41 PM | #11 | |
Vintage Screwball
MOTM - Mar '16
Goin' fast on slow bikes! |
February 10th, 2016, 01:45 PM | #12 |
Yeah, them... I forgot the acronym. Yeah, the bike was designed and first build in the 80s but its still produced. XR650. The TRX400ex uses the same design.
February 10th, 2016, 01:47 PM | #13 |
Vintage Screwball
MOTM - Mar '16
Really? That's surprising....I haven't torn in to a modern XR650 or 400EX. Figured they'd all have gone pentroof by now.
February 10th, 2016, 02:13 PM | #14 |
Yeah the XR has only changed plastics in the last 30 years. Maybe some minor bits here and there but most stuff is unchanged or interchangeable.
Case in point...http://www.partspitstop.com/oemparts...6-670/cylinder Btw, save that site to your favorites. OEM Parts fiche for nearly every bike made in the last 40 years, including our ninjette. I never buy from there but it helps figuring out whats what, what to call something, where its located, or just to look at the inner workings of stuff.
February 10th, 2016, 02:25 PM | #15 | |
Vintage Screwball
MOTM - Mar '16
February 10th, 2016, 03:22 PM | #16 | |
February 10th, 2016, 03:27 PM | #17 |
Vintage Screwball
MOTM - Mar '16
Eh, still not as bad as a Honda. Yamaha only requires three set ups for the three different planes. Honda is 4 planes no matter how you slice it.
February 10th, 2016, 05:30 PM | #18 |
What I dont get about Yamaha Titanium valve engines is how they can get away with 20k valve lash intervals when other Titanium or steel engines (like ours) are all under 10k... Titanium is VERY soft and its only a hard coating that keeps them alive for any time at all. Must be coated in Unobtanium!
February 10th, 2016, 08:00 PM | #19 |
Join Date: Feb 2016 Motorcycle(s): many mostly racebikes cbr565 fzr490 ex250ish Posts: 40
because they break before 20k.....I hate ti valves....great for short term sucks when it is time to do service work. Suzuki 1200.00 for just valves just stupid if you ask me.....
300 air switching valve and purge valve (CAL) removal | joyspring | 2013 - 2017 Ninja 300 Tech Talk | 21 | February 13th, 2017 01:36 PM |
Fixed valve cover bolt leak & valve clearances | Linkin | Videos | 3 | June 24th, 2015 03:49 PM |
new seats | YellowNinja | Pictures | 10 | October 10th, 2014 03:02 PM |
Dropped bike off for valve adj. v. New valve stems? | edxmon | 2008 - 2012 Ninja 250R Tech Talk | 14 | July 17th, 2012 04:55 PM |
Where to get Different Colour Seats | Sinical | 2008 - 2012 Ninja 250R Farkles | 7 | March 17th, 2012 10:23 AM |
