October 30th, 2011, 03:52 PM | #1 |
ALRE all day
Join Date: Apr 2011 Motorcycle(s): 2009 Ninja 250R SE Posts: 107
Milky Oil??
Hey there,
I changed my oil yesterday went for a short ride around the block and I check the level to find that it looks a little milky. Now its only 45- 50 degrees here but is that normal? I checked my coolant and it is not low and still green as always. What gives? Thanks in advance for all your help- Robert |
October 30th, 2011, 03:59 PM | #2 |
Join Date: Jan 2011 Motorcycle(s): 06 yzf r6r previously: 09 ninja 250r, black 07 zx6r Posts: A lot.
Did any water get in the oil?
October 30th, 2011, 04:01 PM | #3 |
ALRE all day
No not at all. Maybe condensation from the cold?
October 30th, 2011, 04:07 PM | #4 |
I've heard that even if a slight amount of water gets into the oil it can cause a milky / bubbly reaction to occur. Just something to keep in mind.
October 30th, 2011, 04:13 PM | #5 |
ALRE all day
I am going to take it around again get it really hot.
October 30th, 2011, 04:33 PM | #6 |
Milky oil is not unusual when the weather gets cold. Running the engine at its normal temperature solves the problem. It usually happens when the bike is used for short hops in the cold.
The Ninja is notoriously cold blooded so it takes a while to get up to operating temperature. I did not experience that problem as much when I switched to Synthetic Oil--Rotella T-6
Ninjette, Sold. New Bike: 2010 Honda NT-700V/VA, 73 Honda 550, 74 Honda 550 |
October 30th, 2011, 05:32 PM | #7 |
ALRE all day
OK Update. I took it out for about 20 miles and now its looking fine no more milk. So does that mean that it was related to cold? What a good ride.. Freezing can't feel my fingers
October 30th, 2011, 08:01 PM | #8 |
So, where's the reverse?
November 2nd, 2011, 05:09 PM | #9 |
Yep..just condensation on the inside of the sight glass...it wouldn't be fall if someone didn't ask that at least once on any given motorcycle forum. You can drain a little oil to make sure, or what you did...take it on a ride and re-check to see that it was just condensation.
November 2nd, 2011, 05:16 PM | #10 |
ah yes..good explanation here..
http://www.youtube.com/watch?v=VFU9g...eature=related |
Is it normal for oil to increase a bit in the crankcase after an oil change? | cadd | 2008 - 2012 Ninja 250R Tech Talk | 10 | May 15th, 2014 08:38 PM |
[roadracingworld.com] - Pets Named After Famous Racers, Part 52: Milky The Cat | Ninjette Newsbot | Motorcycling News | 0 | November 30th, 2013 01:11 AM |
milky/yellow oil after a valve job | quanttrom | 2008 - 2012 Ninja 250R Tech Talk | 24 | March 31st, 2012 04:39 PM |
[webbikeworld.com] - Substitute Ducati Oil Filters - Changing the Multistrada Oil and | Ninjette Newsbot | Motorcycling News | 0 | October 26th, 2008 05:10 PM |
