Old December 12th, 2012, 11:56 AM   #1
jayman87
Motorcycle(s): 2007 ninja ex250
Engine Rebuild Question
I’m just about done putting my engine back together. I’m trying to put the flywheel bolt(92002) back in the flywheel.
My question is how do I stop the crankcase from turning while I tighten the bolt.
jayman87 is offline   Reply With Quote
Old December 12th, 2012, 12:11 PM   #2
use a rubber grip tool (like what you use to grab an oil filter) around the hub.
Old December 12th, 2012, 12:44 PM   #3
jayman87
Something like this?
http://www.lowes.com/pd_253674-16878...1072405&rpp=32
Old December 12th, 2012, 02:28 PM   #4
it might work. make sure you double check torque specs
Old December 13th, 2012, 10:01 PM   #5
rickthefix
Crashing sux
Motorcycle(s): 07 EX250, 04 ZX6R, 96 Vulcan EN500, 79 XS650-SF, 80 TS185
I usually just use an impact drver, never had any issues with that.
rickthefix is offline   Reply With Quote
Old December 14th, 2012, 06:13 AM   #6
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I use an impact gun. If all else fails you can put the engine in the bike with the cover off. Put the chain on and hold the rear brake.
Worlds fastest 250 ninja
Old December 14th, 2012, 09:04 AM   #7
jayman87
I wanted to get an impact driver but I didn't want to get a cheap one. I'm between jobs at the moment (interview on Tuesday wish me luck) so the less money I spend the better.
I thought about doing that exactly, but I checked the engine's specs and it only puts out about 20 ft-lbs. The bolt requires about 51 ft-lb so I was afraid to I would break something.
Anyway the strap wrench did work, the bolt is secure. But this reminds me of something else. I have about a 3/8" of free play in the gears of my clutch basket. Is that cause for concern.
Old December 14th, 2012, 11:13 AM   #8
if i'm poor and need tools i'll usually go buy it, use it, then return it. harbor freight doesn't care since the tool only cost then $0.50c
Old December 14th, 2012, 11:15 AM   #9
which gear? the inner or the outer one? or the inner inner one? or the one on the side?? LOL maybe take a photo?
Old December 18th, 2012, 10:57 AM   #10
n4mwd
n4mwd's Avatar
For the flywheel, whatever you do, use a torque wrench for putting it back on. You can use an impact wrench for taking them off, but putting them on you need to make sure you don't overtorque it.
Are you sure the 3/8" is from the gears and not the basket itself.
My Ninja Blog
Old December 18th, 2012, 11:25 AM   #11
Gurk
Done here.
Motorcycle(s): -
do opposite of everything alex says or your engine will blow.
Gurk is offline   Reply With Quote
Old December 18th, 2012, 11:48 AM   #12
go have sex with a woman for once, gurk
Old December 18th, 2012, 11:53 AM   #13
Gurk
Done here.
Motorcycle(s): -
HAHAHAHHAHAHAHAHAHA
do i have to point the irony in this? when's the last time you had sex with a woman alex? 8 years ago?
Old December 20th, 2012, 02:51 PM   #14
jayman87
yeah that vid sums it up. My clutch basket has more free play than that. I'll look into a replacement.
Thanks everyone for you help
Old December 20th, 2012, 04:59 PM   #15
n4mwd
n4mwd's Avatar
They can be pretty loose and still work OK. I don't think its possible to find one that is perfect though.
My Ninja Blog
Old December 20th, 2012, 07:50 PM   #16
rickthefix
Crashing sux
I prob have one if you see you need it.
Old December 21st, 2012, 09:30 PM   #17
jayman87
I agree. I've been thinking about it and i can't remember there being any sign of a problem. The first time I even suspected a problem was when I pulled out the clutch basket and saw it move. So I'll let it go for now.
Cool, I'll keep that in mind
Racer X engine rebuild. Racer x 1986 - 2007 Ninja 250R Tech Talk 14 April 21st, 2018 04:26 PM
Engine Teardown and Rebuild Rustitution 1986 - 2007 Ninja 250R Tech Talk 77 February 27th, 2017 09:17 PM
Need Help Oil,engine rebuild meggyewill 1986 - 2007 Ninja 250R Tech Talk 10 July 22nd, 2014 02:39 AM
Engine Rebuild FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 210 November 2nd, 2013 07:16 PM
1996 CBR990 Needs engine rebuild FvnnyL3tt3r1ng General Motorcycling Discussion 7 February 7th, 2013 08:35 PM
