Old July 28th, 2015, 06:50 PM   #1
[motorcyclistonline] - 2016 Victory Empulse TT | FIRST RIDE
Harley-Davidson got lots of play out of releasing its LiveWire eBike prototype last year (click HERE for our First Look at Project LiveWire)—reportedly the biggest story in the history of The Motor Company in terms of pure consumer reach. Without a production component, however, it was largely a story without substance. It just put a gloss of futuristic innovation on what many consider an anachronistic company. Some leveled the same criticism at Victory earlier this year when it entered a one-off electric race bike in the Isle of Man TT Zero, but it turns out this wasn’t just greenwashing now that Victory Motorcycles has revealed the Empulse TT, its first production eBike.
If this bike looks familiar—you might even recognize the Empulse name—that’s because it’s based on the Empulse eBike sold by Oregon manufacturer Brammo before Polaris acquired all of Brammo’s motorcycle assets earlier this year. Victory did make some improvements in creating the TT, however, including an upgraded lithium-ion battery system with 10-percent more capacity, mildly restyled bodywork, a new dash, and lighter wheels.
RELATED: Polaris Acquires Brammo Electric Motorcycles
Aside from a larger, 10.4 kWh battery capacity, the TT powertrain is unchanged from Brammo spec, with the same liquid-cooled, permanent-magnet AC induction motor and a six-speed transmission. It’s the only eBike on the market equipped with a gearbox, which Victory says improves both range and acceleration, as well as making the bike more engaging for experienced motorcyclists to ride.
Because the bike hadn’t been publicly announced yet we rode the Empulse TT under embargo at Colorado’s High Plains Raceway, 60 miles from nowhere east of Denver, and found it—not surprisingly—very similar to the Empulse we were already familiar with. The bike fits and handles like an aggressive streetfighter (Triumph’s Street Triple was Brammo’s benchmark), the only departure being footrests that feel lower and further apart to make room for the electric motor mounted below the swingarm pivot. (Yes, the pegs drag early during aggressive cornering.)
Victory posts outputs at 54 horsepower and 61 pound-feet of torque and that feels about right, delivering acceptably brisk acceleration up to a 110 mph (indicated) top speed. Manipulating the notchy gearbox only provides a slight increase in acceleration compared to parking it in any upper gear. Shifting is entirely optional—you can also take advantage of the eBike ability to provide max torque at any rpm and operate it in twist-and-go mode for maximum convenience. The clutch is only necessary to change gears, not to start or stop the bike.
Dual, radial-mount Brembo brakes deliver strong, confident braking, appreciated because, at a claimed 460 pounds, the Empulse TT isn’t exactly light. You notice that mass on the racetrack, where the bike tends to fall into corners and overwhelm the adjustable (but undersprung) 43mm inverted fork, inspiring some reluctant steering under hard braking. Handling seems better at non-racetrack speeds, staying light and acceptably neutral around the paddock.
The racetrack is not necessarily the best context to assess range and any improvements thereof, either. Fifteen-minute track sessions in the more aggressive (of two available) power mode consumed almost 50 percent of the battery charge, so even if the range is improved with the new battery it’s likely not significantly improved over what we know from past Brammo experience, which was about 75 miles in combined mixed urban/highway use. (Victory claims “up to 140 miles of range per charge,” presumably under extremely conservative operation.) There is a regenerative charging feature, but during later sessions on an 80-degree day test units occasionally displayed an “REGEN OFF, BATTERY HOT” message. The 3.6 kW on-board charger can completely replenish the battery in 3.5 hours using a Level 2 supply, but it takes 8 hours with a (household) Level 1 power supply.
DON'T MISS Victory Motorcycles: High On Voltage
Even if the Empulse TT doesn’t break any new technological ground compared to the old Brammo bike, it still offers class-leading performance. And it’s certainly not cheap at $19,999. Still, this is the first electric effort we’ve seen backed by a major manufacturer—not a start-up—with the financial and engineering strength that Polaris brings to the table. This is just the beginning of eBike development for Victory, and it already puts Harley-Davidson—and every other major OEM, for that matter—in the position of playing catch-up.
TECH SPEC
EVOLUTION*Victory’s revamped version of the Brammo Empulse, with slightly more battery capacity and other detail changes.RIVALS*Zero STECH*PRICE$19,999ENGINELiquid-cooled permanent-magnet ACTRANSMISSION/FINAL DRIVE6-speed/chainCLAIMED HORSEPOWER54 hpCLAIMED TORQUE61 lb-ftFRAMEAluminum twin-sparFRONT SUSPENSIONMarzocchi 43mm fork adjustable for spring preload, compression and rebound damping; 4.7-in. travelREAR SUSPENSIONSachs shock adjustable for spring preload, compression and rebound damping; 4.7 in. travelFRONT BRAKEDual Brembo four-piston calipers, 310mm discREAR BRAKEBrembo two-piston caliper, 210mm discRAKE/TRAIL24.0º/3.8 in.WHEELBASE58.0 in.SEAT HEIGHT31.5 in.BATTERY CAPACITY10.4 kWhCLAIMED WEIGHT460 lb. wetAVAILABLEFall 2015CONTACTvictorymotorcycles.comVERDICT*7/10 Stars - The apex of eBike performance, but still very expensive and range-limited compared to any similar internal combustion bike.
Click here for full story...
Old July 30th, 2015, 11:22 AM   #2
allanoue
allanoue's Avatar
MOTM - Sep '14
I like the competition but I think I will still go with a zero come 2018 when I will be getting my next bike
I can not wait to see how good the e-bikes will be by then.
Old July 30th, 2015, 12:24 PM   #3
adouglas
adouglas's Avatar
Motorcycle(s): Aprilia RS660
Love everything about this except the $20k price tag.
This is very much like a Yamaha FZ-07, which costs $7k. Doing some simple math and making very generous assumptions about the cost of ownership of a gas vs. electric bike, you'd have to ride this for 12 years at least to break even.
Chop the time to break even in half and maybe we'll talk. That's about $13k. Get it to $10k and I'm heading to a dealer right now.
Old July 30th, 2015, 07:15 PM   #4
kdogg2077
kdogg2077's Avatar
Motorcycle(s): 2015 Yamaha FZ07, Ninja 250r 2012 Limited Edition (Sold)
Yeah these bikes are cool but they're just novelties for now. The only reason to get one is to brag that you had an ebike first.
Gimme a call in ten years when the price and range are way better.
"Take it easy driving. The life you might save might be mine."
kdogg2077 is offline   Reply With Quote
[motorcycle.com] - 2016 Victory Empulse TT First Ride Review Ninjette Newsbot Motorcycling News 0 July 28th, 2015 06:50 PM
[motorcyclistonline] - 2015 Brammo Empulse R | FIRST RIDE Ninjette Newsbot General Motorcycling Discussion 2 March 19th, 2015 02:42 PM
[motorcyclistonline] - RECALL NEWS: Brammo Recalls Certain Empulse and Empulse R Elec Ninjette Newsbot Motorcycling News 0 February 12th, 2015 09:20 AM
[motorcyclistonline] - Brammo Empulse R | First Ride Ninjette Newsbot Motorcycling News 0 January 16th, 2013 07:50 PM
[motorcyclistonline] - Aaron Gobert to Ride New Brammo Empulse RR at Red Bull Grand P Ninjette Newsbot Motorcycling News 0 July 21st, 2010 08:10 PM
