July 29th, 2015, 12:40 PM | #1 |
[motorcycle.com] - Honda Starter Relay Switch Recall Hits US, Affects 45,153 Motorcyc
Sharing the same component across multiple models has its advantages. Manufacturers don’t need to redesign relatively simple parts over and over again and can order them in large quantities, taking advantage of the economy of scale. The downside is when there’s a defect in the part, leading to recalls with headline-grabbing large numbers. That’s what happened here, as the Honda starter relay switch recall in international markets we’ve previously written about has finally reached the U.S., affecting 45,153 motorcycles (click here for the full list of affected models). According to Honda, the starter relay switch may have been incorrectly treated with sealant that may cause an increase in resistance through the main fuse, potentially interrupting battery voltage in the electrical system. Should this happen, the engine may fail to start or stall if already running. In the most extreme case, it may cause the starter relay switch to catch on fire. Honda dealers will inspect recalled units and replace any affected starter relay switches. The full list of U.S. models affected includes:
Click here for full story...
Is this a bad starter relay, or worse? | rottyfan | 1986 - 2007 Ninja 250R Tech Talk | 9 | July 12th, 2015 11:03 PM |
[motorcycle.com] - Suzuki GSX-R Recall Affects 210,228 Motorcycles in US | Ninjette Newsbot | General Motorcycling Discussion | 4 | June 11th, 2014 03:31 PM |
[motorcycle.com] - Honda CB500F, CB500X and CBR500R Recall Affects 6,954 Units in US | Ninjette Newsbot | Motorcycling News | 0 | March 10th, 2014 12:00 PM |
[motorcycle.com] - BMW Fuel Pump Recall Hits US, Affecting 50,184 Motorcycles | Ninjette Newsbot | Motorcycling News | 0 | January 6th, 2014 05:20 PM |
Starter Relay/Starter Problem | Time Mage | 1986 - 2007 Ninja 250R Tech Talk | 13 | July 13th, 2012 05:02 AM |
