August 4th, 2013, 12:26 AM | #1 |
Join Date: Nov 2011 Motorcycle(s): Ninja 250r Posts: 152
Annoying noise at 2,5-5 k RPM
Hi! i did a valve job on my bike one month ago... before the valve job, my bike had this rattle noise at 7-9k rpm... then i did the job, and all valves are now perfect, however the noise came back after 500kms, but now has the range changed so it is at 2,5-5k rpm...
could it be my CCT? i tried to reset it, and then there were no noise the first 10 kilometeres, but then it came back... |
August 4th, 2013, 05:41 AM | #2 |
And btw if it is a valve tapping, shouldn't it be there at all revs?!
August 4th, 2013, 06:12 AM | #3 |
How well did you reset it?
August 4th, 2013, 06:26 AM | #4 |
well i took it off... pulled it all the way in with a small screwdriver, hold it there while i screwed it back on (that part was hard as ****) and then i removed the screwdriver and heard the "pop" sound, so it should have been reset.
i have heard about a tip... screwing the CCT 2 mm out, so it pops out to next level, and then screw it back in. you think i should give that a try? |
August 4th, 2013, 06:47 AM | #5 |
By doing that, you would put excessive tension on the chain, accelerating wear.
August 4th, 2013, 01:56 PM | #6 |
tried it now, but no change... wonder what it could be
August 4th, 2013, 02:25 PM | #7 |
Then, I would take the cover off and verify the gap for each valve.
August 6th, 2013, 06:45 AM | #8 |
August 6th, 2013, 08:07 AM | #9 |
Sorry, I don't hear well anymore. Nothing catastrophic for sure, I would verify the valves' clearance, just to have some peace of mind.
August 6th, 2013, 08:35 AM | #10 |
narh it runs fine too... i will take the valve cover off and check it all again, but must wait 2 days before i have the time.. :/ will use my winter gs 500 in the wait time, (if it starts -.-)
August 8th, 2013, 10:52 AM | #11 |
Update:
Got the cover of, one ex valve was too lose. (0,32mm) i have fixed it now, but a little problem... when taking the camshaft holder off one of the 4 8mm bolts broke! so now i got half of it up and half of the 8 mm bolt is stuck (about 1 inch down in the hole...) How the HEK do i get it up! or can i live with the 3 other bolts? |
August 8th, 2013, 11:54 AM | #12 |
I would find a good machine shop and take the engine (or the bike-coordinate with them before) there for a proper extraction (they have the tools and the skills).
If the bolt snapped during un-bolting, is not going to be easy for you to pull it out with just hand tools.
August 9th, 2013, 08:09 AM | #13 |
ok so i tried to reassembly it all again got the screw fixed... and the noise is gone!!! But a new weird noise shows up :S its like the sound from a crow, actually thought it was a bird the first few times i heard it... it comes every time i give it some gas, just one at a time.. could it be wrong timing?
August 9th, 2013, 08:24 AM | #14 |
Did you verify the proper angular position of both camshafts? Does it sound like pre-ignition? http://en.wikipedia.org/wiki/Engine_knocking Could it be the noise coming from the external chain?
Rasping Noise Above 8k RPM | Finesse | 1986 - 2007 Ninja 250R Tech Talk | 10 | April 11th, 2014 01:22 PM |
Strange Noise at ~6000 RPM | forevertwowheels | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 20th, 2012 06:15 AM |
7k+ rpm makes strange noise | Graugaard | 2008 - 2012 Ninja 250R Tech Talk | 14 | June 11th, 2012 03:30 PM |
Mystery Noise at 4800 RPM? | jnninja250r | 2008 - 2012 Ninja 250R Tech Talk | 6 | May 11th, 2012 09:57 PM |
Rattling Noise from 8-9k RPM | 250fan | 2008 - 2012 Ninja 250R Tech Talk | 20 | August 1st, 2009 10:52 PM |
