Old August 23rd, 2016, 05:01 AM   #1
Petrolh34d
Motorcycle(s): 2004 ninja ex250, 1996 Honda cbr900rr
My rear shock blew
Well recently I blew the rear shock on my 2004 ninja 250. I ordered a new generation rear shock to drop in and I definitely want to upgrade the front. I noticed the front forks from the new gen are 37mm and the pregen are 36mm. Would these still fit?
Petrolh34d is offline   Reply With Quote
Old August 23rd, 2016, 05:45 AM   #2
Brother Michigan
Motorcycle(s): 2013 Ninja 300
No, you'd need new upper and lower triples at the very least, and I don't know if those would fit. Someone will be along shortly with all the information, I'm sure.
DISCLAIMER: I generally have no idea what I'm talking about.
Old August 23rd, 2016, 07:32 AM   #3
Ghostt
Ghostt's Avatar
An easier solution is to replace the fork springs with heavier ones, and changing the fork oil to a heavier weight.
http://faq.ninja250.org/wiki/How_do_..._suspension%3F
http://faq.ninja250.org/wiki/Which_t...ion_upgrade%3F
http://faq.ninja250.org/wiki/Front_suspension_upgrades
I've done the fork springs, I had an extra set from an EX500, so I cut them down, and then replaced the fork oil with 15wt, along with the rear shock from a ZX600 this set-up works for me.
http://faq.ninja250.org/wiki/Installing_a_ZX600_shock
IMHO upgrading the suspension on the Ninjette is the best upgrade one can do, and is a must do upgrade, and is the best bang for the buck.
Something else to consider is doing the fork seals and dust covers if there's any doubt about then. Nothing is more annoying than doing all that work, to only have them leak soon after, only to have to tear it apart again.
Finally is you have the extra cash laying around($180.00) get the Ricor INTIMINATOR
http://store.ricorshocks.com/product...20-1001nin.htm
Several members here have them and swear by them.
A Ninjette with the suspension dialed in, and a skilled rider will dominate the twisties .
violente et ignorantia
ZX-2R BLOG
Old August 23rd, 2016, 08:24 AM   #4
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!)
MOTM - Nov '15
@Ghostt: I think the OP may already have bought a new gen shock. Assuming he wants to use what he has; will a new gen shock just drop into a pre gen or are there changes that need to be made if it's at all possible?
Having said that; I agree with all your above suggestions
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over
SLOWn60 is offline   Reply With Quote
Old August 23rd, 2016, 08:28 AM   #5
Ghostt
Ghostt's Avatar
Good point, I read into it as he also wanted to do something about the forks, by swapping out the PreGen with NewGen. Not a bad option, but a cheaper easier upgrade would be to upgrade the PreGen forks themselves, springs, oil, INTIMINATOR, etc.....
ZX-2R BLOG
Old August 23rd, 2016, 08:34 AM   #6
SLOWn60
n00bie to wannabie
SLOWn60's Avatar
MOTM - Nov '15
So new gen & pre gen shocks are interchangeable without machining or whatever?
Old August 23rd, 2016, 09:31 AM   #7
VaFish
VaFish's Avatar
MOTM - Jan '16
I have not done the swap yet, but from everything I have read, yes.
Old August 23rd, 2016, 09:38 AM   #8
spent_too_much
spent_too_much's Avatar
Yes. I have used both a new-gen 250 and 300 rear shock in my pre-gen. It just bolts in. And, it only costs around $35 USD.
Old August 23rd, 2016, 10:16 AM   #9
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
And the EX500 shock is basically the same dimensions as the PreGen shock too (but the spring is about a 1/3 softer on the 500, and it has a preload adjuster). The NewGen/300 shock might be a tad longer, but it's in "lift the rear because I want to make it turn a little quicker" range, not "screw up all my suspension geometry" range.
I haven't seen much data posted for rear spring rate numbers, with nearly nothing on the PreGen. Some online calculators indicate that the NewGen/300 spring is too stiff for a lot of people - ideal for ~215lb. Whatever you end up with, check your sag to make sure the spring is in the right range for your weight. Too soft means too much movement, and it'll feel squishy. Too stiff means the wheel won't absorb bumps properly and will skip. Either one is bad, just in different ways.
And yes, definitely upgrade the fork springs. They're much softer than the rear spring to begin with, so going to the 18% stiffer rear will make that imbalance even worse.
Old August 23rd, 2016, 10:18 AM   #10
Petrolh34d
Thank you for the replies! Yes I have picked up a 2008+ rear shock and felt the front needed updating as well. I come from the world of automotive racing and upgrading the rear without touching the front usually results in excessive oversteering(not sure of the same applies here) so I definitely wanted to upgrade the fronts along with the rears. Thank you all for the suggestions
Old August 23rd, 2016, 12:02 PM   #11
spent_too_much
Great points. Yes, I am close to that 215 lb. range, and it is NOT too stiff for me.
Old August 23rd, 2016, 12:09 PM   #12
Ghostt
Ghostt's Avatar
ZX-2R BLOG
Old August 23rd, 2016, 07:51 PM   #13
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
someone not swapping a GSXRRRRRRRRR shock awed
Old August 26th, 2016, 09:49 AM   #14
Petrolh34d
So ended up with a 300 ninja shock instead. Should still fit. Now going to order the ricor intiminators as well as some .70kg front fork springs. Should be a nice bike after all that. Not to mention once my woodcraft lowered bars come in
Old August 26th, 2016, 01:35 PM   #15
JohnnyBravo
Congrats on your new shock... Keep us updated
I need suspension mods... But first track daaaaaaaay
Old August 27th, 2016, 08:13 AM   #16
InvisiBill
InvisiBill's Avatar
Originally Posted by Petrolh34d View Post
So ended up with a 300 ninja shock instead. Should still fit. Now going to order the ricor intiminators as well as some .70kg front fork springs. Should be a nice bike after all that. Not to mention once my woodcraft lowered bars come in :D
FYI, the NewGen/300 have .65kg/mm fork springs. If you can find some cheap, "pretty close" might be a better value than buying "exactly right" for full price. Also, the Intiminators are designed to use a lot of damping, so they can tolerate a softer spring better too.
I'm not trying to discourage you from spending money on the right parts, just pointing out an option that might be nearly as good for a lot less.
Old August 27th, 2016, 11:05 AM   #17
Petrolh34d
The front fork springs will fit? Aren't they 1mm thicker. If they fit, I found a set for 10 dollars which works for me. Lol
Old August 27th, 2016, 12:50 PM   #18
Ghostt
Ghostt's Avatar
Yes they fit
ZX-2R BLOG
Old August 29th, 2016, 06:42 AM   #19
Petrolh34d
Originally Posted by Ghostt View Post
Yes they fit
Thanks for that! I'll be getting the rear shock in tonight and the fronts should arrive by the end of the week. Super excited, I'll get to shake the new setup down at bear mountain this weekend!
Old August 29th, 2016, 06:37 PM   #20
Petrolh34d
Installed the shock today as well as the woodcraft lowered risers. I can't believe the difference the shock made! Bike actually feels like it wants to go around turns. I can't wait for the front springs to arrive.
Old August 29th, 2016, 07:03 PM   #21
Ghostt
Ghostt's Avatar
Your in for a pleasant surprise when you get the front done, and get it all dialed in.
I've always said the best bang for the buck is doing the suspension, add some new better tires, and you'll be amazed on how well it will do.
ZX-2R BLOG
Old August 30th, 2016, 08:57 AM   #22
spent_too_much
Are there any more $10 sets available? I could use 2 or 3 sets... eBay didn't turn up any deals today, but I am in no rush.
I too thought that they wouldnt fit. It is good to know that there are other inexpensive options.
Old August 31st, 2016, 07:13 PM   #23
Petrolh34d
It was the only set I've seen for sale on eBay. Here they are in all their glory!
Old October 10th, 2016, 07:50 PM   #24
Petrolh34d
After a few weeks of installing the ninja 300 springs with and 15w motul fork oil, the bike feels great. Really feels like a much newer bike. Now need to pick up a battery, this one died on me 2 days ago
Need New Rear Shock akima 2008 - 2012 Ninja 250R Tech Talk 30 September 24th, 2015 11:58 AM
Gixxer rear shock question - rear stiffness too high cookiebug79 2008 - 2012 Ninja 250R Tech Talk 20 January 17th, 2015 08:19 AM
Rear shock set to high (rear wheel slipping)? passive101 2008 - 2012 Ninja 250R Tech Talk 6 August 10th, 2014 08:45 PM
For sale: 2003 ninja 250 rear brake pedal and rear shock ReDnEcK Motorcycle-related 0 October 6th, 2010 12:02 PM
Replacing my rear shock with a newgen rear shock... ReDnEcK 2008 - 2012 Ninja 250R Tech Talk 4 September 10th, 2010 12:38 PM
