Old February 7th, 2013, 04:44 AM   #1
tubarney
Which size jets - Need help tuning carb
I'm removing the airbox and going with pods. I'm using Keihin jets. Which size main jet should I use? I have a full exhaust and stock carbs. I just need to get it run so I can ride it to the dyno.
Old February 7th, 2013, 05:35 AM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
40 pilot
110 main but that is a start point. Take some shims and larger and smaller jets
Worlds fastest 250 ninja
Old February 7th, 2013, 06:48 AM   #3
cuz
cuz
cuz's Avatar
Motorcycle(s): 09 ninja 250r
^^^This very good starting point.
Im #@ sea level w/pod & slip on (leo vince)
110 main jet
40 pilot
2 shims under both needles
THE GOOD LIFE
cuz is offline   Reply With Quote
Old February 7th, 2013, 06:48 AM   #4
tubarney
Thanks. Thats exactly what I got so I should be good to go. Was getting confused cos i couldn't find Factory Pro size conversion.
Picking up my head tomo. will post some photo's
Old February 7th, 2013, 06:49 AM   #5
cuz
cuz
cuz's Avatar
http://www.ninjette.org/forums/showthread.php?t=10208
THE GOOD LIFE
Old February 7th, 2013, 06:14 PM   #6
tubarney
Thats what I was looking at. One thing, are Factory Pro jets the same size as Dynojet or Keihin.
Old February 7th, 2013, 07:42 PM   #7
Keihin.
Old February 8th, 2013, 12:56 AM   #8
tubarney
^^Thanks for clearing that up. I thought they might be considering no one said anything about it.
With the factory Pro kit. How far does the needle jet move up when you put it on clip position 3?
Or how thick are your 3mm washers? Mine are only 0.68mm/0.027inch thick. I think i'm going to need more than 2.
Old February 8th, 2013, 07:39 AM   #9
If you have a factory pro kit, these instructions will help you out.
http://www.factorypro.com/tech_tunin...m_engines.html
The washers I used were roughly half a mm.
For starting, put the needle on the middle position. Worry about getting that right after you've gotten the main jet size figured out.
Old February 8th, 2013, 09:45 PM   #10
tubarney
thanks for the link and your help. Really appreciate it. I don't have the factory pro kit but everyone else seems to.
Just trying to get it as close as possible so save my tuner the effort cos his time aint cheap. It would help if my head was ready, not till next week.
Old February 8th, 2013, 10:30 PM   #11
cuz
cuz
cuz's Avatar
http://www.jetsrus.com/a_jet_kit_str...50R_Ninja.html
THE GOOD LIFE
Old February 9th, 2013, 10:03 AM   #12
If you want to help your tuner out, do the basics with the jetting; test different size mains until you get one that feels right. Then adjust needles until it feels right.
If the butt dyno says it feels smooth, it will be a good starting point for the dyno guy.
What did you have done to your head?
Old February 9th, 2013, 06:50 PM   #13
tubarney
I think I will have a go tuning it for a week before I take it in there.
My head is getting ported on a 5 axis CNC machine by guys with a flow bench. The guys doing it service the entire race industry of my state so I'm not surprised it aint ready.
Whats burning me the most is that I can't get Keihin or even Yoshi carbs until early April because both are on back order.
Old February 9th, 2013, 08:54 PM   #14
Ah. Flowbench. Nice!
I don't have any reference point for jetting a bike with head work, so the only advice I can give you is on method of testing jetting.
Old February 9th, 2013, 09:18 PM   #15
tubarney
Jetting settings are the same for a ported head. A free flowing head does not change the ratio of air or fuel entering the combustion chamber. Just more gets in.
The only thing you need is a set of good carbs. This is when you will get a decent gain from carbs. The mixture of air/fuel will be slower through the larger ports (even if you don't want them bigger, they have to be smoothed out so they will always be bigger), so you need something to speed that mixture up before it gets into your head.
Old June 24th, 2013, 03:11 PM   #16
agentbad
agentbad's Avatar
Where is a good place to get the #4 shims/washers? Lowes?
Old June 25th, 2013, 07:56 AM   #17
subxero
dirty boy
subxero's Avatar
MOTM - Apr '14
you can find some at lowes. I got mine at lowes. I also found some at a Hobby shop later that were a little smaller that i liked better.
size of jets with full leo vince Braden07 2008 - 2012 Ninja 250R Tech Talk 9 August 16th, 2014 09:28 PM
help plz. wideband afr fine tuning the carb MikeJames21 2008 - 2012 Ninja 250R Tech Talk 20 June 12th, 2012 07:47 AM
Carb tuning help (yes, I've searched) THE BIG SITT 2008 - 2012 Ninja 250R Tech Talk 38 April 6th, 2012 04:52 AM
Carb tuning zzrguy 1986 - 2007 Ninja 250R Tech Talk 2 April 5th, 2012 03:06 PM
stock size jets??? scorpio_vette 1986 - 2007 Ninja 250R Tech Talk 13 July 20th, 2009 11:15 PM
