Old December 28th, 2016, 05:44 PM   #1
magnaton
Motorcycle(s): '06 Ninja 250
Aftermarket LED tail light -- brake light not working
Hello!
I replaced the tail light on my street fighter ninja, and while I'm pretty sure it's wired up correctly, it's not functioning properly.
Tail light is always on, and brake light doesn't activate when i depress either lever. Everything was working as it should before the swap.
Was searching around and saw some info on a load balancer/ resister, but I was under the impression that this was only necessary for LED turn signals, not an LED brake light.
I'd add that since I have no reference point, it's also possible that the brake light is always on -- there's just no noticeable change when activating the brakes.
Help please
magnaton is offline   Reply With Quote
Old December 29th, 2016, 07:51 AM   #2
taz
taz's Avatar
MOTM - May '17
More info like what brand and were you ordered it from is it an ebay special, some of them are broke before they even get to you.
Old December 29th, 2016, 08:09 AM   #3
I would expect the unit to have three connections:
1. input to tail light
2. input to brake light
3. ground
Assuming your ground connection is good, then applying 12v to each of the other two should light up that LED or group of LEDs. You shouldn't need any other external components to make that work. A bad ground connection could make odd things happen, but I'm not sure that's your problem, or your only problem.
Old December 29th, 2016, 06:44 PM   #4
magnaton
All fixed I swapped the two positives. Whoops
Thanks for the help everyone
Old December 29th, 2016, 07:31 PM   #5
taz
taz's Avatar
MOTM - May '17
your welcome
Old December 29th, 2016, 07:56 PM   #6
OK, so the brake light was on all the time, and adding the tail light didn't make a noticeable difference, I guess.
Old December 29th, 2016, 08:01 PM   #7
magnaton
Yeah, that's exactly it
Tail Light + Brake Light Not Working (Bulb Replaced) JayZE302 2008 - 2012 Ninja 250R Tech Talk 11 August 8th, 2012 05:03 PM
OEM Tail/Brake Light Comparison to LED Tail/Brake Light g21-30 2008 - 2012 Ninja 250R Farkles 19 November 7th, 2009 12:08 PM
