#1 |
Join Date: Aug 2012 Motorcycle(s): 2012 Ninja 250r Posts: 28
driven clip ons sorta clearance issue
So i installed driven clip on yesterday and I found the best position for the bike with how i like it. Both levers miss the from fairing however I have a issue with the risers hitting the black cowl. I am okay with them hitting that since it's towards the inside the bike but I would like to put something there. Possibly some type of rubber with some 3m tape. ?
Or Is it better to find a spot on the forks that would avoid this issue. If i were to go a tad higher I think I'd be able to do that although I can't recall if it would work that way. Also if I were to add weight inside the bars like aluminum or steel is there a thing of too much weight in the bars. My father is a machinist and I know if i asked him he would make up something. Thanks in advance |
#2 |
I also wanted to add for people is i slightly turned the front brake line at the lever itself. I would be careful not to loosen it hardly at all since any air that gets in there will not be good for braking. At all so be careful. Since there was a fair amount of tension on that Brake line itself I seen a bracket further down the forks. I took that off and drilled a new hole in that. I found a long enough bolt so i could use washers to space the brake line off the bracket. Its easier to show you a picture of what i did that type it. It freed up a lot of tauntness from the brake line itself. Which gave me more freedom
Driven Clip-ons Installed | Redgeneral | 2008 - 2012 Ninja 250R Tech Talk | 16 | May 1st, 2015 05:47 AM |
Front Brake Cable issue w/ Driven Clip-ons | Sirena | 2013 - 2017 Ninja 300 Tech Talk | 9 | April 2nd, 2015 11:08 AM |
Best prices for Driven Clip ons? | jp129 | 2008 - 2012 Ninja 250R Farkles | 6 | February 15th, 2012 09:08 AM |
Driven Clip-Ons | cuong-nutz | 2008 - 2012 Ninja 250R Farkles | 10 | December 28th, 2011 09:46 PM |
Clip-ons Installed, now Clearance Issues | KURT | 2008 - 2012 Ninja 250R Tech Talk | 10 | February 22nd, 2011 10:19 PM |
