Old February 19th, 2014, 03:23 PM   #1
smokinsingle
L8APEX
smokinsingle's Avatar
Motorcycle(s): 07 KTM 950SMR, 06 KTM 450SMR, 99 KTM 300MXC, 00 Derbi GPR 50, 09 Ninja 250 racebike, race with www.cra-mn.org!
Fixed my warped front rotor
Went for it. Bought the Braking rotor. Rebuilt the master, caliper, and installed a direct inlet banjoless line. I had so, so much brake drag before, gone now. I never would have thought the rotor could be so dished and still feel so smooth at the lever.
www.joemillersmoderngarage.com www.starr-cycle.com
***The most important concept of science isn't memorizing facts, it's observation of phenomena.***
smokinsingle is offline   Reply With Quote
Old February 19th, 2014, 03:43 PM   #2
dino74
dino74's Avatar
Nice! where did you get the rotor from?
CVMA #55
Old February 19th, 2014, 03:59 PM   #3
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Yeah I had this theory about flipping the rotor at set interval like oil changes so see if it would start warping the other way and straiten it sell out. But then I modded the front end to run an R6 front wheel and R1 rotor so I haven't had a chance to test my theory.
Old February 19th, 2014, 04:08 PM   #4
smokinsingle
L8APEX
Western Power Sports, we're a dealer at my shop.
Old February 19th, 2014, 08:04 PM   #5
mgentz
Board Member
Where did you get the brake line? custom?
Old February 20th, 2014, 07:36 AM   #6
sierrahotel
CVMA #92
Motorcycle(s): harleys
Where did you get the caliper rebuild kit? I looked around and didn't see one.
sierrahotel is offline   Reply With Quote
Old February 20th, 2014, 07:59 AM   #7
smokinsingle
L8APEX
Half of a Galfer kit for a ZX10 from Ebay
OEM Kawasaki parts, had to piece it together form the part diagrams.
Old February 20th, 2014, 09:18 AM   #8
tooblekain
tooblekain's Avatar
Motorcycle(s): 2007 Triumph Bonneville; 2008 Ninja 250r (trackbike)
Do you have the Braking part # for that rotor? Ive been trying to find it on their site and cannot find it.
*CVMA #312*SoCal Trackdays*BigHeadz Racing*Motion Pro*Factory Effex*Leatt Brace* Racetech *Bell * Woodcraft CFM*Vortex*Hotbodies*Surface Sun Systems*Braking*LiveWire Energy*Freegun Underwear
tooblekain is offline   Reply With Quote
Old February 20th, 2014, 09:24 AM   #9
smokinsingle
L8APEX
BRAKING ROTOR WK SERIES RIGHT
Vendor Part #: WK103R
Old February 20th, 2014, 10:15 AM   #10
mgentz
Board Member
where did you get the rotor from? I have liked this rotor and thought about buying it many times, but now most places are out of them.
does the brake like fit well? i.e. no slack or excess? What about the MC fitting, are you using a radial MC or the stock one? I am thinking about getting a brembo master but I would have to buy a new line anyways....
Old February 20th, 2014, 10:44 AM   #11
smokinsingle
L8APEX
It fits pretty good. One line of the kit is longer than the other, I used the shorter one and it's still just an inch or two longer than I'd like. I'm using the stock master as required by my racing organization's rules. The top banjo is a 30 degree bend unfortunately, I'd like it to be straight ideally but it works if you point it towards the rear and go around the back of the fork leg. I'll get a picture up.
If you get a Brembo radial I believe the banjo fitting faces the ground so you'd need a line with a 90 degree bend int the top fitting.
Old February 24th, 2014, 01:40 AM   #12
shane liberty
shane liberty's Avatar
Motorcycle(s): None Yet
That rotor looks pimp. Is it legal for Supersport?
shane liberty is offline   Reply With Quote
Old February 24th, 2014, 04:51 AM   #13
mgentz
Board Member
It should be but can depend on your organization
Old February 24th, 2014, 07:51 AM   #14
smokinsingle
L8APEX
At my races it is. They allowed single rotor bikes to upgrade to a floating rotor as long as it's the same diameter.
Old February 24th, 2014, 10:04 AM   #15
tooblekain
tooblekain's Avatar
Yes, it is legal for CVMA supersport. I was the one that brought on the request on the SCM forum.
As for the gixxer rear shock mod...I think they are still working on it.
Old February 24th, 2014, 05:09 PM   #16
shane liberty
I didn't want to do the GSXR swap when I got the ninja. I tried it with my SV back in the day and it shagged out tires too quick. I ponied up for the JRI and I'm glad I did. I think with suspension, at least now, I won't cut corners for my race bikes. You end up spending more on tires trying to fix a bad setup than if you just have a pro build you a proper shock that doesn't shred rubber
Old March 3rd, 2014, 06:16 PM   #17
smokinsingle
L8APEX
True that!
Old March 6th, 2014, 07:22 PM   #18
racegunnr
racegunnr's Avatar
Motorcycle(s): 09 250r race bike, 06 R6 race bike, 06 YZ450f Tard
We will have to see if this starts a fad in the CRA Sam......being you and Drew will be up front all the time with flashy new Braking rotors!
racegunnr is offline   Reply With Quote
Old March 7th, 2014, 01:03 PM   #19
smokinsingle
L8APEX
Ha ha, we'll see!
Old March 7th, 2014, 04:03 PM   #20
the big mike
the big mike's Avatar
Motorcycle(s): 2008 Ninja 250r, Fazer8
I have huge vibrations when braking, but I don't want to spend the $200 on a new disk.
How much time and money did this cost you?
I can not be a true player by playing around.
the big mike is offline   Reply With Quote
Old March 7th, 2014, 06:23 PM   #21
Use a crescent wrench. Lift the front off the ground. Spin the wheel. Use the wrench to bend the disk in the spots where it rubs and true the disk. It should work temporarily. That's how I true the disks on my MTB. I get that I'm used to a smaller example, but the idea is the same.
Old March 7th, 2014, 07:14 PM   #22
mgentz
Board Member
Just get a different rotor. Why put your life at risk for $100-$300 dollars?
Old March 8th, 2014, 08:04 AM   #23
smokinsingle
L8APEX
Here's a decent price on the rotor: http://store.58cycle.com/Braking_WK1...Fa9cMgodNl8ARQ
Warped rotor The_big_dill 1986 - 2007 Ninja 250R Tech Talk 4 August 11th, 2013 04:13 PM
Warped Front rotor? k24_cm7 2008 - 2012 Ninja 250R Tech Talk 28 January 9th, 2012 12:03 AM
WTB: Pregen Front Brake Rotor - NON WARPED! SV_Hadder Items Wanted 3 April 8th, 2011 09:31 AM
Warped front rotor? SV_Hadder 1986 - 2007 Ninja 250R Tech Talk 7 October 25th, 2010 01:28 PM
