Old May 2nd, 2014, 06:34 PM   #1
scorch
scorch's Avatar
Motorcycle(s): 250
Do fork legs from old gen fit new gen?
So pretty early on my mileage on my 08. at around 40k. The fork seals started to leak. And i remember my mechanic told me that it had some scratches on the fork leg and that was the cause.
I ordered some new seals on the intention of fixing my fork seals now at 80k . And completly forgot this detail he told me. So my question is, can old gen ninja fork legs fit the newer ninjas? I just need the upper part. I hate to have parts i dont need around too.
I tried buffing it and sanding it, but its a little too deep to removed. Not sure how i got it. But i wish i had some fork protection so this would not happen.
scorch is offline   Reply With Quote
Old May 2nd, 2014, 08:03 PM   #2
Insane Pie
Motorcycle(s): '08 Ninja 250
Old gen forks are 36mm in diameter and new are 37mm.
Insane Pie is offline   Reply With Quote
Old May 2nd, 2014, 08:09 PM   #3
Skullz
Skullz's Avatar
Motorcycle(s): 2012 Ninja 250
You could try some jb weld on the nick by filling it in and removing the extra and buffing it as smooth as you can.
Old May 6th, 2014, 06:22 PM   #4
scorch
scorch's Avatar
Motorcycle(s): 250
thats a great tip. im going to try that. thanks!
Old May 6th, 2014, 06:29 PM   #5
sounds like a disaster waiting to happen
Old May 7th, 2014, 04:37 AM   #6
scorch
scorch's Avatar
Motorcycle(s): 250
What do you think will happen?
Old May 7th, 2014, 05:08 AM   #7
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
JB weld will not fix a scratch in a fork leg. The scratches are very fine and the JB weld will not hold on the fork. You need new forks.
Worlds fastest 250 ninja
Old May 7th, 2014, 07:50 PM   #8
As many have pointed out, the fork legs will not fit but the entire triple WITH forks, 17" wheel, brakes, etc...WILL.
Old May 9th, 2014, 08:37 AM   #9
scorch
scorch's Avatar
Motorcycle(s): 250
so far after changing the oil and adding the seals it is not leaking. Im hoping it wont leak But so far only did 240 miles on it. So ill let you know in a few thousand miles if its leaking. Meanwhile im might look on ebay for new tubes.
Pre Gen Fork Seals?? Dsheumaker 2008 - 2012 Ninja 250R Tech Talk 3 March 27th, 2015 04:59 PM
Pre-gen Fork Clunk dcj13 1986 - 2007 Ninja 250R Tech Talk 5 February 7th, 2014 08:26 PM
new gen mirrors fit on pre gen? juanpak87 1986 - 2007 Ninja 250R Farkles 2 September 9th, 2013 01:53 PM
Compare new-gen and old-gen fork inner/upper tube abhijitz 2008 - 2012 Ninja 250R Tech Talk 2 February 23rd, 2013 09:22 AM
Does Preg-gen Carb. fit New-gen? headshrink 2008 - 2012 Ninja 250R Tech Talk 29 October 31st, 2009 09:28 PM
