Old November 26th, 2016, 12:10 AM   #1
Mechanikrazy
Mechanikrazy's Avatar
Motorcycle(s): Thruxton R, R6 450 triple, EX300 (sold)
Clutch Cable Replacement Trick/Tip
Maybe this is obvious, but I did not see anyone post about replacing the clutch cable without pulling the fairings. When I did a search, it seemed like people are following the manual, which includes removal of the mid-fairing (also means dropping the lower fairings). If you happen to be supremely lazy like I am, there is a much faster way.
With this method, all you have to do is loosen the two ends of the clutch cable.
From the top, lever-side (this trick has to be done from the top; explained below), just duct-tape the end of the new cable to the top end of the old cable. It must be tip to tip though, due to size constraints. What I did is helically wrap the cables for about a foot (6 inches of each cable). You can probably get away with less, but duct tape is cheap and I wanted to make sure the cables wouldn't pull out.
Then just push/pull the cable from both ends to pull the cable out from the bottom side. There is only one hiccup point--why you have to pull downwards--which is a cable holder at the front right side of the gas tank after the clutch cable has passed through the frame. The two bolts at the bottom of the clutch cable are really tight fits. You have to make sure the sides of the bolts are parallel to the sides of the holder. But you can pull it through with the right angle.
All that is left is to reattached the cable at both ends. This simplifies your clutch cable replacement immensely. Hope this saves time for some of you. I tried to take a video of it, but my old GoPro sucked with low-light/contrast.
Mechanikrazy is offline   Reply With Quote
Old December 3rd, 2016, 09:04 PM   #2
Old December 3rd, 2016, 09:50 PM   #3
Excellent idea! I've done things like this with wiring in houses, etc., but I don't remember applying it to motorcycle cables.
Old December 3rd, 2016, 10:41 PM   #4
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
The method you describe also assures correct routing.
Old December 3rd, 2016, 10:48 PM   #5
Mechanikrazy
Same. I've done the fishing line method before, but working in an apartment garage (with a no repairs policy) has made me try to shortcut as much as possible. Haha.
Next job, fiberglass patching.... Hah
clutch cable replacement james250ninja 1986 - 2007 Ninja 250R Tech Talk 3 April 20th, 2015 11:54 AM
Please help!! Clutch cable replacement complication Dustinfools 2008 - 2012 Ninja 250R Tech Talk 31 November 29th, 2012 01:34 PM
Grip Installation Trick/Tip cuz 2008 - 2012 Ninja 250R Farkles 11 November 27th, 2011 11:29 AM
2008 model clutch cable snapped @ 17,800 miles. Replacement? CZroe 2008 - 2012 Ninja 250R Tech Talk 9 December 14th, 2010 05:40 PM
Carb Sync Trick/Tip WindMeUp 2008 - 2012 Ninja 250R Tech Talk 7 August 28th, 2010 08:30 AM
