Old December 31st, 2016, 04:02 PM   #1
chuime
Motorcycle(s): 2013 Ninja 300. Previous 02 CBR 600f4i and 06 ninja 250
Condensation on turn signals/instruments
New Ninja 300 rider here
My speedometer where the clock is and my turn signal seems to have condensation/water collecting in behind the plastic cover.
Is there a way to remove them/keep water from collecting there? It hasn't rained in the time I've owned it so not sure where/how it got there.
Thanks for the help =D
chuime is offline   Reply With Quote
Old December 31st, 2016, 05:10 PM   #2
Welcome, Andrew !!!
The air inside those instruments has more steam or humidity or dissolved water than normal.
When temperature of that air drops, some of that steam becomes water or condensation because the air cannot dissolve as much as when it is hot.
If the instruments are hermetic, the cycle of condensation/evaporation will continue forever, as the amount of water will remain inside forever.
If the instruments are not hermetic, condensation will happen sporadically when it is cold outside after being hot/humid.
If the instruments are hermetic, the only way to fix the problem is by drilling a little hole in the envelope, cool it and reseal it.
Old December 31st, 2016, 06:33 PM   #3
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
Physics is like that.
Hermeticity is difficult to achieve with consumer grade electro-mechanical instruments.
I wouldn't worry about it. Pretend you're riding a BMW. "They all do that." (DAMHIK)
Old December 31st, 2016, 06:35 PM   #4
dcj13
Participant
dcj13's Avatar
Oh... Welcome to the forum, Andrew! Lots of good info and nice folks here.
Old December 31st, 2016, 08:03 PM   #5
chuime
Thanks for the warm welcome.
I guess I won't have to do anything to it then.
Thanks for the headsup.
Old December 31st, 2016, 08:11 PM   #6
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old January 1st, 2017, 07:50 AM   #7
snot
sammich maker
snot's Avatar
MOTM - Apr '15
Welcome, I have never had this issue with my 300. If it bothers you to much you could try an aftermarket panel.
Old January 1st, 2017, 08:48 AM   #8
I would park it in direct sun for a while and see if it will evaporate the moisture.
Old January 1st, 2017, 01:41 PM   #9
chuime
Thanks for the advice. I think it's probably a sporadic occurrence since I woke up to ride today and it disappeared.
Old January 2nd, 2017, 08:16 AM   #10
taz
taz's Avatar
MOTM - May '17
Good to hear the problem might have fixed it's self, and welcome.
Condensation on my bike? jjmaine 1986 - 2007 Ninja 250R Tech Talk 11 August 19th, 2016 02:06 PM
Looking for 09 oem rear turn signal and front turn signals and tail fairings mbbernas Items Wanted 1 September 11th, 2013 10:48 AM
LED's! (footpeg turn signals, brake light strips, front signals oh my!) VeX 2008 - 2012 Ninja 250R Farkles 16 June 29th, 2012 12:03 AM
Rear turn signals don't blink, front turn signals don't turn on andyuc88 2008 - 2012 Ninja 250R Tech Talk 3 March 23rd, 2012 02:47 PM
Condensation in exhaust. headshrink 2008 - 2012 Ninja 250R Tech Talk 4 July 8th, 2010 01:24 PM
