Old January 4th, 2011, 08:07 PM   #1
frankfong
frankfong's Avatar
Motorcycle(s): 2004 Ninja 250
New battery, still won't start
1) Yesterday, my Ninja fired right up.
2) Today, it wouldn't turn over.
3) The solenoid clicks.
4) I bought a new battery.
5) It still won't start. Solenoid still clicks.
6) Main fuse is good.
7) Now the headlight won't turn on.
I have checked all the other posts I could find anything that worked and I am at my wits end.
Would a bad solenoid cause the headlight not turn on?
Any suggestions?
frankfong is offline   Reply With Quote
Old January 4th, 2011, 08:49 PM   #2
did you charge the new battery before use?
try jump starting the bike from a car.
Old January 4th, 2011, 09:06 PM   #3
frankfong
frankfong's Avatar
Yep, I hooked it up to a new "microcomputer controlled conditioner charger" that indicated it was 100% charged so I don't think it is the battery.
Old January 4th, 2011, 09:42 PM   #4
try jump starting it.
http://faq.ninja250.org/wiki/How_to_...ike_from_a_car
Old January 5th, 2011, 07:24 AM   #5
FrugalNinja250
FrugalNinja250's Avatar
Motorcycle(s): Several
The headlight won't turn on until the RPMs from cranking trigger the relay. If you can't crank the engine then it won't come on.
It sounds like you have a bad connection somewhere. Check where the negative wire from the battery connects to the chassis, and check where the positive wire connects to the starter.
If you can get a voltmeter, even a cheapie $10 model will work, you can measure the voltage between the positive terminal of the battery and the engine block. It should show the same as when you measure between the two battery terminals. If not, then you've got a wiring/connector problem to chase down.
Old January 11th, 2011, 07:05 PM   #6
frankfong
frankfong's Avatar
The starter fix
Okay, here is my fix in case someone else runs into this problem.
I was able to bump start my ninja but it would not start again once I turned it off. I removed the starter which was a simple job and took about 10 minutes. Remove the lower fairing, unbolt the two bolts holding the starter, used a hammer and a tap to dislodge it, unplug harness from starter relay/solenoid, and wiggle the starter out. To test it, I used jumper cables connected to a fully charged battery. Nothing happened - told me the starter was bad.
Bought a used starter from a cycle dismantler, reversed the process, and back on the road in an hour.
The moral of the story is that a clicking starter relay/solenoid means it's good and the starter is bad.
Old January 11th, 2011, 08:31 PM   #7
Old January 12th, 2011, 08:40 AM   #8
mrlmd
mrlmd's Avatar
You could have just bypassed the relay and attached heavy battery cables to the starter contact and see if it turned over, instead of taking the whole thing out and then testing it.
A clicking starter relay/solenoid usually means a discharged battery - not enough current to turn over the starter, not a bad starter.
Glad you got it running but you got it figured out by luck rather than logic.
Old January 12th, 2011, 09:04 AM   #9
frankfong
frankfong's Avatar
Thanks, but I disagree...
I thought it was a bad battery also so I took it down to the local dealership to have it tested. They said it had about 20% life left. Besides, it was the original battery from 2004 (7 years old) so it was time to change it out.
I also connected booster cables from the lead at the starter relay to the starter and it could not get the starter to spin. It is very difficult to connect a booster cable directly to the starter. It is a very tight squeeze and I had to wiggle it a bit to get it out.
As for your comment on luck versus logic, logic was exhausted so luck had to kick in.
It is funny how I got more Monday morning quarterback comments AFTER I solved my own problem than when I was trying to figure it out. That's why I am passing on my own experience to the next guy/gal who can use it.
Old January 12th, 2011, 10:08 AM   #10
mrlmd
mrlmd's Avatar
Which lead at the starter relay are you talking about? The in or out? The problem still could have been the relay but you wouldn't know that. Did you check first (with a meter) to see if the relay was even operating correctly before pulling out the starter?
What I was saying was to go directly to the starter from a good battery (bypassing or omitting the relay) and see if the starter turns over. That would have told you if the starter was good or not, without taking it out. You managed to take it out successfully, so it's no big deal but one poster on here managed to destroy a perfectly good starter removing it and the attached positive lead to it.
You have to start at the beginning and go through all the steps in a logical order to figure out a problem. In this case, starting at the battery and its connections, checking the relay, checking the starter.
But like I said, glad you got it running. And these are not "Monday morning quarterbacks", these are other members trying to help you with a problem by offering suggestions. If you feel that way, then don't ask for any more advice, maybe you won't be so lucky next time.
Won't start... :( HELP! deeno415 1986 - 2007 Ninja 250R Tech Talk 59 August 31st, 2013 05:53 PM
Ninja won't start! Dead battery. MarcoPolo General Motorcycling Discussion 11 April 1st, 2012 08:00 PM
killed battery now won't start - shorted something. pezlow010 1986 - 2007 Ninja 250R Tech Talk 38 December 10th, 2011 07:17 PM
changed battery n plugs started right up 5 min latter won't do anything? Bostonninjabastard 1986 - 2007 Ninja 250R Tech Talk 11 May 3rd, 2010 08:35 AM
Battery died, won't hold full charge? ASecretNinja General Motorcycling Discussion 10 August 20th, 2009 06:26 PM
