Old March 16th, 2012, 10:27 PM   #1
rideclassiv
Motorcycle(s): 1994 Ninja 250, 2000 SV650
spark plug tool
Just bought a 1994 Ninja 250r and trying to get it running good. The bike came with all the original tools except for the plug wrench, so I can't pull the plugs. Is there anything else that works, or any way to get an oem plug tool without spending too much? Thanks in advance guys.
rideclassiv is offline   Reply With Quote
Old March 16th, 2012, 10:53 PM   #2
5/8 inch spark plug socket works just fine for removing them.
Old March 16th, 2012, 10:57 PM   #3
I don't know how much a normal plug wrench costs, but I'm pretty sure it's more than the OEM tool and it will likely require you to remove the tank where the OEM one articulates to get under the tank. I see that is costs about $20 new online (Part number 92110-1132), so it should cost less from an owner parting out the used OEM toolkit.
Old March 16th, 2012, 10:59 PM   #4
a craftsman plug socket (only have to buy it once) cost me less than $5... tank removal to save $15? I'll do it.
Old March 18th, 2012, 12:38 AM   #5
I see. Something Casey/@ninja250 said made me think his was a lot more expensive.
Old March 18th, 2012, 12:46 AM   #6
Mountain Dew
Ambrosia.
Mountain Dew's Avatar
Motorcycle(s): 1974 Honda CB550K0 W.I.P.
Spark plug tools are relatively cheap. I spent $23 on my Honda one, and I thought that was WAY overpriced for one.
Life's better on the Mountain.
Mountain Dew is offline   Reply With Quote
Old March 19th, 2012, 09:58 AM   #7
rideclassiv
Thanks for the advice guys, my 5/8" plug socket worked with an extension and a u-joint.
Old March 19th, 2012, 10:15 AM   #8
rideclassiv
So now I can't get the plug back in. The threads look messed up so I assume the threads inside the engine are as well. What do I do now. I've owned 5 bikes and countless cars and I've never had so much trouble just changing plugs.
Old March 19th, 2012, 10:20 AM   #9
Hmm... I read that the torque wrench isn't recommended and that it was easily possible to strip the threads tightening it to spec. Lemme look it up and see if they had any other advice.
Old March 19th, 2012, 10:22 AM   #10
rideclassiv
Didn't use a torque wrench. Didn't even manage to get it threaded in due to the weird angle, then realized I must've stripped it trying. Feeling like kind of an idiot now.
Old March 19th, 2012, 10:34 AM   #11
Found it:
http://faq.ninja250.org/wiki/Changin...rands_to_avoid
They do say that getting it threaded right is hard but they don't show a fix if you crossthread anyway.
Perhaps their instructions to help get it threaded are still useful?
Old March 19th, 2012, 10:49 AM   #12
rideclassiv
Yes i did read that page, thank you. I should've taken the threading advice more seriously the first time. I did manage to get the new plug in. I will see if I can still get an oem plug tool from the dealer, since there don't seem to be any good alternatives online. Anyone have a spare one I could buy?
Spark plug removal tool or tool kit landon1 Items Wanted 11 April 1st, 2015 07:03 PM
disc lock, 08-12 spark plug boot, shim kit, DID chain breaker/rivet tool CThunder-blue Motorcycle-related 15 March 10th, 2015 09:59 AM
Replacement Spark Plug Removal Tool Roark 1986 - 2007 Ninja 250R Tech Talk 8 January 27th, 2015 04:54 PM
Spark plug tool - check/change plugs AmyF 1986 - 2007 Ninja 250R Tech Talk 20 August 2nd, 2014 05:36 AM
Broken Spark plug? Yasko General Motorcycling Discussion 8 June 8th, 2011 08:39 PM
