Old June 9th, 2011, 08:25 PM   #1
kaiserz
There's a limit to s2pdty
kaiserz's Avatar
Motorcycle(s): 250r ninja (sold)
Coolant recomendation?
hey guys, I just want to know what kind of coolant you guys use for your baby?
kaiserz is offline   Reply With Quote
Old June 9th, 2011, 11:25 PM   #2
Racer x
Racer x's Avatar
MOTM - Sep '18, Feb '16
I run engine ice
Old June 10th, 2011, 01:04 AM   #3
+1 I flushed out the stock coolant and replaced with engine ice. Even at 90 deg. F outside temp sitting at a red-light the bikes temp never goes into the red zone. Great stuff.
Old June 10th, 2011, 05:24 AM   #4
dubojr1
dubojr1's Avatar
Wouldn't regular coolant do the same...?
Old June 10th, 2011, 08:06 AM   #5
cwb48
Mature motorcyclist
cwb48's Avatar
Motorcycle(s): 2008 Ninja 250R, blue
FYI- whatever coolant you use, DO NOT use tap water in the mix. Tap water in most areas includes minerals that will quickly clog up an aluminum radiator. Use only DISTILLED water (not bottled water or spring water).
In case you are wondering, I did learn this the hard way.
Chris
cwb48 is offline   Reply With Quote
Old June 10th, 2011, 08:32 AM   #6
kaiserz
kaiserz's Avatar
Thanks guys! (: I'ma get "engine ice" on my day off, should I just mix it with the regular coolant? or flush the old coolant away?
Old June 10th, 2011, 09:03 AM   #7
dubojr1
dubojr1's Avatar
Ideally you never mix any 2 different coolants. http://www.engineice.com/faq.html
I'm not sure what the stuff cost but know that regular coolant/antifreeze will work just fine. It has till now right?
Old June 10th, 2011, 10:40 AM   #8
The OP wanted to know what kind of coolant people use in their bikes. Engine Ice is what I use.
Old June 10th, 2011, 10:46 AM   #9
dubojr1
dubojr1's Avatar
My bad. Your right...
Let me rephrase. Since you choose to use this product. Is there any scientific benefit to it over regular coolant?
Old June 10th, 2011, 10:53 AM   #10
kaiserz
kaiserz's Avatar
now all i need to know is "how to flush the coolant" and I think I good to go. ohhh and where can I get this? thanks guys!
Old June 10th, 2011, 11:39 AM   #11
dubojr1
dubojr1's Avatar
Here ya go... http://www.ninjette.org/forums/showp...40&postcount=6
Old June 10th, 2011, 01:30 PM   #12
Racer x
Racer x's Avatar
I use engine ice because it is legal coolant for every racing orgination I have checked. It dose not get slippery when it spills on the track . Even when I spill it on the floor it evaporates without a trace. They say it works better because it decreses the serface pressure or somthing. If you have over heating issues there is another problem. So no it does not make any difference what you use. Not mixing is a good idea.
To flush put a pan under the bike with the left fairing off. There is a 10mm bolt under the pipes at the bottom of the engine. Look careful and you will see the brown washer under it.that is a seal don't loose it. With the radiator cap off you remove that bolt. Then at the front of the engine there is an 8mm bolt .That will drain the rest.
Look at how much you took out mesure it in a jug or something. Then make sure you put that much back in. You might have to put some in then warm up the bike some and add the rest.
Be sure to recycle the old antifreeze .
Old June 10th, 2011, 08:36 PM   #13
kaiserz
kaiserz's Avatar
Thanks Jason, Thanks Eric (:
Old June 10th, 2011, 09:22 PM   #14
It is available at most dealerships.
Old June 11th, 2011, 12:48 AM   #15
ratlab
ratlab
ratlab's Avatar
Motorcycle(s): gsxr1000,R3x2,RC390,FZ07,XR100
engine ice always
ratlab is offline   Reply With Quote
Old June 29th, 2011, 07:53 AM   #16
kaiserz
kaiserz's Avatar
Okay, guys I got my engine ice sitting at the garage, I removed the old coolant and I'm ready to put the "ice", but I have a question, do I really need to put water to flush the old small amount of coolant away? or can I just pour my engine ice into the coolantthing w/o doing the water thing? also should I do this only on the reservoir or should I do this to the radiator too? thanks.
Old June 29th, 2011, 08:50 AM   #17
dubojr1
dubojr1's Avatar
I would advise flushing both the radiator and the reservoir bottle with distilled water prior to filling.
Old June 29th, 2011, 09:05 AM   #18
kaiserz
kaiserz's Avatar
OK, thanks dubo. now I'm on a mission to get distilled water
Old June 29th, 2011, 09:18 AM   #19
dubojr1
dubojr1's Avatar
You should be able to find it just about anywhere that sells gallon size bottled water. I think is about $.60 a gallon at WalMart.
Old June 29th, 2011, 10:25 AM   #20
caps
Sexy Beast
caps's Avatar
Motorcycle(s): 2010 Ninja 250R, 2006 ZX-14, 2012 Ducati Monster
Super Cool with Water Wetter
2010 Ninja 250
2006 Ninja ZX-14
^Both Links
caps is offline   Reply With Quote
Old June 29th, 2011, 11:19 AM   #21
kaiserz
kaiserz's Avatar
@dubo I got it at wallmart and it's like $.83 , but I'm glad I did put some water first and flushed the old coolant out, cause there were still tons inside.
Old June 29th, 2011, 11:29 AM   #22
dubojr1
dubojr1's Avatar
Awesome! Glad to hear you are happy with your success.
Old June 29th, 2011, 03:25 PM   #23
almost40
ninjette.org Monkey Spank
almost40's Avatar
Motorcycle(s): 2008 250R Track-Bike Woodcraft clip-ons and rearsets FZ-6 track bike
Originally Posted by caps View Post
Wetter here also. If it doesnt freeze or you have a heated garage and your bike never see's feezing temps. This stuff works just fine with distiled water. AND ITS CHEAP. you can swap coolant every year for about $2.00 per year. Got a buddy who loves his Engine Ice just as much as you guys. Nothin wrong with it but the price.
BTW theres nothing wrong with regular antifreeze. If your overheating you have other issues as RacerX stated.
Black 250R
Full Area P QC
Dyno Jet Kit 100 main 41T Rear Sprocket
almost40 is offline   Reply With Quote
Coolant Cap Jaife86 2008 - 2012 Ninja 250R Tech Talk 2 June 22nd, 2014 06:04 AM
Coolant SafetyPaws 2008 - 2012 Ninja 250R Tech Talk 33 May 17th, 2013 05:46 AM
Waterless Coolant? conrya5 1986 - 2007 Ninja 250R Tech Talk 11 April 28th, 2013 05:15 PM
What Coolant Do You Use? RiderOnTheStorm 2008 - 2012 Ninja 250R Tech Talk 19 March 12th, 2012 03:50 PM
Coolant top up RAMN 2008 - 2012 Ninja 250R Tech Talk 19 August 17th, 2011 04:26 AM
